Flashing Sign - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 1 Post By frenchelectrican
  • 1 Post By A Little Short
Old 09-30-2016, 10:27 PM   #1
A Little Short's Avatar
Rewards Points: 966
Default Flashing Sign
I've been asked to look at one of those "flashing arrow" signs you see on the road front in front of businesses. I guess they are called portable signs, IDK, I'm not a sign guy.
Anyway, what is in there, just bulbs and a flasher?
More than one flasher?
Bulbs with internal flasher?
As you can see, I know nothing about them but it's for a good customer so I said I would look at it. Seems just part of it is flashing so I don't know if it's bulbs, flashers, control box?
Any help here?
Old 09-30-2016, 10:45 PM   #2
Rewards Points: 21,884
Any help here?
If you do have flashing arrow type with about 8 to 12 bulbs in there that useally have a flasher or altenrnating relay to alternate the flashing depending on type of sign it have.,,
most portable verison do have floursecent lamps typically four or six footer is most common AFAIK but once a while you will hit 8 footer flourscent lamps and typically they are High Output verioson but yes they can have VHO verison too so just be aware of that.
the flasher useally can be either electronic or motor driven flasher some case it called mechichal flasher.
Majewski likes this.
A Little Short (09-30-2016)
Old 09-30-2016, 11:19 PM   #3
Rewards Points: 966
The lights appear to be round/incandescent bulbs. I haven't looked closely, just saw it from a distance and saw some lights not working at all and others not flashing.
Old 09-30-2016, 11:28 PM   #4
Ahh a common one .,, the flasher useally be inside of the sign panel useally near the point where the power conductor go in the sign lumiaire is .,,
this is the type of flashing sign or differnt style.
Keep in your mind that sign can have flashing arrow or constant on.
Old 10-01-2016, 12:07 AM   #5
Rewards Points: 966
http://http://www.cotteradvertising....delA1_400w.gif
Your link didn't work.
frenchelectrican likes this.
The Following User Says Thank You to A Little Short For This Useful Post:
frenchelectrican (10-01-2016)
Old 10-01-2016, 12:10 AM   #6
corn-fused
papaotis's Avatar
Rewards Points: 620
certainly not the expert, but many of those older signs have pretty common bulbs and you may only need to change them.
Old 10-01-2016, 12:30 AM   #7
Most common is 60 or 100 W A21 bulb type useally a buglight or yellow sign bulb but somecase traffic light bulb work well too. ( most are 120 Volts )
papaotis likes this.
Sucky Magnetic Sign Tiger General Electrical Discussion 21 08-31-2016 09:44 PM
Neon Sign in Residential Dwelling Unit A6USMC Residential Electrical Forum 20 03-10-2016 03:18 PM
Subway sign ballast psd7.3 General Electrical Discussion 14 01-04-2016 11:53 AM
