Flickering lights with dimmers set at certain points - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
  • 2 Post By mike9666
  • 7 Post By Semi-Ret Electrician
  • 1 Post By frenchelectrican
  • 1 Post By MechanicalDVR
Old 11-02-2016, 09:29 AM   #1
Rewards Points: 126
Default Flickering lights with dimmers set at certain points
Stumbled upon a weird call back. 3 light fixtures in the kitch/dining, 2 of them are LED on their own dimmer (LED compatable) The other one is an incandescent on its own dimmer (non LED comp.)
All dim properly on their own, but when you set the incandescent fixture to just below full and then set one of the LED dimmers to near the middle the LED flickers like a strobe. But then if you adjust the incand. or the LED dimmer at all everything is working normal.
Has to be a bad dimmer, kind of thinking the one not compatable with LED, but has anyone run into this issue before??
mike9666 is offline   Reply With Quote
Old 11-02-2016, 10:04 AM   #2
Rewards Points: 98
I had something similar happen 1st time with maestro (lutron) dimmers. They need to be programmed. What dimmers are you using?
350X is offline   Reply With Quote
Old 11-02-2016, 06:33 PM   #3
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 766
Did you adjust the pot on the side of the switch or program the lutron as 350X mentioned?
Also check the brand out, they may have issues with certain dimmers- I know that Lutron Casta switches do. Lol.
The_Modifier is online now   Reply With Quote
Old 11-03-2016, 12:20 AM   #4
Rewards Points: 126
Damn,
i didn't think to look at the brand, the customer had bought them... (first mistake) probably the cheapest dimmer out there.
I just adjusted the pot, didn't program anything.
Old 01-08-2017, 10:22 PM   #5
Rewards Points: 45
did you figure this out yet? could be a shared neutral problem.
arthur is offline   Reply With Quote
Old 01-08-2017, 10:50 PM   #6
Semi-Ret Electrician's Avatar
Rewards Points: 486
If the LED load is very low (10 or 20W) don't put it on a 600W dimmer. Use a 150W dimmer or it will strobe.
The Following 2 Users Say Thank You to Semi-Ret Electrician For This Useful Post:
MechanicalDVR (01-09-2017), telsa (01-09-2017)
Old 01-08-2017, 11:33 PM   #7
Rewards Points: 21,898
That what I learn that trick not too long ago in my island area due we do use alot of LED's..
Ya if you use too large a dimmer some do have a minuim load to get it working properly.
Majewski likes this.
Old 01-09-2017, 03:15 AM   #8
Rewards Points: 24,458
Great info.
Points per circuit (LED's) meggerman Canadian Electrical Forum 36 08-23-2016 07:27 PM
Flickering lights turn off/on futureairways General Electrical Discussion 5 06-15-2016 05:53 PM
Removing unwanted recessed lights. Woodman General Electrical Discussion 4 05-03-2016 03:56 PM
Dimming LED Lights power General Electrical Discussion 8 04-01-2016 07:06 PM
Flickering lights at my palatial estate... guest Residential Electrical Forum 21 03-04-2016 05:06 AM
