Fuel stop solenoid WOODWARD - Electrician Talk - Professional Electrical Contractors Forum
Like Tree12Likes
Old 12-21-2016, 02:22 AM   #1
Rewards Points: 12
Default Fuel stop solenoid WOODWARD
Hi again!
Today i have something that really confused me, whcih is solenoid fuel stop. It pulls and holds, but the thing is it gets hot. I dont know if this is normal, but the wiring was newly made according to this diagram. Is it really supposed to get hot ( 1 hour hold but still holdable with my hand)
Thank you
Sent from my MI 5 using Tapatalk
JBoen is offline   Reply With Quote
Old 12-21-2016, 03:55 AM   #2
Rewards Points: 26,746
It's idiot easy to check out the circuit.
1) Identify '30' and '87' -- these will be marked on the under belly of the relay, which you must remove.
2) Noting the corresponding female connections, jack in a DC ammeter.
Don't turn anything on... don't attempt to start the motor.
Just right there you've got the amount of amps flowing into the solenoid -- which will pull up the second you jack a DC ammeter across 30 & 87.
3) Remove your ammeter and restore the relay.
Majewski likes this.
Old 12-21-2016, 04:04 AM   #3
Rewards Points: 12
But the thing is solenoid gets hot when it holds, is that normal? Just as hot as your smartphone while playing some games.
Old 12-21-2016, 03:41 PM   #4
Rewards Points: 36
Yes, that is normal. The DC coil has to use resistance to limit the current and that generates heat.
Sent from my XT1585 using Tapatalk
Flyingsod, JBoen and MCasey like this.
inetdog is offline   Reply With Quote
Old 12-21-2016, 05:18 PM   #5
Rewards Points: 1,536
Wouldn't a solenoid be a primarily inductive load?
Old 12-21-2016, 06:33 PM   #6
Rewards Points: 36
And a pure inductor offers no impedance to DC.
An AC solenoid can use inductance to limit current.
PlugsAndLights likes this.
The Following User Says Thank You to inetdog For This Useful Post:
splatz (12-26-2016)
Old 12-21-2016, 07:32 PM   #7
Rewards Points: 12
Do you think its bad if i change the relay with OMRON timer H3CR (0.2s)?
Old 12-21-2016, 08:38 PM   #8
Rewards Points: 12
Old 12-22-2016, 07:26 PM   #9
Rewards Points: 52
Solenoids generally run hot. Especially if they are energized for extended periods.
Moonshot180 and JBoen like this.
TRurak is offline   Reply With Quote
Old 12-22-2016, 07:30 PM   #10
Rewards Points: 12
Thank you
Old 12-22-2016, 08:41 PM   #11
The DC amps will tell you the Watts. ( W = E x I = 12V x ?I = > ? Watts)
An excessive value will indicate a short to ground within the solenoid winding.
DC Solenoids are RL circuits.
DC circuits actually do have impedance... it's just that it decays with time... and (usually) very little time, at that. This means that DC impedance decays to pure resistance within milliseconds -- or a few seconds. ( larger systems -- ie big DC motors )
So, the system starts out with DC impedance -- and then promptly fades to pure resistance. Hence the current is only choked back by resistance. ( Think milliseconds)
Old 12-23-2016, 01:06 AM   #12
Rewards Points: 36
Another way of looking at it is that what is applied to the solenoid is not a DC voltage, it is a unipolar voltage pulse.
It goes from zero to nominal voltage at some time T, and the current moves rapidly toward a steady state value.
This step voltage can be expressed as a summation of an infinite number of sine waves of differing frequency, and it is those that interact with the inductance of the coil, not the "constant" DC.
Real world electricians take the simple stepped DC voltage approach and some engineers and physicists take the Fourier transform approach.
Old 12-24-2016, 07:02 PM   #13
AKA Luketrician
Moonshot180's Avatar
Rewards Points: 1,101
its normal..heck some of the environments our solenoids are in have ambient temps well over 100 deg f....
some solenoids may be too hot to touch..doesn't mean that there is an issue w/ it.
While energized, get a current measurement, and see if it adds up to what the nameplate says.
Big John, telsa and JBoen like this.
Moonshot180 is offline   Reply With Quote
Old 12-25-2016, 10:01 AM   #14
Rewards Points: 12
Thanks all, i just want to know if its normal to get hot, i just dont wanna screw the new solenoid.
Old 12-25-2016, 01:34 PM   #15
Rewards Points: 334
My question would be, how hot is hot?
Old 12-25-2016, 03:21 PM   #16
sbrn33's Avatar
Rewards Points: 3,534
If it is latching why would it get hot?
John Valdes likes this.
Old 12-25-2016, 04:45 PM   #17
Rewards Points: 36
"It pulls and holds...." in the OP was not a reference to a latching solenoid.
It is energized the full time the engine is running.
Old 12-25-2016, 09:06 PM   #18
AKA Luketrician
when the coil starts boiling the paint off of the coil cover...
seriously speaking I think most solenoids that we install, have different ratings on them..asco (for example) will list the normal ambient temperature range in the catalog cut sheets...and most often times, the fluid temp will be additive to the overal temp rating of the coil
Old 12-25-2016, 09:09 PM   #19
AKA Luketrician
Here is an example..of an Asco..with the coil insulation information..
Old 12-27-2016, 10:43 AM   #20
Rewards Points: 12
I think it will be around 40-50 degree celcius for 2 hours hold.
There is many types of fuel solenoid, this one is the fuel shut off solenoid. 3 wires, a black wire to ground, red wire goes to positive, white wire touches red wire for one sec to pull and hold the solenoid. When red wire disconnect from positive, it will stop holding. So i guess, the coil is working as a magnet while getting electricity from positive battery. Thats why it gets hot, perhaps?
Fuel 18 impact more compact then fuel 12 zac Tools, Equipment and New Products 3 08-17-2016 08:54 PM
E Stop For Fuel Pumps Walnuts240 General Electrical Discussion 11 06-24-2016 06:40 PM
Milwaukee M18 vs Fuel HAL9000 Tools, Equipment and New Products 25 05-28-2016 12:46 PM
Water Solenoid Valve electricfishery PLCs, VFDs, Motors and Controls 20 04-05-2016 06:02 PM
Propane vs Diesel fuel for Generators katwalatapan Canadian Electrical Forum 21 02-20-2016 01:59 AM
