generator with 400 amp switch - Electrician Talk - Professional Electrical Contractors Forum
Old 04-13-2012, 08:03 PM   #1
Bababoee
captkirk's Avatar
Rewards Points: 2,030
Im doing a genny with 400 amp switch for a 300 amp service. Were would you put the switch. ? Im taking out the manual switch... just curious how some of you would approach this. Its gonna be a 20 kw kohler...
generator with 400 amp switch-forumrunner_20120413_200157.jpg   generator with 400 amp switch-forumrunner_20120413_200220.jpg   generator with 400 amp switch-forumrunner_20120413_200238.jpg   generator with 400 amp switch-forumrunner_20120413_200305.jpg
Full time Bovine Scatologist.
Old 04-13-2012, 08:14 PM   #2
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
Can that tel data stuff be moved?
Old 04-13-2012, 08:18 PM   #3
Bababoee
captkirk's Avatar
Yea probably, you think its stupid to put it on the left wall, and maybe sealtight into the trough.
Old 04-13-2012, 08:38 PM   #4
Hairbone's Avatar
Check the article as I believe the emergency feeder will need a seperate wireway. I would disconnect the pvc pipe feeding the wireway and connect direct to the ats and re-feed the trough from the ats.
I wouldn't waste time moving the low volatge as it looks clean the way it is.
BORN TO FISH... FORCED TO WORK
FISH ON
Hairbone is offline   Reply With Quote
Old 04-13-2012, 08:40 PM   #5
Hairbone's Avatar
Bet you a dollar the switch wouldn't fit
FISH ON
Old 04-13-2012, 09:05 PM   #6
Bababoee
captkirk's Avatar
Yes that sounds familiar... that's why i come here...lol...
Old 04-13-2012, 09:12 PM   #7
RIP 1959-2015
HARRY304E's Avatar
No not at all .,If it fits it ships.....
Old 04-14-2012, 12:58 AM   #8
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
I have a similar job coming up with a 300 amp service. Lots of large loads like swimming pool heat, range oven, 5-ton AC, etc. I'm installing a 125 amp panel and transferring the emergency circuits into the new panel. I'll be using the load-shedding switch too just to be on the safe side. Aren't you worried about possibly overloading the genny?
Replies based on NEC 2014
Old 04-14-2012, 07:18 AM   #9
Southeast Power's Avatar
Rewards Points: 9,240
Tony,
If it's just a contactor type double throw switch, you can place it almost anywhere. The problem is if you have a disconnect on it.
The fact that you are bringing in a feed from a 20kw, leads me to believe that it may only have a 100amp breaker on it and that this will all be downstream from the service disconnect.
Old 04-14-2012, 08:47 AM   #10
Bababoee
captkirk's Avatar
I did the same thing on a 400 amp service a few weeks ago Ron. I plan on using a load shedding device on this service. It will allow me to shed four applicances and two ac's.
John im gonna use a 400 amp se rated switch... That should be ok no..?
The Following User Says Thank You to captkirk For This Useful Post:
Magnettica (04-14-2012)
Replacement Generator Transfer Switch mkgrady General Electrical Discussion 8 11-16-2011 07:49 AM
Transfer switch and portable generator CJE General Electrical Discussion 2 02-04-2011 09:20 PM
480 to 240 switch for Generator garfield General Electrical Discussion 2 05-27-2010 08:18 PM
Adding a single gang switch next to an existing switch 1900 General Electrical Discussion 38 05-10-2009 09:43 AM
Wiring In Generator Control Switch limey_swindon General Electrical Discussion 1 01-07-2008 07:16 PM
