In-floor heating thermostat / sensor question - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree12Likes
Old 02-16-2018, 09:45 AM   #21
sbrn33's Avatar
Rewards Points: 3,634
Okay, if the OP's sensor is shot, what's the option besides besides the rheostat? If he put a new sensor in the wall it might work, it would just have a different reference point.
You pull off the baseboard, chip out some tile and install a new one. Caulk it back in and tell them to get a tile guy.
He should feel lucky he didn't supply any of the components.
Old 02-16-2018, 09:50 AM   #22
Rewards Points: 3,335
I guess if you had a big enough grout line, you could do it with no tile damage.
Old 02-16-2018, 09:51 AM   #23
Rewards Points: 2,414
Firstly, are you sure the first T-stat was bad? If it has gfci built in as most do then it could be that the gfci needs to be reset.
Measure the resistance of the load and maybe there is some info around that has that info.
Also depending on how the sensor was installed you may be able to just slide a new sensor down the pipe which would get it close to the floor. We always sleeve the sensor in conduit so that the sensor can be reinserted. I believe some manufacturers will sell you a conduit made for that purpose
I can't help it if I'm lucky
Old 02-16-2018, 10:20 AM   #24
Rewards Points: 3,084
I would think you could probably hack up some way to surface mount the sensor in an out of the way spot, but that might be more trouble than identifying a compatible thermostat since it sounds to me like the thermostat is OK.
#HACKLIVESMATTER
Old 02-16-2018, 03:50 PM   #25
Islander's Avatar
Rewards Points: 630
Thanks to everyone for your responses.
I finally called the folks who manufactured the replacement thermostat (True Comfort). They were baffled that the thermostat would even show that low of a temperature. However, they did provide a solution to the problem that would avoid the complications of installing a new sensor. There are four settings for how to control the temperature, and one of them is "Room". Basically, it ignores the sensor entirely, and adjusts the power to the cable based upon room temperature only.
The install pages I had on site made no mention of that, but their online guide does.
Problem (hopefully) solved.
Downside: the bathroom door would have to be kept closed, or the flooring will try to heat the entire lower floor. At 250 watts (it's a small bathroom), it would have its work cut out for it.
Get me a wire stretcher, a stainless steel magnet, and a skyhook.... STAT!
Islander is offline   Reply With Quote
Old 02-17-2018, 08:10 AM   #26
Rewards Points: 20
Maybe a timer ahead of it to limit the times of the day it operates. Morning wake up to get ready for the day and any other appropriate times.
Sent from my Z851M using Tapatalk
FWW56 is offline   Reply With Quote
Garage heater thermostat NFS General Electrical Discussion 4 11-04-2017 10:19 PM
Thermostat help NYelectric25 General Electrical Discussion 20 10-20-2017 07:51 PM
Nest thermostat wreaking havoc - buzzing relay, anyone else seen this? alexbc General Electrical Discussion 39 07-25-2017 07:15 AM
Installing a double pole thermostat to 2 heaters smh382 General Electrical Discussion 2 12-28-2016 06:56 PM
Line Voltage Thermostat with Terminals splatz Residential Electrical Forum 7 04-10-2016 05:11 PM
