Fuse Panel Not Adequate for Home Insurance? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree66Likes
Old 10-15-2019, 03:05 PM   #1
Rewards Points: 8
Question Fuse Panel Not Adequate for Home Insurance?
We recently purchased a home and the insurance company completed an inspection. Below is what the insurance company said I must fix, followed by what the initial home inspection report (not by insurance company), noted regarding the electric. I am wondering if what the insurance company wrote is incorrect based on what my home inspection report shows
From the Insurance company:
Electrical fuse panel. Fuse panel must be replaced with a minimum 100 amp or higher circuit breaker by a licensed contractor.
From the home inspection report prior to purchase:
Service Panel: Siemens 200 amp, 115/230 volt capacity, Circuit breakers, Basement
Branch Circuits: Copper, which did appear to be appropriately matched to the Circuit breakers
happyharry is offline   Reply With Quote
Old 10-15-2019, 03:25 PM   #2
Rewards Points: 578
See @Cricket, this is the type of question that non-electrical pro's should be able to ask here. It's not DIY and I think they would get better answers here than at the DIY forum. But you ignored my private message completely
The insurance company can ask for whatever they want. You either accept their requirement or find a different insurance company who has different requirements. Now if they made a mistake, then you need to find it and show them.
I would get clarification on what exactly they want done and why. Did they mistake the breaker panel for a fusepanel? Or the size? Or are they talking about a small subpanel located elsewhere? Who knows, you need to get as much information as possible.
rlc3854 likes this.
Old 10-15-2019, 04:11 PM   #3
Band Member
emtnut's Avatar
Rewards Points: 56
I'd just call your insurance, and tell them it is a 200A breaker panel ... and ask them 'what's wrong ? '
Old 10-15-2019, 04:14 PM   #4
Rewards Points: 578
$50 says there is one of those little 4 spot fuse panels plastered behind a door somewhere upstairs or in the attic.
MechanicalDVR (10-15-2019)
Old 10-15-2019, 04:19 PM   #5
Band Member
emtnut's Avatar
Rewards Points: 56
I read one recently, probably at DIYchat , where the insurance was freaking over a fused disconnect for a HWT
Fuses kill people
Old 10-15-2019, 06:25 PM   #6
Rewards Points: 8
Question
See @Cricket,
Thanks for your advice. This was the company's response:
"I looked at the photos from the inspection and indicated that yes, the
home does indeed have the appropriate circuit breakers. However, it
also appears that the home has a fuse box as well. They would need
proof from an electrician that the fuse box has been either removed or
disconnected.
Rest assured, the circuit breakers are the appropriate amperage and
nothing further needs to be done with the circuit breakers".
So....Not sure where that leaves me, other than scratching my head
Old 10-15-2019, 06:51 PM   #7
Rewards Points: 2,320
Is there a fuse panel? If not tell them to show you where the fuse panel is... Fuse panels properly done are probably safer than breakers. The problem is people oversize the fuses.
I can't help it if I'm lucky
The Following 2 Users Say Thank You to Dennis Alwon For This Useful Post:
brian john (10-15-2019), stiffneck (10-15-2019)
Old 10-15-2019, 07:02 PM   #8
Rewards Points: 578
disconnected.
Ask him for the picture of the fuse box. Is it possible that you have one in your house somewhere?
If you can’t find it then maybe you will have to get an electrician in there to look around and write up a letter confirming that there is no fuse box in the house.
Old 10-15-2019, 07:21 PM   #9
Can't Remember
Rewards Points: 1,536
Fuse panels work fine with the exception of there is limited space for expansion or the ability for adding arc fault breakers to code.
Old 10-15-2019, 07:35 PM   #10
Rewards Points: 578
They are generally extremely old, they are small and the wiring is packed in tight, they are dangerous because you could put a much larger fuse than the wire could handle, and many of them have exposed energized parts. In general, if you have to make a rule across-the-board, it’s a good idea to replace them.
nrp3 and Kevin_Essiambre like this.
Old 10-15-2019, 07:41 PM   #11
Can't Remember
100 amp sub panels are reasonably priced, so if you have a fused panel somewhere it’s probably not too big of a deal to replace. My guess is the more difficult of the task is replacing the likely three wire feeder with an up to code four wire.
HackWork likes this.
Old 10-15-2019, 10:30 PM   #12
Rewards Points: 28
People over size breakers too lol
They should have made different fuses different sizes for what they insert into but they didn’t. They did however switch to the smaller sockets by means of adaptors which is good. Do you know how many houses I’ve been too and unscrewed a fuse to find a nickel or a quarter back there?
Drsparky14 is offline   Reply With Quote
Old 10-15-2019, 11:12 PM   #13
Rewards Points: 1,483
Maybe ask if it would be acceptable to replace the fuses with circuit breakers?
Old 10-15-2019, 11:22 PM   #14
Rewards Points: 24,212
Maybe a sub forum section: "Ask the pros a question" but just for these type questions
micromind, HackWork and Bird dog like this.
Knightryder12 (10-25-2019)
Old 10-16-2019, 12:54 AM   #15
Beam Me Up Scotty
Kevin_Essiambre's Avatar
Rewards Points: 476
They make these fancy things called fuse ejectors. They screw into the fuse socket. Blue is 15 amp and red (or pink... I can't remember) are 20 amp. You can put smaller but not bigger fuses in.
Vote Kevin for Moderator!
The Following User Says Thank You to Kevin_Essiambre For This Useful Post:
Drsparky14 (10-16-2019)
Old 10-16-2019, 04:56 AM   #16
Rewards Points: 566
I bought an old old house once that had the original 30A fuse box on an outside wall from 1910 when it was built. It was embedded into the ship-lap siding, making it difficult to remove and/or ugly to patch the hole, so it was disconnected and left behind when the service was upgraded to a 100A breaker panel, probably in the 1950s from the looks of it. When I went to insure the house after buying it I went through a similar thing, I had to have a licensed electrician certify that it was no longer in service. I happened to know a licensed electrician at that time (he was sleeping with my wife every night!) He did it for a nominal fee.
Wirenuting likes this.
Old 10-16-2019, 07:02 AM   #17
Rewards Points: 578
Insurance companies often have crazy rules. I've had quite a few instances in which all traces of knob and tube wiring had to be removed, included the knobs. It didn't matter that there was no wiring at all, those knobs had to be removed from the joists in the basement.
This is the typical way that things work when someone sitting in an office without any real world knowledge makes the rules, kinda like the people who make the electrical code.
Old 10-16-2019, 07:48 AM   #18
jw0445's Avatar
Rewards Points: 1,980
So where did you fit in this picture?
jw0445 is online now   Reply With Quote
Old 10-16-2019, 07:58 AM   #19
RSE Master Electrician
Incognito's Avatar
Rewards Points: 954
I argued with an insurance guy who showed up at my house for an inspection about what size my service was. It was a 125 amp rated enclosure with 100 amp breakers. He was trying to tell me I had a 125 amp service.
2018 Canadian Electrical Code
Old 10-16-2019, 08:21 AM   #20
Hmm, I'd think there should have been no fee at all...........
Tags
circuit breakers, fuse box, inspections, insurance, panels
