Fastening to Insulated Steel Wall Panels - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 2 Post By ppsh
  • 1 Post By splatz
Old 11-04-2017, 07:17 PM   #1
Rewards Points: 52
Default Fastening to Insulated Steel Wall Panels
I'm working on a commercial steel building with girts, purlins and insulated steel wall panels. I'm a low voltage contractor and will be attaching cameras, camera housings, and an alarm bell/housing on the exterior. Most areas are quite easy with some interior drywall and attaching EMT to girts and purlins. But, it's the insulated steel wall panels that pose a bit of a challenge. I see where various trades people have done various things to a fasten to these walls for exterior lights and other interior devices. Some of their techniques looks somewhat dodgy.
Some existing exterior devices, attached long ago, are attached with machine bolts/nuts completely through the wall, but I see where tightening these has created an indentation on the wall.
The insulated steel walls appear to be 26 - 24 gauge, and using a self tapping sheet metal screw can easily strip the hole causing the screw to spin freely if not careful.
I see where the walls are attached to the girts with what appear to be heavy duty rivets. I don't want to do that in the event something needs to be moved.
What seems to work best with these walls? Something similar to molly bolts perhaps?
RickM15752 is offline   Reply With Quote
Old 11-04-2017, 07:37 PM   #2
ppsh's Avatar
Rewards Points: 118
If it is something light, #10x1 stainless wood screws, otherwise fab-lok fasteners.
glen1971 and splatz like this.
ppsh is online now   Reply With Quote
The Following User Says Thank You to ppsh For This Useful Post:
RickM15752 (11-04-2017)
Old 11-04-2017, 08:15 PM   #3
Rewards Points: 52
Thanks for the quick reply. This looks like the thing to use. The heaviest device I'll be installing is an outdoor bell in a tampered housing, 15.5 lbs., the cameras and mounts won't be any heavier.
These look like heavy duty molly bolts. I see some distributors sell them by the lot, minimum 1000 for $700.00. I'd never use that many, so I'll be checking my suppliers.
Thanks again.
Old 11-04-2017, 08:41 PM   #4
Rewards Points: 956
The fastener that @ppsh looks excellent but they make a similar anchor that may be cheaper. It's like the old fashioned hollow wall anchors / drive anchors, but it works with very thin materials.
You can also use rivet nuts, which are exactly what they sound like.
Old 11-04-2017, 09:29 PM   #5
Rewards Points: 52
Thanks Splatz. The image @ppsh sent shows a distributor www.windstormproducts.com, which sells them individually in various sizes .86 ea., .93ea., and 1.00 ea., for the sizes I may need. The image you posted looks good too. Is there a brand and model to look up on those?
Old 11-16-2017, 06:43 AM   #6
Rewards Points: 956
I forgot about this until yesterday, I was working at a glass shop and asked the glasiers about it, a common term for these is "jack nut".
I have shown some restraint and only used the term "jack nut" maybe fifty or sixty or at most a couple hundred times since learning it yesterday.
Jack nuts are now obviously my favorite fastener of all time.
https://www.amazon.com/dp/B00NUFMIIO...UFMIIO5268055/
glen1971 likes this.
Old 11-16-2017, 06:47 AM   #7
Rewards Points: 26,408
How do you come off using 'jack-nut' ?
Old 11-16-2017, 07:09 AM   #8
Rewards Points: 956
AAAaggghhh.... my head ... tooo ... many ..... jokes.....
Old 11-16-2017, 08:07 PM   #9
Rewards Points: 260
Google Sammys steel fasteners. They will have what you need.
btharmy2 is offline   Reply With Quote
EMT for Cat 6 in steel framed warehouse, grounding required? RickM15752 Commercial Electrical Forum 11 10-16-2017 08:49 PM
PV conduit inside exterior wall permitted? katwalatapan Alternative Energy Forum 11 12-05-2016 01:09 PM
Wire into bottom of insulated wall BobN Residential Electrical Forum 12 07-23-2016 09:01 PM
Venting, not HVAC 220/221 General Electrical Discussion 6 07-07-2016 11:09 AM
Hanging heavy lights on a furred wall. Year_Zero General Electrical Discussion 16 02-25-2016 07:38 PM
