Generac (OPCB) set up?? - Electrician Talk - Professional Electrical Contractors Forum
Old 02-02-2015, 06:56 AM   #1
Rewards Points: 26
Default Generac (OPCB) set up??
Getting ready to set a Generac 22KW air cooled gen. set with a RTSY200A3 transfer switch. I've also purchased their PMM starter kit (24VAC) and one additional PMM (24VAC).
The house has two Bryant split heat pump systems, one 1st floor with 15KW supplemental heater and one on 2nd floor with 10KW.
I would like to set up the (OPCB) on the transfer switch to shed the 2nd floor system first and the first floor system second in the event of a generator overload.
Just want to know the best wiring method to accomplish this.
Thanks for any help you can provide.
Mike
mike costanzo is offline   Reply With Quote
Old 02-02-2015, 07:05 AM   #2
Can't Remember
Rewards Points: 1,556
PMM's are only good for 50 amps. Be wary of how the heat strips are controlled. I found out on one job that I had to add a tdr relay because the furnace had a thermal relay controlling the heat. So even though I had broken the low voltage wire to the heat strips, the heat would still come back on after an outage on the generator unless I held up the transfer for a minute.
MG set bobelectric Commercial Electrical Forum 1 12-19-2014 08:18 AM
generac Side work hero Residential Electrical Forum 79 10-06-2013 10:54 AM
What is your set up mclovin Tools, Equipment and New Products 12 10-31-2012 11:40 PM
Wanted: Want KO set sparky723 Electrician Swap 22 04-15-2012 03:41 PM
Generac 20 kw footsweat General Electrical Discussion 2 02-26-2012 12:45 PM
