Fastener of choice - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Closed Thread
Old 09-16-2013, 11:28 AM   #41
360max's Avatar
Rewards Points: 1,234
Originally Posted by Cletis View Post
This is the professional method. I use this of course and it passes
why are you wasting an additional screw, I'd fire you?
360max is offline
The Following 4 Users Say Thank You to 360max For This Useful Post:
crazyboy (09-16-2013), drumnut08 (09-16-2013), Magnettica (09-16-2013), That_Dude (09-17-2013)
Old 09-16-2013, 07:41 PM   #42
Tool Fetish
If you're really careful, I guess you could just drive one long screw through the SER and save the piece of romex also.
SteveBayshore is offline
The Following User Says Thank You to SteveBayshore For This Useful Post:
crazyboy (09-17-2013)
Old 09-16-2013, 07:46 PM   #43
BBQ
Salty Member
BBQ's Avatar
That would be a clear violation, the NM is not.
Personally I would use staples but all you haters on the NM strap are going just by looks and not by effectiveness.
BBQ is offline
Old 09-16-2013, 07:58 PM   #44
Rewards Points: 1,213
When you're right, you're right. Romex strapping is as effective as hand tightening locknuts. Both work just fine.
HackWork is online now
Old 09-16-2013, 08:00 PM   #45
BBQ
Salty Member
BBQ's Avatar
Not at all, but you do what makes you feel cool.
BBQ is offline
Old 09-16-2013, 08:01 PM   #46
Code compliant
Old 09-16-2013, 08:03 PM   #47
gold's Avatar
Rewards Points: 2,070
Tie wire!
Define "Anger Management"
“Free at last, Free at last, Thank God almighty we are free at last.”
gold is offline
Old 09-16-2013, 08:04 PM   #48
BBQ
Salty Member
BBQ's Avatar
Code compliant
Nope ... unless you are removing the paint first.
250.12 Clean Surfaces. Nonconductive coatings (such as
paint, lacquer, and enamel) on equipment to be grounded shall
be removed from threads and other contact surfaces to ensure
good electrical continuity or be connected by means of fittings
designed so as to make such removal unnecessary.
Nothing on the connector will cut into the paint if hand tight.
Now you are more than free to ignore this but an inspector could fail you on it and you would not have a leg to stand on.
Well see ya for a while, off to work.
BBQ is offline
Old 09-16-2013, 08:05 PM   #49
The little teeth pierce/scratch it, that's what they are made for.
That's your opinion. It's not a fact.
Impossible.
Old 09-16-2013, 08:08 PM   #50
Rewards Points: 1,006
Originally Posted by drumnut08 View Post
Lol ! Use bubble gum if you want , I could care less . I'll use the proper strap and still make money in the process . Not everyone wants the cheapest install that barely squeaks through an inspection ( if there is one ) .
And those who specify they don't want the cheapest install possible get what they request. Those who want the cheapest install possible get the NM strap. Horses for courses.
FWIW, this doesn't "barely squeak through". Something either complies or doesn't. I've never been graded in an inspection.
You seem to have a lot of energy around this. I've never used romex to hang cable, but I certainly understand that it's code compliant and it does work (I've seen really old jobs done this way) and last.
__________
Was born in HACKensack, NJ
CraigV is offline
The Following User Says Thank You to CraigV For This Useful Post:
Old 09-16-2013, 08:21 PM   #51
Maple_Syrup25's Avatar
Rewards Points: 780
i was in a old cottage and the guy who wired the place used roofing nails in between the ground and hot or neutral. did a very neat and tidy job too.
Maple_Syrup25 is offline
The Following User Says Thank You to Maple_Syrup25 For This Useful Post:
sbrn33 (09-17-2013)
Old 09-16-2013, 08:37 PM   #52
While it apparently worked and possibly lasted, it wouldn't be code-compliant because it damaged the cable.
__________
CraigV is offline
Old 09-16-2013, 08:42 PM   #53
Rewards Points: 780
it does work and still lasts. I wasnt at work at the time, i just looked at it and chuckled. definately wouldnt pass.
Old 09-16-2013, 08:48 PM   #54
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
For a longer run of medium size SER cable, what is your favorite method of support? In this situation, about 80' long run under wood joists above a drop ceiling.
Install bridal rings and then pull thru them? Or pull the SER and then use large staples to support afterwards?
PVC straps.
Replies based on NEC 2014
Magnettica is offline
Old 09-16-2013, 10:54 PM   #55
Southeast Power's Avatar
Rewards Points: 8,888
Why would that stop you from using SER cable?
I don't know. We just don't see it down in this part of Florida.
30+ years in the trade, I have never installed it.
Thousands of service calls, maybe have seen it once or twice in older small houses.
Southeast Power is offline
Old 09-16-2013, 11:14 PM   #56
drumnut08's Avatar
Rewards Points: 1,012
Not really , but when I see something half assed like a scrap piece of Romex being used as something they make specifically for the purpose , I don't get it , nor will I do it . To each his own , besides the NEC is minimum standards anyway , lol ? I'll start saving my old worn out shoelaces for you and Cletis if you want ?
drumnut08 is offline
Old 09-16-2013, 11:20 PM   #57
Rewards Points: 19,133
The inspectors around here will fail if the romex in that picture has any conductors inside the sheath, cause they feel that it creates a transformer coil wrapped around the other cable like that once the current flows in the ser......
The lab was just 260 meters away from the Wuhan seafood market....... 853ft 0.2204880in. Chinese Wuhan Virus.
macmikeman is online now
Old 09-17-2013, 12:01 AM   #58
Rewards Points: 314
I guess theres nothing wrong with the romex sheath, as it is pretty durable and wont deterioate easy. However Ive got a feeling it would be frowed upon around here.
Briancraig81 is offline
Old 09-17-2013, 07:05 AM   #59
drumnut08's Avatar
Exactly ! I can hear the inspector now " you know , they make actual straps for that ? " legal or not , it looks like garbage , and if anyone has a shred of pride in their work , they're not doing that ! Different strokes , I guess ?
Old 09-17-2013, 08:45 AM   #60
It's easily tested for output, isn't it? I'd also like to see what article that violates.
Again, for the other naysayers, the point wasn't whether it was pretty or the best method, or recommended. They point was that it's NEC compliant, which it was claimed to not be.
__________
CraigV is offline
BBQ (09-17-2013)
Closed Thread
Other Job Choice bobelectric General Electrical Discussion 50 07-23-2013 01:45 PM
Weapon of choice jbfan Residential Electrical Forum 16 06-12-2012 10:59 PM
Your second choice Chris1971 Off Topic (Non Trade) 95 05-28-2012 01:27 AM
Your drill set of choice A_D Tools, Equipment and New Products 41 11-12-2011 01:28 PM
Had No choice Shockdoc General Electrical Discussion 61 06-02-2011 04:31 PM
