Fuse holder in 1/2" KO? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree13Likes
Old 02-14-2018, 12:57 PM   #1
Rewards Points: 1,229
Default Fuse holder in 1/2" KO?
I've never seen these before, what are they for? I couldn't open the panel because there was a pallet in front of it and I was in a rush so I just snapped the picture.
Fuse holder in 1/2" KO?-img_0728.jpg
Old 02-14-2018, 01:12 PM   #2
cabletie's Avatar
Rewards Points: 1,274
I would guess there for that meter or surge protector below the fuses. They probably tap off something large to feed that thing below
HackWork likes this.
The Following User Says Thank You to cabletie For This Useful Post:
HackWork (02-14-2018)
Old 02-14-2018, 01:15 PM   #3
Good guess. I search for it and found those same fuses in one of the packages.
I didn't think about that because I never wired an E-Mon D-Mon with fuses.
Old 02-14-2018, 01:17 PM   #4
cabletie's Avatar
We just did a job that had 208v singe phase condensate pumps that were taped off the three phase feed to the CAC unit hanging in the ceiling. There was a place in the unit to land the condensate pump. It had two of those fuse holders in the unit.
Old 02-14-2018, 01:19 PM   #5
I've seen those in standalone equipment, but never in a panel like that.
I thought maybe it was a way to add an extra circuit or two to a full panel
splatz (02-14-2018)
Old 02-14-2018, 01:24 PM   #6
cabletie's Avatar
Is that a single phase panel? Or are they just metering a single phase load?
Never mind, you said you didn't open the panel.
Old 02-14-2018, 01:27 PM   #7
Rewards Points: 1,182
Those look like panel mount fuse holders, putting them in a 1/2" KO probably would not be 100% kosher but I could see it working reasonably well.
Old 02-14-2018, 01:30 PM   #8
cabletie's Avatar
Oh well, lunch is over. I'm going to mis the lunch view here now the job is done. Ok it's not as nice as McMikes!
Fuse holder in 1/2" KO?-img_1875.jpg
Old 02-14-2018, 01:32 PM   #9
Hey, if you zoom in enough you can see my truck!
Old 02-14-2018, 01:41 PM   #10
Rewards Points: 3,006
Is that Asbury Park there along the ocean?
Old 02-14-2018, 02:01 PM   #11
Rewards Points: 14,073
CC fuse for motor protection?
Old 02-14-2018, 02:12 PM   #12
See: http://www.electriciantalk.com/f2/fu...5/#post4767833
gellc likes this.
Old 02-14-2018, 02:15 PM   #13
What's an Emon Dmon?
Old 02-14-2018, 02:16 PM   #14
Maybe they're for CT leads going to the submetering device. .
Old 02-14-2018, 02:17 PM   #15
http://www.emon.com/
Old 02-14-2018, 02:37 PM   #16
It's a sub-meter.
Old 02-14-2018, 04:24 PM   #17
cabletie's Avatar
Yes, that's it. I knew you would figure it out.
Old 02-14-2018, 04:56 PM   #18
I've been on most of those roofs there....lol!
Old 02-14-2018, 05:01 PM   #19
Rewards Points: 320
You NEVER put a fuse in a CT circuit!
More likely they are for an electronic transducer of some sort, and the device needs a very small OCPD, smaller than 15A, so a breaker in the panel can't work for it.
micromind likes this.
Old 02-14-2018, 05:21 PM   #20
I did not know that - why not? I never did it, never really thought about it until looking at hax's picture ...
What caused this fuse melt down? Canaduh Residential Electrical Forum 9 01-16-2018 07:56 PM
Mystery Fuse Blow Aegis General Electrical Discussion 16 08-17-2017 06:07 AM
how do we know what kind of class for the transfomer fuse or switch gear DS fuse ? mike883 General Electrical Discussion 1 04-30-2016 04:44 PM
Harmonic Filter Fuse glen1971 PLCs, VFDs, Motors and Controls 2 04-06-2016 08:14 PM
Upgrading and outdoor screw-in fuse box to a circuit breaker type box Jimmi328 Residential Electrical Forum 2 03-26-2016 09:09 PM
