Fire stop foam - Electrician Talk - Professional Electrical Contractors Forum
Like Tree18Likes
Old 11-09-2017, 05:37 PM   #1
WronGun's Avatar
Rewards Points: 676
Default Fire stop foam
These bottles are great and worthless at the same time.
Sometimes you need to fill in 2 small holes for inspection and then junk the whole bottle.
I tried to use a bottle for the second time today which still had 95% fill... it ended up everywhere a total mess... amazingly it did the job but barely..
Am I missing something here ? There has got to be a better way...
Old 11-09-2017, 05:48 PM   #2
Rewards Points: 26,360
There are many tricks -- recorded on YouTube -- to save partial cans.
You might also look into purchasing fire stop as PUTTY PADS.
They are perfect for tiny holes.
Old 11-09-2017, 05:53 PM   #3
WronGun's Avatar
Rewards Points: 676
The pads are great , but wouldn’t be efficient for some jobs. I’ll check out the videos
Old 11-09-2017, 06:38 PM   #4
trentonmakes's Avatar
Rewards Points: 138
Theres caulking tubes of firestop
Texting and Driving
The Following User Says Thank You to trentonmakes For This Useful Post:
WronGun (11-09-2017)
Old 11-09-2017, 06:56 PM   #5
Rewards Points: 760
@WronGun, did you ever try the putty sticks? You can buy it in bricks like duct seal or packages that look like big sausages. I only use the pads for wrapping boxes in a firewall.
If I wanted it tomorrow I would have called you tomorrow, I want it TODAY
Old 11-09-2017, 10:20 PM   #6
Retired Account
Rewards Points: 14,650
For anyone who's seen a fire take out something substantial, some sealant is a rather dubious remedy
Old 11-09-2017, 10:21 PM   #7
WronGun's Avatar
Rewards Points: 676
Texting and Driving
I’m going to buy this next
Old 11-09-2017, 10:39 PM   #8
Retired Account
this thread needs 334.80 input
Old 11-10-2017, 01:47 AM   #9
Rewards Points: 21,836
Spray bottle or spray can ?? normally I used fireproof chalking in chalk gun that useally last longer and you can seal up the tip with etape and when you need it just peel it off and off you go with it.
active1 and glen1971 like this.
Old 11-10-2017, 09:27 AM   #10
Rewards Points: 3,928
I've spun a marrette on the end and taped it as well..
frenchelectrican and telsa like this.
Old 11-10-2017, 02:25 PM   #11
Rewards Points: 26
We get the fire rated foam for the re-usable guns. They have a knob you turn to shut the air off to the cans.
Sent from my XT1080 using Tapatalk
WIsparky71 is offline   Reply With Quote
Old 11-10-2017, 02:32 PM   #12
StriickeN's Avatar
Rewards Points: 204
The re-usable guns with the disposable tips and a can of cleaner work perfectly.
Speedy Petey likes this.
StriickeN is offline   Reply With Quote
Old 11-11-2017, 12:43 AM   #13
AlmostPro's Avatar
Rewards Points: 142
The job I'm currently on doesn't allow the use of fireblock foam. Just fire caulk, it gets messy and spendy when the sheet rocks decide to leave a giant hole around Smurf/conduit/wires.
AlmostPro is offline   Reply With Quote
Old 11-11-2017, 02:46 AM   #14
Rewards Points: 17,667
The fire stop foam cans make short sweet work of the penetrations above the ceiling tile into and out of tenant spaces. Love the stuff better than plain old expanding foam. And so do electrical inspectors during open ceiling inspections. After seeing that they leave you alone pretty much.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 11-11-2017, 08:24 AM   #15
Speedy Petey's Avatar
Rewards Points: 584
If that's the case let them close it up with compound.
frenchelectrican likes this.
Old 11-11-2017, 11:43 AM   #16
AlmostPro's Avatar
Rewards Points: 142
Sometimes it's easier to do it yourself and know it's done than waiting and waiting... And waiting for them to do it. Also the company that initially made the whole failed and the GC hired a new company so they don't see it as their problem/priority.
Old 11-11-2017, 12:13 PM   #17
Trained Monkey
TheLivingBubba's Avatar
Rewards Points: 588
I worked for a company that in all contracts would state that the GC was required to fire seal all and everything necessary. They would take some money out of the bid, but the amount of labor time and materials saved was much greater. The GC would just sub it out to a company who would come in for one day a week and just spend that entire day sealing everything.
HackWork for Moderator
~ I believe in Hax ~
TheLivingBubba is online now   Reply With Quote
Old 11-11-2017, 01:46 PM   #18
AlmostPro's Avatar
Rewards Points: 142
The last job the company was on was like that. Why can't it just be a standard?
Old 11-11-2017, 02:38 PM   #19
Professional Nit Picker
manchestersparky's Avatar
Rewards Points: 2,186
It can be a standard- Get your company to include it in all their contracts.
Anything Worth Doing ....
Is Worth Doing Right
Old 11-11-2017, 02:53 PM   #20
Watt Pusher
B-Nabs's Avatar
Rewards Points: 470
Our company always excludes firestopping.
Fire alarm guy hancholo General Electrical Discussion 20 08-01-2017 01:35 PM
Is Progress can fire rated/ John M. General Electrical Discussion 4 04-29-2017 09:19 PM
Got really sick after using fire stop sheets TechieBecky Workplace Safety 13 04-26-2016 01:41 PM
Fire Alarm How To Book LanceBass General Electrical Discussion 19 03-26-2016 05:40 PM
Lunera Recalls LED Lamps Due to Fire, Burn and Electric Shock Hazards guest Recalls, Safety Notices and References 0 01-27-2016 09:28 PM
