Getting .143 vac reading on a 20A circuit - Electrician Talk - Professional Electrical Contractors Forum
Closed Thread
Old 01-26-2015, 06:02 PM   #1
Default Getting .143 vac reading on a 20A circuit
I'm renovating a rental unit that was built in the 50's and has been passed through several owners over the years (many of which have done some pretty shabby "fixing" of various systems including some of the electrical circuits). I elected to replace the metal outlet and switch boxes with plastic remodel boxes since I the switches and outlets were in need of replacement anyway. As I was tracing out the circuits with my Fluke model 113 digital multimeter I happened across one that gives a .143 voltage and a continuous tone even with the fuse removed from the socket. I traced the two part wire back to the panel and found that the neutral has the neutral from another circuit spliced into it (whoever did it just removed about an inch of insulation from the neutral tied into the buss bar and wrapped the bare end of the second neutral to it and then taped it up - I suspect because the second neutral was cut too short to reach the neutral buss bar). I haven't removed the tape and disconnected the two to check the circuit again but could this be the cause of the .143 reading I'm getting?
keegans is offline
Old 01-26-2015, 06:42 PM   #2
Speedy Petey's Avatar
Rewards Points: 182
Thanks for posting on ElectricianTalk.com. However, working with electricity and electrical systems can be unsafe if not done by a professional licensed electrician. The moderators of this site would like to advise you to contact a professional electrician in your area.
“If there are no dogs in Heaven, then when I die I want to go where they went.” – Will Rogers
Speedy Petey is offline
Old 01-26-2015, 06:43 PM   #3
Rewards Points: 1,563
You are getting a false reading from your digital multimeter and it is confusing you. Use a simple test light or wiggly and you will see that the circuit is dead with the fuse removed.
samgregger is offline
Closed Thread
14 AWG on a 20A Circuit BSK3720 NEC Code Forum 36 10-02-2014 04:37 PM
20A bath circuit xevious614 NEC Code Forum 8 08-10-2013 07:27 PM
277 vac circuit drops to 55 vac when load is applied. Sparkypyro General Electrical Discussion 15 09-13-2012 04:49 PM
15A switch on 20A circuit? shocking NEC Code Forum 11 09-05-2007 08:06 PM
