Generator Problem - Electrician Talk - Professional Electrical Contractors Forum
Old 03-02-2015, 03:01 PM   #1
magmash's Avatar
Rewards Points: 218
Default Generator Problem
Hi
I got this generator that have been working fine until yesterday. The generator when started works fine, but after 3 minutes the voltage drops from 230vac to 150-70vac and fluctuate. I have tried to replace the AVR with a new one but still i have the same problem. What do you guys think the problem could be ???
This is some info on the generator
40KW
3 Phase
50HZ
Brushless alternator
magmash is offline   Reply With Quote
Old 03-02-2015, 03:17 PM   #2
Rewards Points: 1,830
Could it be a bad alternator?
Old 03-02-2015, 03:23 PM   #3
Vintage Sounds's Avatar
Rewards Points: 4,004
Is the engine rpm steady?
Old 03-02-2015, 03:24 PM   #4
magmash's Avatar
Rewards Points: 218
Dennis;
I have tested both the exciter winding and the main stator winding and both have their resistance up to specs
Old 03-02-2015, 03:29 PM   #5
Well my guess was the voltage regulator but it sounds like you replaced that already. Not sure what else if everything else is in tact
Old 03-02-2015, 03:44 PM   #6
magmash's Avatar
Rewards Points: 218
Yes its steady
Old 03-02-2015, 04:07 PM   #7
Rewards Points: 664
post your question over on "smokstak.com lot of great mines over there on all types of generators. lot of smart ones here also!
circuitman1 is offline   Reply With Quote
Old 03-02-2015, 04:38 PM   #8
MXer774's Avatar
Rewards Points: 608
First thing I would do is call the manufacturer and see if tech support could offer if any some answers.
MXer774 is offline   Reply With Quote
Old 03-02-2015, 07:45 PM   #9
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
where in Dubai is it ? I wonder if ISIS snuck in during the night and put a potato in the exhaust.
Old 03-02-2015, 07:59 PM   #10
backstay's Avatar
Rewards Points: 296
Check "all" your connections. Loose wire could cause the VR to wander.
Old 03-02-2015, 10:38 PM   #11
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Def check for loose connections at the source and first means of disconnect.
Replies based on NEC 2014
Old 03-02-2015, 11:35 PM   #12
Rewards Points: 1,512
Originally Posted by magmash View Post
Dennis;
Straight resistance measurements will not always detect
shorted turns or insulation breaking down under load.
You need to do a ring test for that.
And a megger test.
Old 03-02-2015, 11:58 PM   #13
Rewards Points: 1,367
Are you taking these readings with a load on it?
Old 03-03-2015, 12:11 AM   #14
quanchai's Avatar
Rewards Points: 150
Have you done a load test on the rotating diodes ?. One possible theory could be that a diode or two fails during load and causes a not constat current flow to the electro magnet from the exciter, which would cause the generator to output a fluctuating voltage + reduced voltage.
quanchai is offline   Reply With Quote
No problem! Magnettica General Electrical Discussion 37 01-26-2014 12:46 PM
Portable 3-phase generator problem erics37 General Electrical Discussion 27 01-13-2013 11:34 PM
Generator problem? Elephante General Electrical Discussion 16 12-21-2012 03:03 PM
Generator problem - exploding GFI outlets and other devices drapati General Electrical Discussion 12 11-07-2012 03:26 AM
5500 watt running, 8550 peak generator problem TooFarFromFenway General Electrical Discussion 11 08-01-2011 12:25 AM
