GFI 4 non-grnd recepts - Electrician Talk - Professional Electrical Contractors Forum
Old 12-04-2010, 02:50 PM   #1
Question GFI 4 non-grnd recepts
I need to prove to our local OSHA inspector [wanna-be] that I can use gfi receptacles in outlets where there is no ground present. However I can't remember where it is in the NEC. Does anyone know the NEC section/article where this info can be found?
sierrarider is offline   Reply With Quote
Old 12-04-2010, 02:51 PM   #2
BBQ
Salty Member
BBQ's Avatar
The NEC allows it in some instances, OSHA does not.
As far as the NEC look at 406.3(D).
Old 12-04-2010, 03:05 PM   #3
OSHA guy said if it is in the NEC then he will sign off on it. Thanks for the help!
Old 12-04-2010, 03:22 PM   #4
BBQ
Salty Member
BBQ's Avatar
He should not and you will still be liable.
Check this official interpretation direct from OSHA
http://www.osha.gov/pls/oshaweb/owad...ONS&p_id=22962
Old 12-04-2010, 04:32 PM   #5
Rewards Points: 2,000
That link is a LIE.
Old 12-04-2010, 04:36 PM   #6
Rewards Points: 6,421
Originally Posted by Frasbee View Post
That link is a LIE.
No it's not. OSHA agrees with the GFCI will interrupt the circuit over 6ma of fault current within a few cycles, BUT ONLY AFTER some fault current has already flowed; likely through your body. OSHA doesn't permit even that split second tiny fault current to flow through your body as a requirement of the GFCI operating. They'd rather have an actual ground path to possibly stand a chance of tripping the GFCI than to solely rely on your body. This is why they inspect for broken ground pins on extension cords, even though everyone's plugged in via a GFCI.
Old 12-04-2010, 04:40 PM   #7
BBQ
Salty Member
BBQ's Avatar
That link is a LIE.
Are you drunk?
Can you tell me what the lie is?
Old 12-04-2010, 04:41 PM   #8
OSHA also will allow an "approved grounding system" OR GFCI protection for temporary wiring. While the NEC or NFPA 70E (forget which one) will only except GFCI protection for temp wiring.
IMHO I think all temp should have GFCI protection and OSHA should drop that silly approved grounding system option.
slickvic277 is offline   Reply With Quote
Old 12-04-2010, 04:47 PM   #9
Jlarson's Avatar
Rewards Points: 4,056
That link is a LIE.
Just felt like making some crazy statement to flip everyone out or what?
Old 12-04-2010, 05:07 PM   #10
I don't know. I've had to temp in portable panels off 480 services that only had ground fault monitors.
Old 12-05-2010, 01:58 PM   #11
Are you drunk?
It went to a blank page when I clicked it yesterday.
neutral to grnd voltage lynn General Electrical Discussion 3 03-13-2010 02:28 PM
Grounding type recepts RePhase277 Vintage Electrical 9 05-28-2008 09:20 PM
When to use Hospital grade recepts? Losrod NEC Code Forum 15 05-18-2008 05:29 PM
