GE A-Series Panelboard Bonding - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree29Likes
Old 09-23-2017, 09:36 AM   #21
sbrn33's Avatar
Rewards Points: 3,542
Take one of the neutral SS's out and drill thru it into the can. Then run a screw thru both.
That will look way more factory than some jerry rigged strap.
shocksystems likes this.
Old 09-23-2017, 09:39 AM   #22
sbrn33's Avatar
Did you even look in the bottom of the panel?
Is this one of those ****ing skinny little GE POS?
Old 09-23-2017, 12:27 PM   #23
Rewards Points: 3,236
If the panel is fed by a transformer that's close by, bond in the XFMR and run a ground to the ground bus.
Might not be possible though.......
Old 09-23-2017, 12:52 PM   #24
Rewards Points: 1,642
Could it be this kit?
GE BNDKT
Old 09-23-2017, 05:59 PM   #25
Jlarson's Avatar
Rewards Points: 4,128
I'd just bend up a strap.
Old 09-23-2017, 11:41 PM   #26
Watt Pusher
B-Nabs's Avatar
Rewards Points: 478
If a piece of wire and a lug would be legal, why would you be doing it again? The answer to why is it this way on a brand new panel is the honest one: evidently the bond strap was lost.
telsa likes this.
Old 09-24-2017, 05:13 AM   #27
Rewards Points: 26,780
Wouldn't it be funny if this stinker was bonded up inside a dry-type transformer set nearby ?
Old 09-24-2017, 05:52 AM   #28
Rewards Points: 19,045
It would be even funnier if you looked in my van and found at least ten each 24''pieces of #4, #2, and #1/0 cu conductors cause I'm a service contractor. Some are closer to 6 feet long. Just like American Express, don't leave home without it.
HackWork and telsa like this.
If you start feeling the effects of a possible Corona infection, do not take Ibuprofen (ADVIL) to relieve pain, it increases the ability of the virus to replicate itself.
telsa (09-24-2017)
Old 09-24-2017, 08:20 AM   #29
rrolleston's Avatar
Rewards Points: 1,134
I like to leave some #2 and 4/0 in cases where I have to replace a main breaker and its so bad I have to cut the wires out of the lugs to replace it and splice wire in to reach the new breaker. Worst case we put in a 100 amp breaker and splice #2 to whatever is there and schedule a panel upgrade.
Sent from my SM-S727VL using Tapatalk
HackWork likes this.
Old 09-24-2017, 08:25 AM   #30
Rewards Points: 969
I don't cut then to 24" because sometimes I need longer pieces. But I have #4 and #6 copper and #2 aluminum coils. #2 copper is an oddity for me so I don't have any.
Old 09-24-2017, 08:47 AM   #31
Different worlds.
I'd shift gears if I was a Service Call Electrical Contractor.
My niche is rapid fire Commercial TI.
Actually, super-rapid fire TI. My ideal contract involves trivial changes. ( LED lighting... )
I bite my tongue WRT Canadians, and the East Coast. ( Non EUSERC )
[ I'm constantly amazed as to what flies outside EUSERC. ]
In praise of EUSERC: ECs don't have to conjure up screwball Services.
That is, we don't waste any time trying to 'value engineer' Services.
I'm also spoilt because I don't really have to deal with ice, snow, and frozen ground.
Hence, I bite my tongue when the Northern fellas weigh in.
In my county, the AHJ love underground Services // Service laterals.
( Typically legally mandated. O/H is out of the question for new builds// Service upgrades. )
So even O/H Services -- even Commercial O/H Services -- I run away from.
I'm not in anyway set up for them.
So BITE ME.
Old 09-24-2017, 08:51 AM   #32
Rewards Points: 969
So BITE ME.
Instead of that long drawn out post that had nothing to do with the discussion, you should have just admitted that you have no idea what you're talking about.
readydave8 likes this.
Old 09-24-2017, 08:55 AM   #33
Rewards Points: 1,360
You'd just have to know these clowns. It's a GD nightmare dealing with them. This is military engineers, civilian project managers, and inspectors which come in teams of both. Believe me, it's best to fool them than try to explain code.
shocksystems and B-Nabs like this.
Old 09-24-2017, 08:57 AM   #34
GE BNDKT
The guy on the right looks like it would fit just right and is what I pictured making from a box blank.
Old 09-24-2017, 09:00 AM   #35
Rewards Points: 969
Why did you do this?
Because it's much better than the little tiny bar they give you and it's code compliant to do it.
Old 09-24-2017, 09:07 AM   #36
OK. I'm going to do it like you guys suggest and just put a big obvious lug and #4 jumper out there. But I've already won literally $230000 worth of pending projects on this site, so if this little bodge gets me ejected, I'm coming for each one of you...
Old 09-24-2017, 09:13 AM   #37
Rewards Points: 969
I'm just trying to get you back for all the cash I've lost on the wasted neutrals on all the Tesla chargers I've installed.
shocksystems and RePhase277 like this.
Old 09-24-2017, 09:20 AM   #38
I'm shaking my fist at you now!
Old 09-24-2017, 09:25 AM   #39
Rewards Points: 969
Old 09-24-2017, 11:07 AM   #40
Rewards Points: 960
I sure hope this job you "inherited" you put provision in your contract to get paid extra for running down missing parts
cdslotz is offline   Reply With Quote
Daisy chaining bonding jumpers Sparky305 NEC Code Forum 3 06-27-2017 10:10 PM
Pool Pump Bonding Lug Dennis Alwon General Electrical Discussion 10 05-08-2017 07:09 PM
Earth bonding for AC units razouki General Electrical Discussion 15 11-04-2016 05:22 AM
Earth bonding for AC units razouki General Electrical Discussion 0 11-02-2016 04:24 PM
Hydro tub Bonding? HackMaster General Electrical Discussion 2 01-30-2016 11:26 AM
