gfci breaker - Electrician Talk - Professional Electrical Contractors Forum
Old 07-26-2013, 04:48 PM   #1
drspec's Avatar
Rewards Points: 1,120
Default gfci breaker
In the past when box fill was an issue, I would install gfci breakers instead of gfci receptacles on circuits that didn't have a ground. After seeing this today it makes me think that wasn't code compliant.
This came out of a Homeline gfci breaker package. Do all brands contain the same wording in their paperwork? Has anyone else ever noticed this?
Thoughts?
Old 07-26-2013, 05:00 PM   #2
rewire's Avatar
what are you thinking is not compliant?
rewire is offline   Reply With Quote
Old 07-26-2013, 05:02 PM   #3
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
What was the practice for a swimming pool prior to 1965 ?
Old 07-26-2013, 05:06 PM   #4
BBQ
Salty Member
BBQ's Avatar
If you have a pool installed before 1965 you may use a class B GFI.
Not sure anyone makes them.
Old 07-26-2013, 05:08 PM   #5
drspec's Avatar
just edited....
talking about using these on wiring without a ground
Old 07-26-2013, 05:28 PM   #6
BBQ
Salty Member
BBQ's Avatar
Originally Posted by drspec View Post
just edited....
You can use them on circuits without a grounding conductor you just can't use them on ungrounded systems.
Old 07-26-2013, 05:40 PM   #7
drspec's Avatar
I guess it depends on how you read and interpret it but thanks that makes a bit more sense now
Old 07-26-2013, 05:46 PM   #8
Rewards Points: 1,611
It does says "circuits" which makes it seem like they are saying to only use it on a 3-wire circuit.
I doubt it's an issue being as you seem to be the only person who ever noticed that
Old 07-26-2013, 07:27 PM   #9
Going_Commando's Avatar
Rewards Points: 1,620
Well, it says grounded power supply circuits only, and that is one convoluted sentence. My guess is you can use them when the supply is grounded, but I dunno.
ch br 50 amp gfci breaker socalelect General Electrical Discussion 15 01-09-2013 09:38 PM
GFCI Rec & breaker Salvatoreg02 General Electrical Discussion 14 02-04-2012 01:06 PM
CH GFCI breaker sstlouis03 General Electrical Discussion 3 11-10-2011 09:35 PM
Gfci breaker electricalcj General Electrical Discussion 8 10-24-2011 10:58 AM
gfci breaker iam4ual General Electrical Discussion 6 07-21-2011 05:56 AM
