Gfci box on lb ? - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 12-23-2012, 09:59 PM   #21
Originally Posted by Cletis View Post
Maybe I was a bit fuzzy how to connect. I was going to use a close rigid nipple through and into the weatherproof box and secure with sealing waterproof locknuts like this
god forbid that you should use a hub on a T or a X to give some
semblance of workmanship.
the answer is, no. you are modifying a UL listed device, voiding
it's UL listing. jesus forking krist.
you must have some deep pathological need to be the center of
attention with the troll questions... but after seeing you demonstrate
the absence of anything resembling enough common sense to figure
out how to pour piss out of a boot, i'd not let you wire a shisthouse
in the middle of a cornfield in kansas that i didn't intend to use.
user8640521 is offline   Reply With Quote
The Following User Says Thank You to user8640521 For This Useful Post:
big2bird (12-24-2012)
Old 12-23-2012, 10:00 PM   #22
ponyboy's Avatar
Rewards Points: 709
Second favorite post of the year
Old 12-23-2012, 10:18 PM   #23
Semi-Ret Electrician's Avatar
Rewards Points: 486
•314.23
(F) Raceway-Supported Enclosures, with Devices, Luminaires, or Lampholders. An enclosure that contains a device(s), other than splicing devices, or supports a luminaire(s), lampholder, or other equipment and is supported by entering raceways shall not exceed 1650 cm3 (100 in.3) in size. It shall have threaded entries or have hubs identified for the purpose. It shall be supported by two or more conduits threaded wrenchtight into the enclosure or hubs. Each conduit shall be secured within 450 mm (18 in.) of the enclosure. See related ROP
The underlined words have been removed by the ROP.
So, it could be done if the wp box is < 100 ci and you support the wp box w/ at least two nipples/hubs, which ought to be an engineering feat
And, all the required splices are allowed in either the condulet or wp box.
The Following 2 Users Say Thank You to Semi-Ret Electrician For This Useful Post:
drumnut08 (12-23-2012), HARRY304E (12-23-2012)
Old 12-23-2012, 11:44 PM   #24
Electron Flow Consultant
sparky970's Avatar
Rewards Points: 992
Please don't feed the troll
Old 12-24-2012, 01:02 AM   #25
Buzzy304E
ibuzzard's Avatar
You mean, don't feed the ****head.
Welcome to ET., where the clowns....
should of......could of....would of.....might of?
ibuzzard is offline   Reply With Quote
Old 12-24-2012, 03:42 AM   #26
Rewards Points: 21,856
Can you legally mount a weatherproof box with gfci in it into an lb cover with bolts assuming you use a weathertight fitting through lb into jbox and caulk heavily ???
Code ref?
Est-ce que vous êtes sérieux ? (are you serious? )
Originally Posted by Hotlegs View Post
Attachment 20426
Close enough
That may work but only for indoor useage but not for outdoor at all due it is not listed to work in wet weather without a WP cover for it.
Cletis ., I know you may have some idea but I will never try to reinvent the wheel like that. Just do the proper way as it should be done.
Merci,
Marc
Old 12-24-2012, 07:37 AM   #27
denny3992's Avatar
Rewards Points: 2,014
Love those fitting devices....
denny3992 is offline   Reply With Quote
Old 12-24-2012, 07:38 AM   #28
denny3992's Avatar
Cletis, before u ask another question, think neat and workmanlike manner before u type plz!
GFCI/non GFCI conductors in same conduit Shockdoc General Electrical Discussion 9 10-02-2012 06:25 PM
Gfci mgtack General Electrical Discussion 10 01-27-2010 07:15 AM
gfci njspark83 General Electrical Discussion 38 08-03-2009 11:27 PM
gfci coyledeals Workplace Safety 19 12-31-2008 07:26 PM
AC run to outside GFCI Mike Lamb NEC Code Forum 13 11-24-2008 09:14 PM
