Fastener of choice - Page 4 - Electrician Talk - Professional Electrical Contractors Forum
Closed Thread
Old 09-17-2013, 11:01 AM   #61
BBQ
Salty Member
BBQ's Avatar
The inspectors around here will fail if the romex in that picture has any conductors inside the sheath, cause they feel that it creates a transformer coil wrapped around the other cable like that once the current flows in the ser......
Electrical theory be dammed!
BBQ is offline
Old 09-17-2013, 01:02 PM   #62
drumnut08's Avatar
Rewards Points: 1,012
Originally Posted by CraigV
It's easily tested for output, isn't it? I'd also like to see what article that violates.
Again, for the other naysayers, the point wasn't whether it was pretty or the best method, or recommended. They point was that it's NEC compliant, which it was claimed to not be.
I totally get the point , but my point was most of us won't be using what's mostly considered " trash " to strap cable , Legal or not . Another area of the NEC that can stand tightening up IMO .
drumnut08 is offline
Old 09-17-2013, 01:08 PM   #63
Rewards Points: 18,183
If it were to induce with a single turn, it would have to be current in one direction only in the cable supplying the load. Most ser I run has a neutral in it so there would be cancellation anyway. This might be worthy of a field mactesting to lay the whole stupid to rest...... Ct and recording device on pipe strap.......
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
macmikeman is offline
Old 09-17-2013, 01:11 PM   #64
Rewards Points: 1,337
Whats the difference between the romex twisted around the SER and a bridle ring?
HackWork is online now
Old 09-17-2013, 01:13 PM   #65
Hax, I like your bridal ring thing. I have been sitting on two boxes of them for about a quarter of a century. Next old house rewire the subfeeder for the load centers run underneath the crawlspace is getting bridal rings.
JOBS GROWTH SOARS
RECORD WORKING
Drudge Report
Old 09-17-2013, 01:24 PM   #66
denny3992's Avatar
Rewards Points: 2,014
Did 3" bridals in my house... Old hand hewn 8" logs, i wasnt drilling them so i tucked rings against the outside wall
denny3992 is offline
Old 09-17-2013, 01:26 PM   #67
Do you have the kind that hang from clips? If you have the ones that thread into wood, then that could be more work than it's worth unless you make a drill attachment so you could drive them in with the drill.
I've been threading an eye-bolt into my drill and using it to screw the service drop POA hook into houses that way, works really well for lazy bums like me.
Old 09-17-2013, 01:31 PM   #68
360max's Avatar
Rewards Points: 1,234
price, and securly support versus just supported
360max is offline
Old 09-17-2013, 01:37 PM   #69
My post was in reference to the induced voltage that Mike was talking about.
Old 09-17-2013, 01:52 PM   #70
drumnut08's Avatar
For starters , a bridle ring is not a complete enclosed metallic circle around the wire , its an open loop , secondly the chances of inducing anything even readable , I'd say are slim to none . The way that Romex support completely wrapped the SER , maybe would make a difference , but I doubt it ? I wasn't as concerned with induced voltage as I was aesthetics . If there's no wire in the Romex jacket , it's still ugly , but certainly nothing else to worry about .
Old 09-17-2013, 01:56 PM   #71
I dunno, a bridle ring seems to be very similar to the wrap of romex...
Old 09-17-2013, 04:26 PM   #72
BBQ
Salty Member
BBQ's Avatar
Why would the NEC need to be tightened up?
The purpose of the NEC is safety, not esthetics.
The NM strap is strong and has much less chance of damaging the cable than a metal staple.
BBQ is offline
sbrn33 (09-17-2013)
Old 09-17-2013, 04:28 PM   #73
BBQ
Salty Member
BBQ's Avatar
That's the thing, we are encircling an entire circuit, not a single conductor.
Ask the inspector what the reading on an amp clamp would be if the put it around the cable.
BBQ is offline
Old 09-17-2013, 06:06 PM   #74
Rewards Points: 1,006
The Romex is worth more, it's copper!
__________
Was born in HACKensack, NJ
CraigV is offline
Old 09-17-2013, 06:13 PM   #75
Ask the inspector what the reading on an amp clamp would be if he put it around the cable.
Another issue is that the wrap is of a non-ferrous material, so they can't claim eddy current heating.
__________
CraigV is offline
Old 11-22-2017, 11:33 PM   #76
MTW
Rewards Points: 10,212
Fascinating stuff. Good thread.
MTW is offline
Old 11-22-2017, 11:35 PM   #77
Do you like doing the screwing? Or the other way around?
Old 11-23-2017, 07:54 AM   #78
Rewards Points: 446
Originally Posted by Shockdoc View Post
The investment that keeps giving. It takes a little longer even with the right drill( a superhogg) but less hardware to purchase and a cleaner job.
then you hit a nail and... . then another and then your progress comes to an end. Used a 2" the other day ,which I thought was destroyed, but was in excellent condition and worked great.
farmantenna is offline
Old 11-23-2017, 08:01 AM   #79
Rewards Points: 446
Originally Posted by Speedy Petey View Post
Two-hole PVC straps.
called Handy Straps with nails ready to go by Sturgeon Bay Metal Products
Closed Thread
Other Job Choice bobelectric General Electrical Discussion 50 07-23-2013 02:45 PM
Weapon of choice jbfan Residential Electrical Forum 16 06-12-2012 11:59 PM
Your second choice Chris1971 Off Topic (Non Trade) 95 05-28-2012 02:27 AM
Your drill set of choice A_D Tools, Equipment and New Products 41 11-12-2011 02:28 PM
Had No choice Shockdoc General Electrical Discussion 61 06-02-2011 05:31 PM
