Generator capacity is 30 kw - Electrician Talk - Professional Electrical Contractors Forum
Like Tree15Likes
Old 09-15-2018, 04:24 PM   #1
Rewards Points: 8
Default Generator capacity is 30 kw
Hi,
Well, I just want to know by this generator capacity, how many Ac can I run?
أرسلت بواسطة iPhone بإستخدام Tapatalk
Engineertmt is offline   Reply With Quote
Old 09-15-2018, 04:27 PM   #2
No Longer Here
Rewards Points: 578
Originally Posted by Engineertmt View Post
Hi,
At least 0, maybe even 1,000,000.
readydave8, B-Nabs and MikeFL like this.
Old 09-15-2018, 04:35 PM   #3
Southeast Power's Avatar
Rewards Points: 9,366
Hi,
Perhaps to consult the engineer. For the proper question.
Old 09-15-2018, 04:36 PM   #4
Bird dog's Avatar
Rewards Points: 842
This site is in the United States. You're in the Middle East. Who is your closest generator dealer because numerous questions must be answered.
There should be FG Wilson dealers in the Middle East.
FG Wilson Dubai, AE
http://www.fgwilson.ae/
Old 09-15-2018, 05:02 PM   #5
Rewards Points: 21,898
Hi,
The answer will varies a bit depending on the unit size so check with your generator dealer and also the Ac contractor to help you to get the info you need to sized it properly.
Bird dog likes this.
Old 09-15-2018, 05:16 PM   #6
Rewards Points: 8
Hi,
I forgot to mention the capacity of Ac
If I have 2 ton Ac, How to find the answer?
Old 09-15-2018, 05:29 PM   #7
Bird dog's Avatar
Rewards Points: 842
It doesn't matter because you need to talk to your generator dealer & AC Contractor to properly size it like @frenchelectrican said.
frenchelectrican likes this.
Old 09-15-2018, 06:11 PM   #8
Magic Smoke Remover
Rewards Points: 1,976
1 ton is approx 3.5 kW...
Old 09-15-2018, 06:38 PM   #9
jw0445's Avatar
Rewards Points: 1,982
ibtl
MikeFL likes this.
Old 09-15-2018, 06:55 PM   #10
Rewards Points: 3,078
https://www.generatorjoe.net/html/acload.html
Greg
Old 09-15-2018, 07:00 PM   #11
No Longer Here
Rewards Points: 578
I am the only one who gave an accurate number.
emtnut and MikeFL like this.
Old 09-15-2018, 07:16 PM   #12
Bird dog's Avatar
Rewards Points: 842
Should've wrote it in Arabic.
HackWork likes this.
Old 09-15-2018, 07:21 PM   #13
Rewards Points: 6,421
How many can you run is remarkably different than how many can you start.
If you use the old 1 kilowatt per ton rule of thumb, you could likely stagger start 30, 1-ton units. There's no way you could start three 10-ton units, even if you stagger started them. There's a little bit of engineering math that's going to need to go into this.
wildleg, tmessner and MikeFL like this.
Old 09-15-2018, 07:22 PM   #14
Rewards Points: 2,428
As mentioned you have 3500 watts for one unit but you really need to read the nameplate and see what the fla is then you must calculate your wattage. You also need to consider start-up loads so a call to the generator manufacturer would be very helpful for the inrush loads from multiple units.
frenchelectrican and Bird dog like this.
I can't help it if I'm lucky
Old 09-17-2018, 02:19 AM   #15
Rewards Points: 1,564
Hi,
Hows about telling us what size are these AC units
and how much power they need !
Based on a guess of 3kw per unit,
3 easy maybe even 6.
many variables involved
Old 10-09-2018, 04:40 PM   #16
Rewards Points: 8
After this discussion, the only way, is to ask generator company..
The Following User Says Thank You to Engineertmt For This Useful Post:
Bird dog (10-09-2018)
Old 10-09-2018, 06:28 PM   #17
Rewards Points: 3,814
We can answer this question BUT we needed more information generator manufacturer, fuel type, voltage, single phase or three phase, AC type, voltage and amperage running and Lock Rotor amps would have helped.
Old 10-09-2018, 07:29 PM   #18
Band Member
emtnut's Avatar
Rewards Points: 194
That would be a good start.
Whatever you do, don't ask an engineer unless you want to see the magic smoke
fwiw, you can run 14.125 AC's .... really small ones with start staging
Electrical losses can be minimized by doing proper electrical estimating through jack-off internet electrical estimators
Old 10-09-2018, 10:49 PM   #19
And the first question the generator company will ask you is -
How much power the A / C units require ?
No one can give a definite answer without some more details
Not even the generator company
All A / C units should have tags with all this info on them.
we need to see them ?
Old 11-01-2018, 12:09 PM   #20
Rewards Points: 8
