ground bar on 8x11 box - Electrician Talk - Professional Electrical Contractors Forum
Like Tree1Likes
  • 1 Post By Pete m.
Old 07-02-2014, 10:04 AM   #1
Rewards Points: 146
Default ground bar on 8x11 box
I wanna install a ground bar on a 8x box that's flush mounted to a concrete ceiling. Can I drill 2 holes out to the inside of the box on the side and mount it with a nut and bolt? If so what size or can I use self tappers? Im in nyc
ElectricalArtist is offline   Reply With Quote
Old 07-02-2014, 10:06 AM   #2
Electrical Simpleton
Pete m.'s Avatar
Rewards Points: 172
250.8 Connection of Grounding and Bonding Equipment.
(A) Permitted Methods. Equipment grounding conductors, grounding electrode conductors, and bonding jumpers shall be connected by one of the following means:
(1) Listed pressure connectors
(2) Terminal bars
(3) Pressure connectors listed as grounding and bonding
equipment
(4) Exothermic welding process
(5) Machine screw-type fasteners that engage not less than
two threads or are secured with a nut
(6) Thread-forming machine screws that engage not less
than two threads in the enclosure
(7) Connections that are part of a listed assembly
(8) Other listed means
Pete
Old 07-02-2014, 10:19 AM   #3
Rewards Points: 146
Ok so I can use any nut and bolt or self tapper longer the. Two threads?
Old 07-02-2014, 12:50 PM   #4
Pete m.'s Avatar
Rewards Points: 172
A nut and bolt would most likely be acceptable but remember to remove any paint or other non-conductive coating from behind your ground bar.
The self-tapper may be ok as long as you end up with 2 threads fully engaged in the metal of the box.
Pete
ElectricalArtist likes this.
The Following User Says Thank You to Pete m. For This Useful Post:
ElectricalArtist (01-22-2017)
Old 07-02-2014, 01:05 PM   #5
Rewards Points: 230
You cant use a normal tek screw with a sheet metal thread pitch. The threads are to far apart to engage the metal with more than 2 threads.
KGN742003 is offline   Reply With Quote
Old 07-02-2014, 02:20 PM   #6
220/221's Avatar
Rewards Points: 4,090
You can probably find machine thread self tappers but, who is going to pull them out and measure them?
This (using standard thread self tappers for grounds) is one of the more extreme examples of a purely technical violation of the NEC.
But....there is only one thread on a screw, right?
The Following User Says Thank You to 220/221 For This Useful Post:
chicken steve (07-02-2014)
Old 07-02-2014, 02:25 PM   #7
Pete m.'s Avatar
Rewards Points: 172
Is it a thread or an inclined plane?
Interestingly, as far as the NEC is written you may have pointed out a brand new violation.
Pete
Old 07-02-2014, 02:39 PM   #8
Jlarson's Avatar
Rewards Points: 4,058
Drill holes and throw some #8's or #10's with kep nuts on there.
Old 07-02-2014, 02:40 PM   #9
Rewards Points: 17,799
You can purchase 10-32 tap ends that fit into a cordless drill from the hardware stores, usually they come in packs of ten . While you are there you can get 10-32 screws also , or you can purchase the nicely painted green ones (not required..) from your supply house or the home improvement stores , which are easier to spot in your mess of a tool pouch in dark rooms..
I keep the tap handy at all times. I won't say what else I keep handy in my toolbags for grounding fluorescent lights cause that would be hack...
But that is a nice picture two posts uphill by the way......
JOBS GROWTH SOARS
RECORD WORKING
UNEMPLOYMENT 50-YEAR LOW
Drudge Report
Old 07-02-2014, 03:06 PM   #10
220/221's Avatar
I had a tap tool....in 1975
In 1980, I discovered self tapping screws
Old 07-02-2014, 04:39 PM   #11
denny3992's Avatar
Rewards Points: 2,014
Or these
denny3992 is offline   Reply With Quote
The Following 2 Users Say Thank You to denny3992 For This Useful Post:
Big John (07-02-2014), Cow (07-02-2014)
Old 07-02-2014, 06:34 PM   #12
Rewards Points: 516
Yes^^^^
be easy on them though, as they tend to snap if you push it too hard :whistle:
Sent from my SAMSUNG-SM-G900A using electriciantalk.com mobile app
running dummy is offline   Reply With Quote
Old 07-02-2014, 07:06 PM   #13
denny3992's Avatar
Originally Posted by running dummy
Yes^^^^
If i had a $ for everyone i broke...
Old 07-02-2014, 07:18 PM   #14
Hippie's Avatar
Rewards Points: 570
tell me about it..
Hippie is offline   Reply With Quote
Old 07-02-2014, 08:30 PM   #15
Going_Commando's Avatar
Rewards Points: 1,540
That's what I would do. Drill holes, send in tap, install ground bar. I like 8-32s or 10-32s. As long as the metal is 1/16" thick or more, you have 2 threads.
Old 07-02-2014, 09:38 PM   #16
Sparks fly from my finger
Jhellwig's Avatar
Rewards Points: 4,515
Originally Posted by Hippie View Post
tell me about it..
I have broken more than I have successfully drilled holes with those things. On the plus side it they give you hope of getting them out because you have the drill part sticking out the back of whatever you are drilling till it snaps off.
And for the op. Mount the ground bar with 10-32 screws with it off the wall then grind off whatever is sticking out the back
Telephone Ground to Ground Bus in Primary Panel? truwire Structured Wiring 3 11-30-2013 02:22 AM
Ground rod to ground Qwest and Comcast service? dave.ruybal Residential Electrical Forum 8 05-31-2012 10:15 PM
Ground Fault Without an Intended Ground Path? Scott-Tech General Electrical Discussion 1 11-06-2011 12:26 PM
Confused about Lightning Ground and Building Ground ponders NEC Code Forum 18 08-30-2011 12:11 AM
50 Volts Neutral to Ground and 50 Volt Hot to Ground... DarkDune Residential Electrical Forum 6 06-25-2009 10:56 PM
