garage door receiver to turn on lights. - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
  • 3 Post By B-Nabs
  • 4 Post By B-Nabs
  • 2 Post By samgregger
  • 1 Post By 3DDesign
  • 1 Post By wendon
Old 03-04-2017, 02:03 PM   #1
Rewards Points: 698
Default garage door receiver to turn on lights.
I have a customer that wants parking lot lights controlled from a garage door clicker. I have a clicker and receiving unit from a garage door opener that work. when you push the clicker it closes a set of dry contacts for about 1/10th of a second. Of course i need the lights to stay on until the next time the clicker is clicked then they would go off. 3 ways I have thought of doing this.
1. smart relay that would read the dry contact closure and then close another relay output that would stay closed until it was activated again then it would stay open. (existing definite purpose contactors with 120 v coile)
2. arduino with external relay. (same as 1)
3. alternating relay and ice cube relay that would seal in and then break the seal with the alternating relay.
Seems like this would be simpler somehow. Any ideas?
no internet connection is available. They lights are powered from a separate service in the middle of a 5 acre parking lot. They have 5 forklifts they want an opener in.
garfield is offline   Reply With Quote
Old 03-04-2017, 02:11 PM   #2
Watt Pusher
B-Nabs's Avatar
Rewards Points: 474
mechanically held contactor
The_Modifier, telsa and Cl906um like this.
Old 03-04-2017, 02:14 PM   #3
Rewards Points: 698
How does it release?
Old 03-04-2017, 02:17 PM   #4
Watt Pusher
B-Nabs's Avatar
Rewards Points: 474
When it gets a pulse of electricity, it changes state. When it gets another pulse of electricity, it changes state again. They are commonly used in low voltage lighting relay panels, but they can be had as a standalone thing. Google mechanically held contactor and do a little digging, I'm sure you'll find something that works for you in this application.
Old 03-04-2017, 07:44 PM   #5
Rewards Points: 1,367
Also called a latching relay
sbrn33 and The_Modifier like this.
Old 03-04-2017, 08:37 PM   #6
Rewards Points: 3,078
Lift Master App on my iPhone controls my garage door and lights, but you need a WiFi internet connection
wendon likes this.
Greg
Old 03-04-2017, 08:51 PM   #7
Rewards Points: 26,582
Bingo, no doubt about it.
Old 03-04-2017, 10:06 PM   #8
Most Gates use latching relays.
Greg
Old 03-05-2017, 05:38 AM   #9
wendon's Avatar
Rewards Points: 54
What brand opener does he have? Liftmaster/Chamberlain have controls like this available, don't they? I've used one made by Chamberlain that was designed to turn on a lamp etc. and used the output to control a relay. I use Lutron Caseta to control the lighting in my shop, and a Pico with a visor clip to control them from the truck.
Sent from my SAMSUNG-SM-G870A using Tapatalk
99cents likes this.
Old 03-05-2017, 07:05 AM   #10
Rewards Points: 14,257
Have you tested it to see how far away it works?
Old 03-05-2017, 07:28 AM   #11
Rewards Points: 1,292
There is some variation with what people call a latching relay, which makes it harder to google things. What ABB calls a latching relay (E290) operates on an impulse of control current, latches mechanically for continuous duty, and alternates on and off. The minimum impulse is 50ms so your opener should work. They have a good variety of control voltages but contacts only up to 32A at 230VAC.
https://library.e.abb.com/public/940...0_EN_Final.pdf
telsa (03-05-2017)
3 way dimmer wont turn off Ian M Residential Electrical Forum 4 08-07-2016 06:09 PM
Flickering lights turn off/on futureairways General Electrical Discussion 5 06-15-2016 06:53 PM
Recessed LED lights Flicker wncgnet Residential Electrical Forum 9 05-16-2016 10:41 PM
Removing unwanted recessed lights. Woodman General Electrical Discussion 4 05-03-2016 04:56 PM
Metal Garage SparkyJ Residential Electrical Forum 32 03-12-2016 01:23 AM
