GFCI neutral question - Electrician Talk - Professional Electrical Contractors Forum
Old 05-01-2012, 12:59 PM   #1
Question GFCI neutral question
Serving a small shop with one circuit. Have two recptaciles being protected off of one GFCI, that GFCI and two lights in the shop. Does the nuetral wire with the GFCI protected hot have to be a seperate nuetral wire for the regular circuit nuetral. In other words do I have to pull two nuetrals in part of the pipe or will one work throughout? Oh and also same question with the ground wire.
Thanks!!!
cfiitcb is offline   Reply With Quote
Old 05-01-2012, 01:08 PM   #2
sstlouis03's Avatar
In english this time please?
sstlouis03 is offline   Reply With Quote
Old 05-01-2012, 01:18 PM   #3
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
You need two seperate neutral wires to make that setup work.
Old 05-01-2012, 01:25 PM   #4
felonious smile.
Shockdoc's Avatar
Rewards Points: 572
But you cannot have GFCI and non GFCI conductors in the same conduit.
Old 05-01-2012, 01:30 PM   #5
Rewards Points: 2,302
I think you are thinking of load side for swimming pools. 680.23(F)(3)
I can't help it if I'm lucky
Shockdoc (05-01-2012)
Old 05-01-2012, 01:42 PM   #6
If you want the gfci to function properly then you need to connect either line and load to their perspective places- that includes the neutral. You cannot use the gfci neutral to feed a light that is not part of the gfci load.
Neutral & hot must be on the load side of the gfci or both must be on the line side of the gfci.
The gfci senses the current of the neutral and the hot. If it reads 3-5 ma difference between the two then the gfci will trip.
Old 05-01-2012, 01:48 PM   #7
Speedy Petey's Avatar
Rewards Points: 786
Thanks!!!
Are you doing this work on your own?
Old 05-01-2012, 02:02 PM   #8
Rewards Points: 150
I'm assuming the GFCI protection here is a receptacle?..and you don't want the lights protected? Pigtail your circuit in the GFCI's box and go to the line side of the GFCI and also to the lights. The load side of the GFCI can protect downstream receptacles.
Mark
wesleydnunder is offline   Reply With Quote
Old 05-01-2012, 04:37 PM   #9
Thanks that answers my question on the neutrals. I have a seperate protected hot already pulled and I got to wondering about the neutrals.
Yes I am doing this work on my own for my toolshed in the backyard.
Thank you all for taking time to help me out.
Old 05-01-2012, 07:21 PM   #10
Rewards Points: 1,006
I just want to say one thing: NEUTRAL
__________
Was born in HACKensack, NJ
CraigV is offline   Reply With Quote
The Following User Says Thank You to CraigV For This Useful Post:
Sencoman (05-01-2012)
Old 05-01-2012, 08:06 PM   #11
Mostly Harmless
Split Bolt's Avatar
Rewards Points: 1,008
And I just want to say one thing: "separate," not "seperate!"
"Golf is a good walk spoiled." -Mark Twain
Split Bolt is offline   Reply With Quote
The Following User Says Thank You to Split Bolt For This Useful Post:
Shared Neutral Question Tank General Electrical Discussion 12 12-17-2010 07:48 PM
Neutral Question... sparky723 NEC Code Forum 45 11-22-2010 02:08 PM
2 Pole GFCI Breaker No Neutral BobBob General Electrical Discussion 21 11-06-2010 08:11 PM
Pigtailing neutral wires on GFCI receptacles? Two-headed boy General Electrical Discussion 25 04-17-2010 04:15 PM
Neutral Question micromind General Electrical Discussion 48 05-30-2009 06:08 PM
