GE Breakers Dying - Electrician Talk - Professional Electrical Contractors Forum
Old 09-11-2016, 08:43 PM   #1
ppsh's Avatar
Rewards Points: 118
Default GE Breakers Dying
Put in 2 GE panels on a recent job, and 3 out of 50 breakers were bad. One was a double pole 30a, and one side was dead. The other 2 were AFCIS, upstairs lighting stopped working one day, figured it was a loose connection somewhere, start taking out all the devices, get zapped real good by a neutral, twice. End up undoing every pigtail and remove every device on that circuit, still power on the neutral where the HR comes in. Figure a drywaller must have pierced a wire or something. Decide to check at the panel, 100v from the breakers neutral terminal to ground. Put in new breaker, fixed the problem. Found another bad one when I bump a breaker and the bedroom lights flash, turn it off then try to turn it back on, breaker trips. Change out the breaker problem fixed. Take a look at the old breaker, neutral pigtails pulls right out.
Is this uncommon or are GE breakers just s***?
ppsh is offline   Reply With Quote
Old 09-11-2016, 09:33 PM   #2
Rewards Points: 1,666
I have been using ge for 15+ years and have not had many issues at all. I suspect you got a bad batch....I have never had a defective afci
Old 09-11-2016, 10:44 PM   #3
Rewards Points: 21,884
save those bad breaker and take it back to the place where you did brought the breaker I think you may hit a bad batch .,,
Make sure if the breaker is a genuine item not the counterfit part so look carefull with it.
Old 09-11-2016, 11:01 PM   #4
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,515
I saw that issue 10 years ago. Wound up accumulating over 2 boxes of them. All of them were made in the USA. The ones from Singapore never had an issue.
GFCI Breakers Tripping Simultaneously robmix General Electrical Discussion 15 08-18-2016 06:37 PM
Oxidation on breakers Anathera General Electrical Discussion 58 06-28-2016 01:17 PM
Non-U.L.-Certified Breakers in obsolete Panels? Karl in NY General Electrical Discussion 43 05-18-2016 11:41 PM
New panel or just breakers? newspark80 General Electrical Discussion 22 03-14-2016 11:08 AM
Handle Ties on breakers JasonCo NEC Code Forum 6 02-15-2016 04:31 PM
