feeder - Electrician Talk - Professional Electrical Contractors Forum
Old 02-07-2015, 08:24 PM   #1
Rewards Points: 14
Default feeder
a different perspective.i have a T building 150 away from exiting H frame service. i need to feed three separate 200a panels on t building. the feeder needs to be ran over head to new H frame that will support disconnects for t buildings. Accoridng to 225.30 it has to be a single feeder run to h frame then I can
feed to gutter that feeds disconnects to each 200a panel inside T building. does that make any since?
im asking for ideas. BTW can i hang the New 600a disconnect that will feed the feeder to the new H frame with gutter then 200a disconnects. or do i need to hang disconnect at New H frame location
mannyb is offline   Reply With Quote
Old 02-07-2015, 08:57 PM   #2
Rewards Points: 14
Default New Feeder Run
I have a T building 150 away from exiting H frame service. i need to feed three separate 200a panels on T building. The feeder needs to be ran over head to new H frame that will support disconnects for T buildings. Accoridng to 225.30 it has to be a single feeder run to H frame. then Can
I feed to gutter that feeds disconnects to each 200a panel inside T building. does that make any since?
im asking for ideas. BTW can i hang the New 600a disconnect that will feed the feeder to the new H frame with gutter then 200a disconnects. or do i need to hang disconnect at New H frame location[/quote]
I am looing for different perspective on this topic.
Old 02-07-2015, 09:10 PM   #3
NacBooster29's Avatar
Rewards Points: 1,018
Who said you needed a 600 amp feeder? Have you done an actual load calculation?
Having 3 , 200 amp panels does not nessesarily mean you need a 600 amp feeder.
Way too many unknowns here
Old 02-07-2015, 10:04 PM   #4
Rewards Points: 14
sorry I tried to edit after posting but couldn't figure it out.
I have a T building that basically needs 3- 200a panels hooked up.
the customer has a 800a service on H frame with no load.They want the feeder to run overhead from existing H frame.
my idea was to install new H frame next to T building with 600a disconnect with gutter that would feed 3 disconnects that would feed the 3 panels needed. im just asking if anyone has any better ideas.
Old 02-07-2015, 10:29 PM   #5
How far overhead? What voltage?
600 amp aerial cable is no joke.
I would consider finding out the actual demands for each 200 amp panel.
You may be able to run a smaller feeder to the remote building. It is rare that the actual demand is 100% of the panels ratings. In fact almost never.
Old 02-08-2015, 02:56 PM   #6
Rewards Points: 68
No way I'd be running600 amps overhead, a transformer is in order here.
rookie sparky is offline   Reply With Quote
Old 02-08-2015, 03:12 PM   #7
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,529
What in the world is this guy talking about? If you are a journeyman electrician at least speak the language.
The Following 3 Users Say Thank You to Jhellwig For This Useful Post:
glen1971 (02-08-2015), mcclary's electrical (02-08-2015), NacBooster29 (02-08-2015)
Temporary Feeder 0volt NEC Code Forum 2 12-25-2012 10:53 PM
feeder, O/C sizing Darcinder General Electrical Discussion 3 12-18-2012 09:36 PM
Feeder question... Spartan98 Residential Electrical Forum 2 12-09-2012 08:07 PM
elevator feeder kysparky General Electrical Discussion 5 06-20-2011 04:02 PM
A/C Feeder Evan88 Commercial Electrical Forum 3 04-01-2011 08:29 PM
