Floor box, warehouse, forklift - Electrician Talk - Professional Electrical Contractors Forum
Like Tree15Likes
  • 3 Post By Incognito
  • 2 Post By Jlarson
  • 2 Post By Incognito
  • 2 Post By splatz
  • 1 Post By CoolWill
  • 1 Post By HackWork
  • 1 Post By stiffneck
  • 1 Post By macmikeman
  • 1 Post By mofos be cray
Old 09-27-2019, 06:37 PM   #1
Rewards Points: 2,827
Default Floor box, warehouse, forklift
I want to put a splice box in a warehouse floor that has forklift traffic. What can I use? Ipex makes a highway box for vehicular traffic but I can’t wait for delivery.
Old 09-27-2019, 06:46 PM   #2
RSE Master Electrician
Incognito's Avatar
Rewards Points: 954
Forklifts are very heavy. I would wait for the highway box.
splatz, Bird dog and stiffneck like this.
2018 Canadian Electrical Code
Old 09-27-2019, 06:50 PM   #3
Gouging Profiteer
Rewards Points: 797
Forklifts have a lot of counterweight on the back, but often only have little (and hard) wheels.
I would be worried about doing this myself. Is someone else doing the concrete work? No one engineered this work and speced a box?
Old 09-27-2019, 06:59 PM   #4
Jlarson's Avatar
Rewards Points: 4,290
Wait for something traffic rated. Needs a flush, bolted lid too so it doesn't get fubared.
splatz and stiffneck like this.
Old 09-27-2019, 07:21 PM   #5
Incognito's Avatar
Rewards Points: 954
Or maybe have the box lower than the floor a little and put a cover over it? Like a metal plate or something?
99cents and CoolWill like this.
Old 09-27-2019, 07:44 PM   #6
Rewards Points: 2,782
There are lots of floor boxes suitably rated, try different manufacturers.
https://fsrinc.com/documents/spec-sh...sheet-pdf/file
I have seen people screw up the layout and put regular floorboxes where the forklifts run over them. Quickly mangled, safety issue, no good.
telsa and stiffneck like this.
The more you know, the less you need.
Old 09-27-2019, 08:04 PM   #7
Knotted Ropes Skeery
CoolWill's Avatar
Rewards Points: 1,652
Over cut the hole and leave a lip above the box. Cover it with 3/8" steel plate.
Old 09-27-2019, 08:05 PM   #8
CoolWill's Avatar
Engineered
99cents likes this.
Old 09-27-2019, 08:15 PM   #9
Yes, I was thinking the same thing. Power is down and temperatures are going below freezing. I scraped ice off the windshield this morning.
Old 09-27-2019, 08:17 PM   #10
Why would I want something that a techy found with Google?
Old 09-27-2019, 08:19 PM   #11
Gouging Profiteer
Rewards Points: 797
So it’s someone else’s liability.
stiffneck likes this.
Old 09-27-2019, 08:23 PM   #12
stiffneck's Avatar
Rewards Points: 1,346
I'm just old enough to remember when guys at plants "fabricated" just about anything out of steel. But those days are over. If you install something that's lacking a "rating" and it fails, causing injury or worse. You asx is going to be on fire, with your head catching as your insurance company has to deal with the fall out. Today's speedy delivery will get you what you need. Buy it off the shelf with a RATING on it, whatever the need might be.
In Bred Electrical Worker
Old 09-27-2019, 08:24 PM   #13
If you want to get arts and craftsy you could use a road rated handhole, and install your box inside the handhole. The handhole wouldn't be an electrical vault, you'd be using it like a sleeve around the conduit and box.
http://www.concastinc.com/hand_holes...ated/index.php
The suppliers that sell to highway contractors and precast plants may have these locally.
Old 09-27-2019, 08:33 PM   #14
stiffneck's Avatar
We've done this at the Airport, which includes areas where Aircraft taxi(drive) over.
Old 09-27-2019, 11:58 PM   #15
Rewards Points: 21,531
There are times when a forklift can be way heaver than a forklift. How much load on the lift during delivery has to be taken into consideration also.
The recess box with a steel plate is the best suggestion so far. And make sure you get a CSA sticker on it if there is more than two wire nuts involved.
I stand with Tucker Carlson
Old 09-28-2019, 12:06 AM   #16
Incognito's Avatar
Rewards Points: 954
Um, we use marrettes, not wire nuts.
Old 09-28-2019, 01:32 AM   #17
Well yes, but down here in the south we are real men. So we have nuts.
Waj you call that girly thing again? Serviettes?
Incognito likes this.
Old 09-28-2019, 02:10 AM   #18
Rewards Points: 18
This forum needs a like button cause that **** is funny.
batwing44 likes this.
mofos be cray is offline   Reply With Quote
The Following User Says Thank You to mofos be cray For This Useful Post:
batwing44 (09-28-2019)
