First means of disconnect question - Electrician Talk - Professional Electrical Contractors Forum
Old 02-11-2015, 08:41 PM   #1
Rewards Points: 6
Default First means of disconnect question
Can I use 60amp time delay fuses in a knife switch at the first means of disconnect from a 100 amp meter ?
bullet is offline   Reply With Quote
Old 02-11-2015, 08:43 PM   #2
Rewards Points: 6
It's for a commercial outdoor lift station
Old 02-11-2015, 08:44 PM   #3
corn-fused
papaotis's Avatar
Rewards Points: 620
is that what the disconnect is rated for? then yes
Old 02-11-2015, 09:08 PM   #4
Ditch Digging Dummy
3D Electric's Avatar
Rewards Points: 52
I would think you would want to use 100 amp fuses and a knife switch but I am not there to see. So that said it is completely legal here to use the 60 amp fuses and a knife switch.
3D Electric is offline   Reply With Quote
Old 02-11-2015, 09:16 PM   #5
ponyboy's Avatar
Rewards Points: 709
The meter is rated up to 100 amps. Your service can be any size up to that. Your 60 amp disconnect needs to be service rated however
The Following 4 Users Say Thank You to ponyboy For This Useful Post:
3D Electric (02-11-2015), five.five-six (02-11-2015), Rollie73 (02-11-2015), shocksystems (02-11-2015)
Old 02-11-2015, 09:17 PM   #6
Rewards Points: 1,367
So long as the switch will accept those fuses and that fuse size is correct for the ampacity of the wire, then yes.
Old 02-11-2015, 10:01 PM   #7
Rewards Points: 6
Ok yes the switch is service rated.
I know the minimum size for residential service NEC code is 100 amps. Yes the meter is rated 100 amp, the line side of the meter is 100 amp but the load side of the meter is #6's and they feed a knife switch with 60 amp time delay fuses feeding the equipment panel. The minimum 100 amp service was the confusion.
Thanks for the replies.
Old 02-11-2015, 11:08 PM   #8
corn-fused
papaotis's Avatar
Rewards Points: 620
please correct me if im wrong, but anything AFTER the service can be any size under the service size, as long as it israted for what it is being used for?
Locking a means of disconnect five.five-six General Electrical Discussion 4 05-28-2014 11:14 AM
Means of Disconnect issue Magnettica General Electrical Discussion 15 07-31-2013 12:58 PM
Disconnect Question lims640 General Electrical Discussion 25 12-02-2012 12:27 AM
A-C disconnect question CertElectric NEC Code Forum 2 09-01-2011 11:39 PM
Means of Disconnect on Ballast cself123 General Electrical Discussion 18 02-28-2011 10:55 PM
