Generac Advice - Electrician Talk - Professional Electrical Contractors Forum
Old 02-08-2015, 03:50 PM   #1
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
Default Generac Advice
OK all you Generac gurus. I'm looking at you mcclary.
I have a 16kw generac that is giving me intermittent start issues. Last time it happened, I tried starting the damn thing in manual and it shows battery issue but when I took the battery out and brought it to the parts store where it was purchased, they did a load test and a voltage test and it was fine. Tested at 100%
When it fails to start it shows, error code 1504(?) RPM SENSE LOSS.
SO....if I have a good battery and it will not start and it shows RPM SENSE LOSS when it fails to crank over.......where do I go from here?
Old 02-08-2015, 04:21 PM   #2
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
Damn.....I miss-spelled Generac in my thread title.
Old 02-08-2015, 04:47 PM   #3
Can't Remember
Rewards Points: 1,556
Now I have to slog through the snow to get to the book...
Old 02-08-2015, 04:59 PM   #4
Can't Remember
No crank or no run? I don't see 1504, but see 1501, 1505, 1511, or 1515 RPM sense loss. Doesn't mean that numbers not there either.
Old 02-08-2015, 05:09 PM   #5
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
I could be wrong on the number, I didn't write it down.....but the message is RPM sense loss. Its certainly 15XX....
It won't crank if I try to run it in manual either.
Old 02-08-2015, 05:11 PM   #6
Can't Remember
Loose connection, starter relay, starter itself.
Old 02-08-2015, 05:14 PM   #7
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
OK Thanks for the suggestions. I'm thinking maybe the starter relay???? Good spot to start I guess.
Been a lot of rain and then quick freeze ups here lately. Maybe I have an intermittent problem with water in a connector freezing up.
Old 02-08-2015, 05:22 PM   #8
Can't Remember
It goes through a relay before it makes it to the starter solenoid. That relay is a little black cube with four wires near the controller. Looking for battery voltage at the coil of that relay first, wire 56, then battery voltage at coil at the starter solenoid, wire 16. This would be when you are attempting a start. Be that you are talking a new unit, you can call one of us service guys for warranty too.
Old 02-08-2015, 05:24 PM   #9
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
I will be calling for warranty service. Brand new unit. Less than 15 hrs run time.
Do you want to make a run up to Nova Scotia here in Canada and do the warranty work for me??
Old 02-08-2015, 05:27 PM   #10
Can't Remember
If I were closer, I'd be happy to.
Rollie73 (02-08-2015)
Old 02-08-2015, 05:29 PM   #11
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
I appreciate the help so far NRP......I will check for voltage to the starter and go from there. Its a brand new unit and under warranty so I'm going to do a few basic checks then let the authorized service guy do his end of things.
Old 02-08-2015, 05:34 PM   #12
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Can't be sure without looking but, a couple notes
1) too low gas pressure
2) weak battery
3) bad starter, cranking too slow
4) bad sensor
I listed these in order of likelihood. ....
Old 02-08-2015, 05:35 PM   #13
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
2) weak battery
4) bad sensor
Will it crank over with low gas pressure?
Old 02-08-2015, 05:37 PM   #14
evil bastard
Rewards Points: 746
I missed that this is brand new. Make sure that the selection between lp and ng is correct. Also, there is a physical selection for this, and an electronic selection for this. So there are two places that you need to select fuel type.
Secondly, under load, you should have 10-14 inches of water column. If less, the machine will not run properly, or may not start.
Old 02-08-2015, 05:37 PM   #15
Can't Remember
Cranky yes, starty no. Though in this case you might end up with overcrank.
Saw a few of those at Thanksgiving. Will start and run but die eventually. (gas in wrong position).
Old 02-08-2015, 05:42 PM   #16
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
Yep brand new McClary.....it did run perfectly. I ran it numerous times under load. I did set it up for LP gas already. It just recently started with this issue. It has done its weekly start up every Sunday for the last month and a half but not this week
I get no crank at all.
Old 02-08-2015, 05:44 PM   #17
evil bastard
Rewards Points: 746
Have you tried to start it manually? If so, I would bet is a bad solenoid, or bad starter.
Old 02-08-2015, 05:45 PM   #18
Can't Remember
Start with the wiring, look for 12v at the black relay and if thats good 12v at 16 at the starter solenoid when trying a manual start.
Old 02-08-2015, 05:47 PM   #19
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
Yep tried manual start.
EV Controller shows....
1. Manual start
2. Cranking.....attempt #1
3. Error Code 15XX..........RPM sense loss.
In that order although the exact wording may be slightly different.
Old 02-08-2015, 06:58 PM   #20
evil bastard
Rewards Points: 746
1. Manual start
Yep well you've got either a bad starter relay or bad starter. Verify voltage is making it through your relay. If it is, you know you have a bad starter, double verify that by using jumper cables and putting 12 volts right on the starter.
looking for SoCal Lineman advice..or any advice on.. linemaninthemaking Linework 5 06-08-2014 01:46 AM
generac Side work hero Residential Electrical Forum 79 10-06-2013 10:54 AM
Generac Help boots 211 General Electrical Discussion 6 09-29-2013 05:23 PM
Starting sell alot of GENERAC generators. Advice? Built2ride Business, Marketing, and Sales 12 08-02-2013 12:42 AM
