Generator rehab. - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 02-27-2014, 07:50 PM   #21
Very Long Vacation
Rewards Points: 5,262
Originally Posted by 3xdad View Post
Thanks guys.
The owner said he'd send one of his workers over to the other mountain range to find the old cord cap for me.
i won't be back out there for awhile to get exact info on the yellow tag, but here's a pic for your enjoyment. They've got the 480 on the 6-50R.
Double taped breaker I see.
Change the nema 6-50 to a pin and sleeve. They don't make 480 volt straight blade receptacles.
Old 03-04-2014, 11:02 AM   #22
ET rocks
3xdad's Avatar
Rewards Points: 2,174
Default update
Any of you gangsters or community organizers out east heard of Pyle-National from Chicago?
Cat. No. 321-N
3ph. 30A 4W 600vac
Too soon, Black Dog... way too soon...Rock on buddy.
3xdad is offline   Reply With Quote
Old 03-04-2014, 05:22 PM   #23
Can't Remember
Rewards Points: 1,542
It still exists:
http://www.steinerpylenational.com/a...l-catalog.html
But
http://www.plugs.cc/PYLE_NATIONAL_AMPHENOL_ralco.htm
ON Ebay:
http://www.ebay.com/itm/Ralco-321-A0...item4ce8ca66f2
3xdad (03-04-2014)
Old 03-23-2014, 11:04 AM   #24
ET rocks
3xdad's Avatar
i had to adjust the idle on the gen to run at 60hz. The single and 3ph 120/240v reads correct voltage, but the 480 tests only 417.
Any ideas on how to adjust the 480 voltage only on this regulator? Thanks.
Old 03-23-2014, 11:10 AM   #25
Can't Remember
I don't work on the larger stuff yet, but wondered about the voltage adjust on some of the older units online and wondered if it you needed to use it often. Looking at the photo I would hazard a guess that blue pot might do it. Maybe you need to adjust it when using different voltages?
Old 03-23-2014, 11:16 AM   #26
ET rocks
3xdad's Avatar
Yeah, there are two pots. That one and the one on the left under the two black leads.
Old 03-23-2014, 11:28 AM   #27
ET rocks
3xdad's Avatar
i just found this here. Just need to give it a try i guess.
http://www.macfarlanegenerators.com....0-AVR-Stamford
ADJUSTMENT OF AVR CONTROLS
VOLTAGE ADJUSTMENT
The generator output voltage is set at the factory, but can
be altered by careful adjustment of the VOLTS control on
the AVR board, or by the external hand trimmer if fitted.
Terminals 1 and 2 on the AVR will be fitted with a shorting
link if no hand trimmer is required. Terminals L and L are
linked only for special low voltage applications.
CAUTION Do not increase the voltage above the rated
generator voltage. If in doubt, refer to the rating plate
mounted on the generator case.
CAUTION Do not ground any of the hand trimmer
terminals as these could be above earth potential. Failure
to observe this could cause equipment damage.
If a replacement AVR has been fitted or re-setting of the
VOLTS adjustment is required, proceed as follows:
CAUTION
1. Before running generator, turn the VOLTS control
fully anti-clockwise.
2. Turn remote volts trimmer (if fitted) to midway
position.
3. Turn STABILITY control to midway position.
4. Connect a suitable voltmeter (0-300V ac) across line
to neutral of the generator.
5. Start generator set, and run on no load at nominal
frequency e.g. 50-53Hz or 60-63Hz.
6. If the red Light Emitting Diode (LED) is illuminated,
refer to the Under Frequency Roll Off (UFRO)
adjustment.
7. Carefully turn VOLTS control clockwise until rated
voltage is reached.
8. If instability is present at rated voltage, refer to
stability adjustment, then re-adjust voltage if necessary.
9. Voltage adjustment is now completed.
Old 03-23-2014, 11:34 AM   #28
Can't Remember
The question is which is stability and which is voltage? Looks like the boards are available still. Probably won't hurt to try it and see what happens.
Old 03-23-2014, 12:19 PM   #29
ET rocks
3xdad's Avatar
Voltage on left, stab. on right.
Rehab rules Gamit General Electrical Discussion 18 01-30-2014 09:53 PM
Rehab code in nj? Elephante General Electrical Discussion 12 05-19-2013 06:31 PM
Health and rehab center Service Call Commercial Electrical Forum 6 11-02-2012 07:36 AM
Rehab joethemechanic Off Topic (Non Trade) 3 11-03-2011 11:54 PM
residential rehab services Shockdoc Residential Electrical Forum 16 01-24-2011 10:12 PM
