Furnace question - Electrician Talk - Professional Electrical Contractors Forum
Like Tree15Likes
  • 4 Post By matt1124
  • 1 Post By MechanicalDVR
  • 2 Post By matt1124
  • 1 Post By HandyManDan928
  • 1 Post By eddy current
  • 2 Post By MechanicalDVR
  • 1 Post By Speedy Petey
  • 1 Post By Dennis Alwon
Closed Thread
Old 06-08-2018, 11:25 PM   #1
Rewards Points: 26
Default Furnace question
Hello,
I recently purchased a new home. I am still under warranty, and as of yesterday, both of my furnaces failed and one of my AC compressors outside failed along with my burglar alarm. I don't know the specifics, but one of the transformers was roached on one unit and he suspected the fan motor or motherboard as well and the other one was receiving power, but not working so he thought it was the motherboard. Neither of the fuses had tripped on either unit.
The builder is trying to say that a power surge occurred, and that it is my responsibility to repair, but none of my breakers flipped and I never lost power to any of my other appliances. In addition, nobody in the immediate area had any issues.
Well, when the HVAC guy came today to fix at least one of the furnaces (thank god, its 90+ degrees during the day), he stated that it wasnt a power surge at all, but he suspects that both of my two furnaces are tied to one supply line and that is what caused the failure. He said they should each have their own dedicated power supply and its written in all the of the books.
I stated since this incident that I was going to get a whole home surge protector installed, but he said that wont help if that is indeed the case that both furnaces are tied to one supply line (I suspect that the alarm system comes off that supply line as well).
Is there any clout to this information? Could there be another explanation? Any help would be extremely appreciated!
Thanks
Tx_new_home is offline
Old 06-08-2018, 11:30 PM   #2
Magic Smoke Remover
Rewards Points: 1,966
Having both furnaces on the same circuit can be problematic, especially if they use IBTL control logic.
zac, MTW, tjb and 1 others like this.
Last edited by matt1124; 06-08-2018 at 11:39 PM. Reason: im a goof and can't get letters right
matt1124 is offline
The Following User Says Thank You to matt1124 For This Useful Post:
Tx_new_home (06-08-2018)
Old 06-08-2018, 11:35 PM   #3
Rewards Points: 26
Originally Posted by matt1124 View Post
Having both furnaces on the same circuit can be problematic, especially if they use ITBL control logic.
Thanks for the quick response. I don't know what ITBL control logic is, but these furnaces are Honeywell and are both part of a new construction less than a year old. I blew my lid when he told me it was my responsibility; I just cant imagine a scenario where a both furnaces less than a year old fail with no real sign of a power issue. I just want to make sure it doesnt happen again.
I have the warranty electricians coming on Monday to install a whole home surge protector anyway, I am going to have them see if both furnaces are actually being supplied by one line. If this is the case, would I have a case to dispute and have it remedied under warranty? I live in Texas if that helps...
Old 06-08-2018, 11:38 PM   #4
Magic Smoke Remover
Have you talked to honeywell about it? I would imagine they wouldn't have an issue at least with the parts, surges happen. I've only ever had a claim with their thermostats, so I'm not sure about their brand of motors.
matt1124 is offline
Old 06-08-2018, 11:40 PM   #5
Rewards Points: 26
I am doing this through the builder and warranty department. I havent thought of speaking directly to Honeywell. I just can't imagine both BRAND NEW furnaces being damaged in less than a year and it somehow is my fault or something I have to pay for in a brand new home?
Old 06-08-2018, 11:43 PM   #6
Rewards Points: 26
I have no idea what all of those pictures mean: I am not an electrician, nor to do I claim to be one. In fact, I thought that was pretty clear. And I am not planning on doing any of this myself. What was the point of that?
Old 06-08-2018, 11:45 PM   #7
Rewards Points: 3,006
You do not belong on this forum!
MTW likes this.
MechanicalDVR is offline
Old 06-08-2018, 11:45 PM   #8
Magic Smoke Remover
Each builder and sub is different. I figure in a couple trouble calls into the initial cost to the builder. I'd just have the supply house warranty the parts, factory should have built a better motor. I might even get to double dip and get labor credit from the factory.
