Fire in the attic and breakers didn't trip. - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree23Likes
Old 05-11-2016, 04:07 PM   #21
sbrn33's Avatar
Rewards Points: 3,510
I am interested to see what the rep says.....
Old 05-11-2016, 05:34 PM   #22
Bad Electrician's Avatar
Rewards Points: 4,969
Originally Posted by Smileyboy View Post
Just makes me incredibly worried
Sent from my iPhone
My firm test circuit breakers if you can send me the circuit breaker I will test the circuit breaker and can send you a letter starting if the circuit breaker meets the manufactures Time Current Curve (TCC)
I was born with a plastic spoon in my mouth.
Old 05-11-2016, 05:36 PM   #23
daveEM's Avatar
Rewards Points: 2,382
I think all residential fires are electrical. Well the odd time a guy puts out his smoke in the flower pot. Or burns the siding off his house with his bbq.
Insurance company on a witch hunt?
Edit: I see you are from the US. I suppose someone is going to get sued and the homeowner will never have to work again. Stress and all. 10, 20 mil settlement.
Good place America. They should remove the bottom feeding lawyers tho.
I like perfect.
The Following User Says Thank You to daveEM For This Useful Post:
Jay82304 (05-11-2016)
Old 05-11-2016, 06:07 PM   #24
Rewards Points: 216
I sure hope not.
I was told insurance getting a fire investigator was standard procedure.
In Denver, Co doing Service work and Remodel all day... Love it.
Smileyboy is offline   Reply With Quote
Old 05-11-2016, 06:08 PM   #25
Rewards Points: 216
I'm not sure that I'm "allowed" to get inside the panel.
Old 05-11-2016, 06:27 PM   #26
The rep takes the CB and it disappears into the bowels of his firm,
If you can at a later date contact me, I'll test it simple.
Did you do any branch circuit wiring in the house?
Old 05-11-2016, 06:29 PM   #27
Rewards Points: 216
0 branch circuit wiring. I'll contact you.
Sent from my iPhone
Old 05-11-2016, 09:08 PM   #28
Rewards Points: 131
SOP for FDNY is to turn off all circuit breakers when they enter a fire building; most NYC services and disconnects are inside building, no outside service disconnects.
Also, BX is a trade name used for type AC cable and does have the bonding strip in it so the armor can be used as a ground. Some very old BX (like type mentioned in my previous post) did not have the bonding strip in it. The bonding strip provides continuity to the armor and reduces the inductance of the wound armor so shorts like the one noted will trip the fuse/breaker.
Majewski likes this.
khfiei is offline   Reply With Quote
The Following User Says Thank You to khfiei For This Useful Post:
Bad Electrician (05-11-2016)
Old 07-21-2016, 08:37 AM   #29
Rewards Points: 216
Thanks for all the help guys. This thing is finally over, I'm not at fault. I can now breath.
However the homeowner wants me to do all their electrical! Now a new fight begins with the insurance company and getting them to pay.
I was told by the restoration company they're getting over $100k. I gave my measly bid of $5kish to the adjuster and he scoffed and said he thought it wouldn't be more than $2k . What?! Any tips on dealing with the insurance side of things? How do you write a bid/invoice to get paid?
Sent from my iPhone
Old 07-21-2016, 09:02 AM   #30
Rewards Points: 14,083
In my limited experience with insurance companies, your story sounds about right. Insurance companies don't like permits and inspections, they like repair jobs. If the structure was built in the 1940's, they want it fixed so it's compliant with the 1940 code. I did restoration work on an old shack that had smoke damage from a kitchen fire. They stripped the interior down to bare wood for inspection and I wasn't even allowed to add a smoke detector.
Old 07-21-2016, 09:24 AM   #31
Rewards Points: 216
I pulled a permit. They can't get around that.
Sent from my iPhone
Old 07-21-2016, 09:32 AM   #32
sbrn33's Avatar
Just stick to your guns with the with your quote. But make sure you let the owner know you are billing him and not the insurance company. It will be way easier to go after an owner than an insurance agent.
Old 07-21-2016, 09:39 AM   #33
Rewards Points: 127
I'm sure they'd still sue you for not pulling a permit and not bringing the job up to proper standards, if something happens again.
oldblue is offline   Reply With Quote
Old 07-21-2016, 09:44 AM   #34
Rewards Points: 1,275
Yup, and make it clear that your payment is due on completion of the work, not 5 months later when the insurance company finally sends the check.
sbrn33 and Majewski like this.
Majewski (07-21-2016)
Old 07-21-2016, 10:00 AM   #35
I checked with the AHJ and repair jobs don't need a permit. They didn't like it and I didn't like it. I'm not getting involved in that kind of garbage again.
Old 07-21-2016, 10:30 AM   #36
sbrn33's Avatar
Around here it would need a permit just to get power turned back on.
HackWork and Majewski like this.
Old 07-21-2016, 10:32 AM   #37
Rewards Points: 216
Yep here too.
Sent from my iPhone
Old 07-21-2016, 10:39 AM   #38
Come to think of it, they allowed me a permit only to restore power. It was during my early days of being in business. Today, I would have walked away. Really sketchy and I would be extremely reluctant to do any more insurance work.
Old 07-21-2016, 11:49 AM   #39
Rewards Points: 131
Around here, we work for and get paid by the restoration company. They, like any general contractor will squeeze you for any penny they can and tell you to restore to the previous condition, even though its not up to current code. If the restoration, repair, whatever, is a gut, we're required to do all the wiring to current code (they just don't want to hear that because it effects their profit).
Old 07-21-2016, 07:31 PM   #40
220/221's Avatar
Rewards Points: 4,110
. I'm just curious as to why the breaker didn't trip.. .
Well, a toaster doesn't trip a breaker
It doesn't take 20+ amps to get something red hot.
