Floor Tile heat - Electrician Talk - Professional Electrical Contractors Forum
Like Tree3Likes
  • 1 Post By The_Modifier
  • 1 Post By PlugsAndLights
  • 1 Post By macmikeman
Old 11-01-2016, 09:02 PM   #1
Rewards Points: 3,006
Default Floor Tile heat
Customer says tile heat does not work in bathroom I dont see a temperature sensor wire like nu heat has. all that is in the box is 2 single conductor shielded cables and connected to a slide with on off button at the bottom light dimmer . there is no identification label on the shielded conductors.
This is a picture of the working one in the Kitchen
Old 11-01-2016, 10:30 PM   #2
Rewards Points: 14,073
No problem using a dimmer as long as it's within the Watts range. Is the dimmer shot? Short it out and see if the floor gets warm.
Old 11-01-2016, 10:46 PM   #3
wcord's Avatar
Rewards Points: 1,654
some of the first in floor systems were manual control.
Take the dimmer out of the circuit and see if you get a current draw. If so, your wires are okay. If not, well good luck
I would install a temp probe and proper thermostat
Old 11-02-2016, 12:05 PM   #4
Would there be gfci protection then
Old 11-02-2016, 07:28 PM   #5
Electron Pathway Engineer
The_Modifier's Avatar
Rewards Points: 352
By Canadian code yes! The ground fault is at the source (unit, not the cable).
The largest fine was recently handed out by the courts to an Ontario contractor recently for the death of an elderly man who fell in the bathroom.
Some of the thermostats (assuming thats what you meant by "dimmer") are atmospherically controlled and don't require the in floor unit.
Take a resistance reading of the leads to the floor heat and also a thermal image of the floor.
The sticker for the cable may have not been pulled into the box. You can get a rough idea of the resistance by looking online and the general sq footage of the area.
PlugsAndLights likes this.
Old 11-02-2016, 07:38 PM   #6
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
Yep. That fine was over $500k. Consider liability while deciding how to fix
this.
P&L
The_Modifier likes this.
Old 11-02-2016, 11:30 PM   #7
Rewards Points: 14
Lol
I'd run
west shore electric is offline   Reply With Quote
Old 11-02-2016, 11:34 PM   #8
Rewards Points: 18,165
Bam! Red Tag! I'm hoping to get a side job as a mounty also. Then there won't be a safe place in the whole Northwest Territories for anybody using unlisted ty raps, or puttin in some no gfi bathroom floor heating. A mounty always gets his *
*word deleted so as not to offend any sensitive college students.
Majewski likes this.
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Quoting Roof Heat Tape shocksystems Business, Marketing, and Sales 14 10-05-2016 05:58 PM
Heat Pump Question power General Electrical Discussion 7 10-05-2016 12:58 PM
Cracked Heat Exchanger Dispute power Off Topic (Non Trade) 27 09-23-2016 01:07 AM
Heat pump 40A? The.Juggernaut Canadian Electrical Forum 61 07-15-2016 05:04 PM
Electric heat for log home Grogan14 Residential Electrical Forum 7 03-13-2016 08:15 PM