If it's one that we put in with the builder, no way in hell I'd let them get away with one circuit. I'm always on the electrician to read the data plates of my equipment and size his accordingly if we are only doing the HVAC.
matt1124 is offline
Old 06-08-2018, 11:46 PM   #9
Magic Smoke Remover
Mech, don't spoil my fun now...
MechanicalDVR and tjb like this.
matt1124 is offline
Old 06-08-2018, 11:52 PM   #10
Is this not for electrician talk? Isn't the point of this to help people? Why are you such a douchebag?
Are you an electrician?
This isn't homeowner talk!
Old 06-08-2018, 11:52 PM   #11
HandyManDan928's Avatar
Rewards Points: 98
... well , i know that it doesn't help much but , in AZ it's been like 107 for a week straight ... and yeah the bigger AC in the front part of the house wore itself out ... nice ! ... however , "he suspects that both of my two furnaces are tied to one supply line and that is what caused the failure." ... surely both units are NOT on the SAME BREAKER at the panel ...??? That's practically impossible ... a "surge protector" won't do anything at all about that FUBAR ... , call the AC guy to clarify that statement ...that is HUGE if it's what I think you are trying to say ... the 2 things don't jive with eachother , no circuit breakers popped and 2 AC's on the same "supplyline" ... you either have breakers that are arc-welded in in on position (unlikely ) or the AC guy is a "slow learner" ... sounds like Monday is reckoning day ...
Tx_new_home likes this.
HandyManDan928 is offline
Old 06-08-2018, 11:54 PM   #12
Magic Smoke Remover
I'm an electrician and I own 7 homes, thank you!
MechanicalDVR and Tx_new_home like this.
matt1124 is offline
Old 06-08-2018, 11:55 PM   #13
Rewards Points: 26
yeah, its like mid 90's here in TX. Thats why I am trying to figure out the cause of it and hopefully find a solution so it doesnt happen again. Thanks!
Old 06-08-2018, 11:55 PM   #14
Light Bender
eddy current's Avatar
Rewards Points: 7,816
Are you an electrician? Like you said, this is electrician talk.
This is not new home owner talk.
Call an electrician
eddy current is offline
MechanicalDVR (06-08-2018)
Old 06-08-2018, 11:55 PM   #15
I only own one but i have gifted several to exwives!
telsa and Tx_new_home like this.
Old 06-09-2018, 12:00 AM   #16
Magic Smoke Remover
OHHh I am sorry! I thought you were messing with me haha sorry. I don't have a Porsche or a home in the Hamptons. I was just looking for advice. Sorry!
I was gonna say, you might want to get a surge protector put on that hampton home
matt1124 is offline
Old 06-09-2018, 12:01 AM   #17
Rewards Points: 26
Old 06-09-2018, 09:36 AM   #18
Speedy Petey's Avatar
Rewards Points: 604
Thanks for posting on ElectricianTalk.com. However, working with electricity and electrical systems can be unsafe if not done by a professional licensed electrician. The moderators of this site would like to advise you to contact a professional electrician in your area.
Bird dog likes this.
Speedy Petey is online now
The Following User Says Thank You to Speedy Petey For This Useful Post:
Bird dog (06-09-2018)
Old 06-09-2018, 11:03 AM   #19
Rewards Points: 1,810
Guys, we would really appreciate it if you just report these threads rather than engage the op. It really doesn't make us look good when this stuff goes on.
Service Call likes this.
I can't help it if I'm lucky
Dennis Alwon is offline
Closed Thread
I would like to ask a real higher-up engineer a question HackWork Milbank Manufacturing 37 02-09-2018 06:20 PM
Hot water furnace question splatz Off Topic (Non Trade) 7 01-03-2018 11:47 PM
Old furnace wiring question emtnut General Electrical Discussion 26 11-03-2017 02:32 PM
Using existing two wire cable for new furnace. Hanford43 Residential Electrical Forum 9 06-06-2017 11:45 AM
Bonding a resi furnace HackWork General Electrical Discussion 14 08-31-2016 12:57 PM
