Fan Support on Steel truss - Electrician Talk - Professional Electrical Contractors Forum
Like Tree24Likes
  • 10 Post By tjb
  • 1 Post By Bird dog
  • 1 Post By 99cents
  • 1 Post By frenchelectrican
  • 1 Post By brian john
  • 6 Post By splatz
  • 2 Post By bill39
  • 1 Post By gpop
Old 07-19-2018, 01:43 PM   #1
Flex Bits & Blindfolds
Mshow1323's Avatar
Rewards Points: 2,210
Default Fan Support on Steel truss
I need to mount a ceiling fan on a rounded steel truss system, and having a hard time wrapping my head around it.
My idea was to just use a fan box and thread a U Bolt through and over the beam threaded through a 1900 blank on the top side to keep it from rocking and rolling.
Surely someone has a better idea that that. Picks of licks will help my visualize it
NOT MY REAL NAME!
Mshow1323 is offline   Reply With Quote
Old 07-19-2018, 01:50 PM   #2
Rewards Points: 8
Is welding an option? If so, a flat plate welded to the round beam.
Sent from my HTC6545LVW using Tapatalk
Shaneyj is offline   Reply With Quote
Old 07-19-2018, 01:50 PM   #3
Rewards Points: 18,061
Better than that? How can that idea be topped? Do it.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 07-19-2018, 02:05 PM   #4
Rewards Points: 21,896
How big the ceiling fan is ??
Old 07-19-2018, 02:11 PM   #5
Mshow1323's Avatar
96-inches
NOT MY REAL NAME!
Old 07-19-2018, 02:14 PM   #6
Mshow1323's Avatar
Def not within my skills
NOT MY REAL NAME!
Old 07-19-2018, 02:56 PM   #7
Bird dog's Avatar
Rewards Points: 852
Originally Posted by Mshow1323 View Post
96-inches
That's eight feet! How are you mounting the fan?
Old 07-19-2018, 02:59 PM   #8
tjb
Cool Kid
Rewards Points: 363
Straddle parallel trusses with strut, hang fan from strut.
tjb is offline   Reply With Quote
Old 07-19-2018, 03:05 PM   #9
Bird dog's Avatar
Rewards Points: 852
Mount box to strut & flex to fan.
brian john likes this.
Old 07-19-2018, 03:28 PM   #10
Mshow1323's Avatar
hahah, Duh. I forgotten that I've done that before. Thanks guys, I'm an idiot
NOT MY REAL NAME!
Old 07-19-2018, 03:58 PM   #11
Rewards Points: 13,951
You're not an idiot. Yesterday I forgot how to open the hood on my van. I'm an idiot.
Mshow1323 likes this.
Old 07-19-2018, 04:51 PM   #12
8 feet that is pretty serious fan size .,, but make sure you mounted good so it will not come loose on that.
The biggest one I installed was 18 footer now that really blow a lot of air!!
Bird dog likes this.
Old 07-19-2018, 05:28 PM   #13
Rewards Points: 1,956
I have to go through security at least once a week and we have to open everything up. I constantly wrestle with the hood.
99cents likes this.
Old 07-19-2018, 05:38 PM   #14
tjb
Cool Kid
Rewards Points: 363
You were just over thinking it. I do that all the time.
Old 07-19-2018, 05:51 PM   #15
Rewards Points: 1,092
Small additional point, if possible I put the strut on top of the truss bars rather than hang the truss under, this way the fasteners are just holding the strut in place, not taking the weight of the fan.
Old 07-19-2018, 06:43 PM   #16
Do what the guy that owned my house before I bought the place, just hang them on a Bakelite box with a standard fixture bar.
The only good thing about bakelite boxes is removing them, smack them lightly with Kleins and a screwdriver and they shatter.
I but the would hold up if a fan was slightly out of balance NOT.
Old 07-19-2018, 06:47 PM   #17
Rewards Points: 1,576
Default X
Also, most of the plant safety or job site inspectors I’ve dealt with would also require a looped steel cable with Crosby-type clamps to hold the fan as a safety means in case a bot comes loose or whatever.
brian john and splatz like this.
bill39 is online now   Reply With Quote
Old 07-19-2018, 07:52 PM   #18
Rewards Points: 1,748
Hurricane irma couldn't get this one down. It had a safety wire just in case
readydave8 likes this.
Old 07-20-2018, 01:02 AM   #19
I'm no fan of big fans..............
JOBS GROWTH SOARS
RECORD WORKING
Drudge Report
Old 07-20-2018, 02:07 AM   #20
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 192
http://docs.bigassfans.com/eseries/e...tall-guide.pdf
Cowboy words of wisdom.
Fastening to Insulated Steel Wall Panels RickM15752 General Electrical Discussion 8 11-16-2017 08:07 PM
EMT for Cat 6 in steel framed warehouse, grounding required? RickM15752 Commercial Electrical Forum 11 10-16-2017 08:49 PM
EGC to footer steel denno19 NEC Code Forum 18 06-02-2017 08:46 PM
Technical Support - what do you prefer? Square D_Sarah Square D by Schneider Electric 30 02-04-2017 03:57 AM
