frequency - Electrician Talk - Professional Electrical Contractors Forum
Like Tree12Likes
  • 2 Post By Helmut
  • 2 Post By emtnut
  • 6 Post By micromind
  • 1 Post By oliquir
  • 1 Post By Frank Mc
Old 12-19-2016, 04:47 PM   #1
Rewards Points: 680
Default frequency
what would happen if a 25 cycle transformer is hooked up to 60 cycles?
circuitman1 is offline   Reply With Quote
Old 12-19-2016, 04:56 PM   #2
Cl906um's Avatar
Rewards Points: 1,206
Don't think it would work very efficiently. The core needs to be heavier on lower frequencies.
Old 12-19-2016, 04:57 PM   #3
Rewards Points: 2,088
would probably work ok but may not deliver full power capacity, if you do the inverse (connect a 60hz to 25hz) it will make the transformer overheat
Old 12-19-2016, 05:37 PM   #4
Cl906um's Avatar
Sorry, think I dislecsicked that. Dislexic? Won't fix my spelling on that one. Oh well. Think you can put higher on lower rated transformer.
Old 12-19-2016, 05:37 PM   #5
Rewards Points: 26,780
It won't protest.
Old 12-19-2016, 05:42 PM   #6
German Spy
Helmut's Avatar
Rewards Points: 4,361
It would probably go twice as fast.
Mike_kilroy and Cl906um like this.
Old 12-19-2016, 05:46 PM   #7
Cl906um's Avatar
More than meets the eye. .. Robots in disguise..
Old 12-19-2016, 05:52 PM   #8
Band Member
emtnut's Avatar
Rewards Points: 2,146
Their will be a huge build up of flux, and the toilets will flush counterclockwise for a 6 - 7 mile radius
Frank Mc and lightman like this.
You should 3D print a toe attachment for your shotgun
Old 12-19-2016, 06:11 PM   #9
Rewards Points: 680
THANKS for the replies! thought it might work ok but not sure.i agree with the 60 to 25 cycles.wouldn't work well. just know about the other way.
Old 12-19-2016, 08:39 PM   #10
Rewards Points: 3,236
Higher frequency = less iron needed.
This is why airplanes use 400HZ. A 10HP motor @ 400HZ is about the size (and weight) of a 2 HP @ 60HZ.
NC Plc (12-20-2016)
Old 12-20-2016, 09:43 AM   #11
thats why they use micro transformers in switching power supply that works in the 10-1000 khz range and can deliver lots of power comparing to 60hz transformers
micromind likes this.
Old 12-21-2016, 03:03 AM   #12
Frank Mc's Avatar
Rewards Points: 860
Hi Micro
Many years ago we were putting in a new ups and switchboard into a place ,they were also installing i think (long time ago) a motor generator set which ran at 400hz. and of course i asked the guy why 400Hz and (if my memory is correct) he replied that if it got a glitch at 400hz it was,nt noticable but at 50Hz it would be....??
Fág an Bealach
Frank Mc is offline   Reply With Quote
Excessively hot 160kW motor Electrorecycler PLCs, VFDs, Motors and Controls 29 06-07-2017 03:03 PM
VFD feedback Sparky Mcgregor PLCs, VFDs, Motors and Controls 15 12-29-2016 08:35 AM
Help with a lenze 8200 SMD Frequency inverter roboticbebop General Electrical Discussion 4 10-05-2016 02:37 PM
Analog output as frequency reference for a second drive Cano PLCs, VFDs, Motors and Controls 5 03-09-2016 10:43 PM
Advantage/Disadvantage of 220V/50Hz and 110/60Hz? thanhvu94 Residential Electrical Forum 19 02-23-2016 03:00 PM
