Doing repair work in older dwelling. Some Existing recepticle wiring is old 2 comductor cloth with no ground conductor. Thoughts on using GFI recepticle instead of 2 prong recepticle. Will the GFI provide better protection? By code, like for like, I can only install 2 prong devices at these locations.
Had a Zinsco panel utterly melt down a few years back...we would have luckier if the cabin had burned. This allowed complete replacement with actual grounding on the insurance dime for the most part...not the shady stuff from the 60’s.
Last time I installed one was in 95. My supply house gave me their last box for free just to get rid of them. Used it to replace one with a bootleg ground.
The down side of the GFCI method is people will think the devices are grounded even with the required stickers stating otherwise. If the customer is using surge protectors and there is no ground wire then they will not work effectively. One job I was on, the Media Room guy would not guarantee his equipment because there was no ground present. Also if replacing receptacles you might have to use AFCI / GFCI receptacles if you are following the code.
I have put new 2 prong receptacles in living rooms and bedrooms, with a GFI where the TV goes. You don't need a ground prong for a lamp / cell phone charger / clock / vacuum cleaner etc anyway
So, I think I'll mention this since nobody....... you can also rip out said existing circuit(s) and run new Romex wiring........ and charge large.........
It is an attitude instilled into people by Hollywood. I don't think electricians in foreign places have to go thru this as much. F'n Hollywood did this to us.
Tks fpr the input guys. It is most appreciated and helpful, some even amusing.
Related Threads
Electrician Talk
2.3M posts
93.1K members
Since 2007
