Flatwire? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree32Likes
Old 05-07-2016, 04:55 PM   #21
Rewards Points: 864
To clarify it wasn't buried under Sheetrock mud though.
Pride is doing what you know is right especially when no one else is looking.
Sparky J is offline   Reply With Quote
Old 05-08-2016, 01:25 AM   #22
Rewards Points: 131
Interesting that the installer doesn't know hoe to use a (plastic) trowel.
Majewski likes this.
khfiei is offline   Reply With Quote
Old 05-08-2016, 05:57 AM   #23
I'm going to wire my whole house in flatwire! Have you ever played the game operation?
Coreythesparky is offline   Reply With Quote
Old 05-08-2016, 05:58 AM   #24
Don't touch the walls!
Old 05-08-2016, 05:25 PM   #25
Rewards Points: 1,539
That is Low Voltage Right ?
Don
donaldelectrician is offline   Reply With Quote
Old 05-08-2016, 06:28 PM   #26
Rewards Points: 1,224
Originally Posted by Sparky J View Post
Interesting I've seen flat wire product similar to the shown product (I think it was like 15 years ago) used under carpet squares in a sprint store for power to a kiosk. This was some sort of wiremold product IIRC. I was sent by a company I worked for at the time to terminate both ends. But boss man had used it, was familiar with it, and said hook it up for client.
That is type FCC cable covered by Article 324. It has a grounded metal cover over the top of the conductor cable. The cover was heavy enough to prevent most damage to the actual conductors. I did one install using the product and was made by Wiremold. It worked well for an open office layout, and they also had flat phone and data cables so you could get everything you need to a desk that was not near a wall.
The product in the video is a concealable non-metallic extension.
382.2 Definitions
Concealable Nonmetallic Extension. A listed assembly of two, three, or four insulated circuit conductors within a nonmetallic jacket, an extruded thermoplastic covering, or a sealed nonmetallic covering. The classification includes surface extensions intended for mounting directly on the surface of walls or ceilings, and concealed with paint, texture, joint compound, plaster, wallpaper, tile, wall paneling, or other similar materials.
The product is in the UL White Book under "Concealable Nonmetallic Extension (PXYC) and the white book says the following:
This category covers assemblies of two, three or four insulated circuit conductors within a nonmetallic jacket, an extruded thermoplastic covering, or a sealed nonmetallic covering. These assemblies are intended for installation in accordance with Article 382 of ANSI/NFPA 70, "National Electrical Code." These conductors are intended to be mounted directly on the surface of walls or ceilings, and concealed with paint, texture, joint compound, plaster, wallpaper, tile, wall paneling, or similar finish materials.
Concealable nonmetallic extensions of a multilayer flat conductor design, including one or more ungrounded conductors enclosed by a layer of ground conductors (inner sectioned layers), and an overall layer of ground conductors (outer sectioned layers). All flat conductors are copper and are equivalent to 14 AWG or 12 AWG conductor sizes. The starting/source tap device for the extension provides the following protection for all load-side extensions and devices:
1. Supplementary overcurrent protection
2. Level of protection equivalent to a Class A GFCI
3. Level of protection equivalent to a portable GFCI
4. Line and load-side miswire protection
5. Protection from the effects of arc faults
There is one company, Nexovation, INC. that has a product listed to this standard.
chicken steve likes this.
The Following 2 Users Say Thank You to don_resqcapt19 For This Useful Post:
donaldelectrician (05-09-2016), FaultCurrent (05-10-2016)
Old 05-09-2016, 09:44 AM   #27
Rewards Points: 22
I've used flatwire in commercial applications. 120v. It is a fairly simple and clean installation.
You lay a rubber vapor barrier down on the concrete floor and tape it down. You lay your flat wire out and tape it down. You then install thin sheet metal on top of the wire and vapor barrier, and then tape that down.
Bases for receps are installed under the wire (so it can be one long continuous piece) and then carpet is laid down. The floor guys cut out around the recep bases and you just screw the recep down onto the base. Everything is proprietary and designed for the application.
It gives a nice clean look and still allows stuff to be powered without power poles everywhere.
cagresham85 is offline   Reply With Quote
Old 05-09-2016, 11:12 PM   #28
The carpet must be carpet squares no more than one meter square.
donaldelectrician likes this.
Old 05-09-2016, 11:30 PM   #29
Originally Posted by Majewski View Post
Am I last to learn of this? How interesting......
https://m.youtube.com/watch?feature=...&v=C-u_tFtPdaU
I'm thinking of troubleshooting issues and thinking it would be a pita.
No , I am the last to learn . Under Carpet , I have worked with many
moons ago . Never seen that , and not interested .
Looks like a way way longer install and finish process than simple fishing
procedures . Way more $$$$ .
Hope some one later hangs a picture ... I do not like it .
Are they going to paint the whole wall or room ? Spot paint ?
This product is listed , I just back read some post ... GFCI will not
make it better. The AFCI people must have a hand in this .
Don
chicken steve and Majewski like this.
Old 05-10-2016, 12:20 AM   #30
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,774
Those pesky AFCI people are the root of all evil.
Old 05-10-2016, 06:47 AM   #31
Retired Account
Rewards Points: 14,650
I shoulda been a plumber , at least their products are manufactured to be full o' s%$t....~CS~
Majewski and cagresham85 like this.
Old 05-10-2016, 08:36 AM   #32
Rewards Points: 22
Yes sir. Pretty much every commercial job I go to the carpet tiles are about 2' square or maybe 3' square.
I've never been on a job where they used rolls of carpet. Tiles all the way.
Old 05-10-2016, 09:44 AM   #33
[quote=donaldelectrician;2786378...
make it better. ...
Don[/quote]
The circuit conductors are sandwiched between two outer copper sheets, the GFCI protection is part of the listed system, and is to de-energize the flat conductor when someone drives a nail into it.
