A faulty light fixture? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
Old 10-08-2017, 04:26 PM   #1
AlmostPro's Avatar
Rewards Points: 142
Default A faulty light fixture?
Hello all,
Just hoping to get some advice perhaps. Yesterday I was installing new LED light bulbs in a ceiling fan. It seemed to work great for a few minutes then turned off and on then stayed off. I first thought it would be a tripped breaker perhaps however it was not. I next thought a loose wire either on the switch or in the fan, it seems to be neither. I am going to try a new switch today to see if that does anything however if not does anyone here have any other suggestions?
the rating plate is for 60 WATT bulbs which I got, however it also said incandescent, I haven't known any fixtures not being able to take LEDs.
AlmostPro is offline   Reply With Quote
Old 10-08-2017, 04:42 PM   #2
Rewards Points: 1,330
Sometimes those fans have a watt limiter built in so the led may be causing issues with that item.
I can't help it if I'm lucky
Old 10-08-2017, 04:45 PM   #3
AlmostPro's Avatar
Rewards Points: 142
Hmm if that were the case then putting in the old bulbs or even having no bulbs would turn on the fan at least yes? I tried but if anything it seems fried.
Old 10-08-2017, 04:47 PM   #4
Rewards Points: 1,468
So a 60watt incandescent will work but not a 9 or 13 watt LED?
Never seen that before.
Old 10-08-2017, 04:49 PM   #5
AlmostPro's Avatar
Rewards Points: 142
Right those incandescent lights had been working for a good year, so i went to upgrade and it all just stopped working.
Old 10-08-2017, 04:50 PM   #6
AlmostPro's Avatar
Rewards Points: 142
I am hoping it is just a fault in the switch but who knows.
Old 10-08-2017, 04:50 PM   #7
I see you say you're an apprentice, don't be a parts changer.
Do you have a Wiggy or other load type circuit tester?
Take a reading on the voltage in and out of the switch, check for voltage with a meter at all connections.
Know where you do and don't have voltage.
Curious, why ask here rather than ask your journeyman?
sbrn33 and glen1971 like this.
Old 10-08-2017, 04:51 PM   #8
It has to do with the current limiter that is attached to the socket. By-pass the limiter and you'll be okay but UL listing is voided. Have I done it? (Head down_) Yes
It has more to do with the electronics in the LED somehow messing with the current limiter
Old 10-08-2017, 04:52 PM   #9
Don't 'hope', diagnose!
Old 10-08-2017, 04:53 PM   #10
You probably blew out the current limiter-- incandescent only means something in this case
Old 10-08-2017, 04:54 PM   #11
I guess I've installed cheap fans....
Old 10-08-2017, 04:54 PM   #12
AlmostPro's Avatar
Rewards Points: 142
I did, he suggested that I change the light back and forth, try with and with out the lights. Make sure to turn the breaker on and off, make sure all wires are tight within the switch and in the fixture. I have done all the above to no avail. I have already given up on the fixture and am now just trying to figure out what could be the cause. As for the circuit tester I did try to get a reading last night but didn't have much luck with getting a reading. I plan to try again before I change out the switch.
Old 10-08-2017, 04:55 PM   #13
What are you using for a tester/meter?
Old 10-08-2017, 04:57 PM   #14
AlmostPro's Avatar
Rewards Points: 142
just a basic multimeter. I'd rather have a voltage tester but alas here I am without for now.
Old 10-08-2017, 04:59 PM   #15
Not so sure it has to do with the quality. There was a period of time where they were used and it may have been just one company, IDK however I have run into it a few times
Old 10-08-2017, 05:02 PM   #16
AlmostPro's Avatar
Rewards Points: 142
Would a faulty limiter cause the whole assembly to stop working even after removing the LEDs?
Old 10-08-2017, 05:03 PM   #17
Do you recall the brand?
Old 10-08-2017, 05:05 PM   #18
That should be fine for reading the switch and connections up stream.
Old 10-08-2017, 05:05 PM   #19
AlmostPro's Avatar
Rewards Points: 142
The one I'm having issues with is Hunter.
Old 10-08-2017, 05:08 PM   #20
MTW
MTW's Avatar
Rewards Points: 8,678
I always cut out the watt limiter.
sbrn33 likes this.
help with a light fixture heavysparky Industrial Electrical Forum 11 04-27-2017 08:45 PM
Switch for an outdoor motion sensor light fixture? Islander Canadian Electrical Forum 7 03-04-2017 01:00 PM
Turning a recessed light into a fixture box. HackWork Lighting Design 9 12-06-2016 10:06 PM
Bathroom mirror -- light fixture Spark Master Residential Electrical Forum 16 08-22-2016 08:26 PM
