Fixture Restoration - Electrician Talk - Professional Electrical Contractors Forum
Like Tree2Likes
  • 1 Post By Switched
Old 06-11-2016, 11:35 AM   #1
Switched's Avatar
Rewards Points: 9,230
Default Fixture Restoration
I have a client with a 1920's Spanish home. It has the original outdoor fixtures, which were all wrought iron with mica shades.
The fixtures are in fairly good condition but of course the mica is toast on all but one. Has anyone ever tried installing new mica to a cylindrical style fixture?
We will more than likely send them out to a specialist, just thought I would see if anyone has done it.
Old 06-11-2016, 02:59 PM   #2
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
No idea but I'd love to see before and after pictures.
Old 06-12-2016, 02:42 AM   #3
Rewards Points: 1,508
Ditto !
Old 06-12-2016, 02:44 AM   #4
Have you tried posting this question in the vintage electrical section ?
Old 06-12-2016, 03:43 AM   #5
MikeFL's Avatar
Rewards Points: 600
You can buy mica sheet
https://www.google.com/search?q=mica...h&q=mica+sheet
Michael Gookin, President
GPS Timers
(833) GPS-TIME
Old 06-12-2016, 11:23 AM   #6
Switched's Avatar
Originally Posted by MikeFL View Post
Yeah I googled that too... It seems you can heat it up in an oven and form it to a shape pretty easily. Might be worth it to try a few out, maybe when I am finally broken I can sit in my wheelchair and repair old fixtures!
Majewski likes this.
Old 06-12-2016, 02:58 PM   #7
Majewski's Avatar
Soon then? I kid I kid.
Old 06-12-2016, 03:16 PM   #8
Switched's Avatar
I am probably closer to it than I want to admit.... Suppose I should take up surfing so I can be a beast like Mike!
Old 06-12-2016, 03:19 PM   #9
Majewski's Avatar
Admit nothing!
Old 06-12-2016, 03:46 PM   #10
MikeFL's Avatar
Rewards Points: 600
We do production bending using heat and it's my experience that you're going to need two forms, one for the inside radius of the mica and one for the outside radius of the mica. What you're going to have to experiment with is spring back. The longer you let it cool, the less spring back you get. If it ever heats back up, it will want to restore the original shape. Another option, and I don't know what your fixtures look like, is that if the fixture can be used as the jig, you may not need to make any forms. Or maybe the fixture can be half of the jig (one form) and make something to hold the mica in the fixture while it cools.
Can you post a picture, or several pictures showing different angles, of one of the fixtures?
Sounds like a fun project but I don't know what kind of money the owner is willing to spend. Sounds like they prefer restoration over replacement so there has to be some kind of reasonable budget.
How many fixtures? Maybe you can make your wages on volume to offset the setup time.
GPS Timers
(833) GPS-TIME
Old 06-13-2016, 01:14 AM   #11
Rewards Points: 44
What area are you in ?
If your in the jersey area there is a lamp shop in Medford NJ that specializes in restoration.
FF301 is offline   Reply With Quote
Old 06-13-2016, 02:20 AM   #12
Switched's Avatar
The fixture are cylindrical, so I think if you heated the mica up you would need and interior form, but the exterior would be the fixture itself. I would assume also that any spring back would be beneficial do to the design.
I think I'll try a couple and if it doesn't work I'll send them out.
Old 06-13-2016, 03:08 AM   #13
MikeFL's Avatar
Rewards Points: 600
The circumference of the circle is the length of the sheet.
( 2 * pi * radius ) or ( pi * diameter )
Can you tell how tight the old ones fit? Did they leave an 1/8" for expansion?
Too loose and it may rattle. Too tight and it may warp or crack.
It should be a fun experiment.
GPS Timers
(833) GPS-TIME
Bathroom mirror -- light fixture Spark Master Residential Electrical Forum 16 08-22-2016 09:26 PM
commercial gear and fixture mark ups texasjourneyman2323 General Electrical Discussion 6 05-18-2016 02:14 PM
Looking for a fixture type wy2ak Lighting Design 9 04-14-2016 12:39 AM
SO cord for fixture whips? Derek1 NEC Code Forum 14 03-06-2016 05:50 PM
Preferred fixture type over sink with valance. sayn3ver Lighting Design 3 02-14-2016 10:06 AM
