Flexible non metallic conduit - Electrician Talk - Professional Electrical Contractors Forum
Like Tree7Likes
  • 3 Post By RePhase277
  • 2 Post By PlugsAndLights
Old 04-05-2017, 10:37 PM   #1
Rewards Points: 8
Default Flexible non metallic conduit
Im in a jam and was hoping someone could help? I want to get this job done in a day (tomorrow of course )
I have to feed 2 condensers on the roof of a shopping mall. I will be running the feeders through a ventilation shaft that is used for supply air to the main electrical vault. I was planning to run teck from the disconnects on the units, down the shaft (with jacket removed) and into the vault, junction box, and bx the rest of the way to the panel.
Instead, could I run "tough tube" down the shaft? We have a ton at the shop and I want to use it but Im getting mixed answers from everyone. Help! I know answers may vary depending on jurisdictions etc.
Canadian Electrical Code, BC
https://ontario.westburne.ca/medias/...263_144_en.pdf
I cant find anything telling me I cant! LOL
Thank you very much
DoubleAction is offline   Reply With Quote
Old 04-05-2017, 10:46 PM   #2
Rewards Points: 1,360
I don't think I would run anything in there wasn't plenum rated. Does that matter in Canada?
The Following 2 Users Say Thank You to RePhase277 For This Useful Post:
DoubleAction (04-05-2017), MechanicalDVR (04-06-2017)
Old 04-05-2017, 10:51 PM   #3
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
No. Liqudtite is not suitable for this use.
code ref 12-1302.
P&L
Old 04-05-2017, 11:06 PM   #4
Rewards Points: 8
Thanks P&L
Is that based on sub rule 1?
Old 04-05-2017, 11:14 PM   #5
Safety Pin Member
Originally Posted by DoubleAction View Post
Thanks P&L
sub 1,2&3 are all suggesting that the intended/allowed use is as
a flexible connection to a load. For instance, from a disconnect to
an A/C unit. Not as a general use conduit.
You're Welcome,
P&L
BTW, the CEC section is the best place for Canadian rules.
Bird dog and DoubleAction like this.
Old 04-05-2017, 11:47 PM   #6
Rewards Points: 3,986
Thank you very much
Why take the rubber jacket off the cable? Is there no other way to install this than the plenum?
code ref 12-1302.
P&L
I'm assuming you're referring to the "tough tube" (liquid tight) option?
I didn't see where you couldn't run teck, since it is FT4 rated, but I'm not sure how it could be firestopped at each end properly... I'd be looking at an alternate route..
Old 04-06-2017, 12:59 AM   #7
Thank you very much
So by "tough tube" I am assuming this is the trade slang up there for "flexible non metallic tubing / conduit" eh?
We call that "smurf tube" down here. I'm not familiar with Canadian Code but I'm pretty sure the NEC doesn't allow FNMC in ventilation shafts.
I'd be trying to find a better way to do the job. Is EMT out of the question? At least for the portion where it is in the ventilation shaft?
Patriot1776 is offline   Reply With Quote
Old 04-07-2017, 12:46 AM   #8
Rewards Points: 8
Jobs done! I'm asking for an apprentice next time, I'm beat. Yes the plenum was the only option. I used teck. I'm trying to stick to the job as quoted, which my boss says I should do more often
Old 04-07-2017, 09:04 AM   #9
But why strip off the outer jacket? How did you seal the duct openings where the cable came out?
Suspending security camera from conduit ElectMe NEC Code Forum 8 02-19-2017 05:20 PM
Spa conduit emerging in the pad. Kaffeene General Electrical Discussion 4 12-10-2016 10:16 PM
PV conduit inside exterior wall permitted? katwalatapan Alternative Energy Forum 11 12-05-2016 01:09 PM
Getting the most from an existing U/G conduit Gaussios Residential Electrical Forum 16 04-25-2016 11:11 PM
locating conduit or LV cable behind wall or missing conduit end? lortech Structured Wiring 3 01-18-2016 01:35 PM
