Final connections in service panel. - Electrician Talk - Professional Electrical Contractors Forum
Like Tree9Likes
Old 07-13-2017, 01:27 PM   #1
Default Final connections in service panel.
I have a question regarding touring if wires and connections inside service panel.
If the ground and neutral bus bars are on the sides of the box and you have that small amount of space between panel and busbar, is it allowable to make your connections on that side of the busbar, which would make a cleaner box but I'm sure would be fun making connections.
Mcswain is offline   Reply With Quote
Old 07-13-2017, 01:30 PM   #2
Rewards Points: 3,240
Not following your description.
Old 07-13-2017, 01:40 PM   #3
Rewards Points: 23,896
You lost me as well.
Old 07-13-2017, 01:50 PM   #4
Speedy Petey's Avatar
Rewards Points: 662
I think he means if the bar is closer to the sides of the box can you make the connections in that small space.
Yes, you can make the connections on either side as long as there is room to bend the conductors.
brian john and MechanicalDVR like this.
Old 07-13-2017, 01:55 PM   #5
For example the locations of the ground and neutral bus bars. There to far outside of panel. Instead of making connections on right side of neutral busbar, can you bring them down left side? Vice versa for ground busbar.
Old 07-13-2017, 01:56 PM   #6
Yes sir! Sorry for confusion! I try to be as detailed in description.
Old 07-13-2017, 02:15 PM   #7
I don't ever see it done. Is there a reason? Time consumption?
Old 07-13-2017, 02:38 PM   #8
Rewards Points: 1,589
It's too tight to bend it in there, takes too much time for no real benefit.
brian john, glen1971 and telsa like this.
Old 07-13-2017, 04:19 PM   #9
Gold Pliers Champion
Signal1's Avatar
Rewards Points: 2,550
Pretty much. Why would you want to do that?
Like Pete mentioned bending space would most likely be an issue.
brian john likes this.
"Hanging ceiling fans for grandma"
M E T G A !
Signal1 is online now   Reply With Quote
Old 07-13-2017, 09:35 PM   #10
Rewards Points: 792
Marrettes in a new panel ? measure twice and cut once as my incharge used to say before smacking me around my ears ! Good old days !
Old 07-14-2017, 02:30 AM   #11
Magic Smoke Remover
Rewards Points: 1,966
I think that's just a stock photo, if not, WTF...
Still, WTF?
lighterup likes this.
Old 07-14-2017, 10:36 AM   #12
Rewards Points: 321
I have done it in an old panel when there were just too many neutral wires in a spaghetti heap to slip the new ground or neutral neatly into place. Especially a bare ground; I don't want that "floating" above a mess of wires where it could accidently move and touch a hot location. Or rearranging a panel where maybe someone double tapped and did something else that makes me want to move things around. It may be easy to take the neutral or ground out of the bus bar, but difficult to put in into the new spot (to be honest, I would rarely feel it necessary to move the neutral or ground if I were just dealing with a double tap ...unless for some reason it had to go to the other side of the panel and i had to move the whole wire).
Greg Sparkovich is offline   Reply With Quote
Old 07-14-2017, 10:58 AM   #13
Rewards Points: 976
The splices in the panel is not an issue however, look at the number of EGC's in the conduits.
Considering that and the open KO's it must be part of a rework.
Roger
Roger is offline   Reply With Quote
Old 07-14-2017, 11:41 AM   #14
Wiring up a full panel in class. Next week I'll get some pics and let you all critique? Be gentle! You guys can be hurtful!
Old 07-14-2017, 11:42 AM   #15
The pic of the panel was to reference the locations of busbars and the connections from behind I was referring to.
Old 07-14-2017, 05:11 PM   #16
Can't sign em..forget em
lighterup's Avatar
Rewards Points: 10,200
Still, WTF?
Old 07-14-2017, 05:21 PM   #17
I dAtEd A gUrL oNcE
cuba_pete's Avatar
Rewards Points: 3,287
...not hurtful, but 'critique-al'...
...it's less hurtful than monetary penalization from an AHJ d!ckhead.
To build a cenotaph, you must first choose a million victims
Old 07-14-2017, 05:29 PM   #18
??? True!!
Old 07-15-2017, 07:43 AM   #19
Rewards Points: 319
consistently blows me away the pictures that people throw up on google to "show off" their "neat" tie ins to promote their shop or whatever.
you'd get laughed off site around here with that dogs breakfast. (btw OP i know that's not your tie in)
IBEW Local 2085
fisstech is offline   Reply With Quote
Old 07-15-2017, 08:10 AM   #20
Rewards Points: 26,838
Those KOs are brutal.
Win The Future... says it all.
200A Service Upgrade Panel Suggestions Dynamic18 General Electrical Discussion 20 02-18-2017 01:02 PM
Service Panel Parameters tinkering General Electrical Discussion 72 01-24-2017 01:12 PM
Service wires coming into the panel: how to tell what guage they are? Islander General Electrical Discussion 10 01-22-2017 10:28 AM
Residential 200amp Electrical service panel 13grind Services and Service Equipment 5 08-08-2016 12:18 AM
Service Panel Mounted on Fieldstone Wall? CGW General Electrical Discussion 31 03-19-2016 11:06 AM
