Which ground is better? - Electrician Talk - Professional Electrical Contractors Forum
Closed Thread
Old 05-08-2013, 12:13 AM   #1
Cletis's Avatar
Rewards Points: 2,050
Default Which ground is better?
If I ran 2-#6 Cu solid and ran out of meter to 2 separate ground rods or 1 - #6 Cu solid and run to first ground rod then to second ??
Which system would have less resistance ?
I'm shakin it boss..I'm shakin it
Cletis is offline
Old 05-08-2013, 12:24 AM   #2
Chief Hack
Rewards Points: 258
neither
forgotflying is offline
Old 05-08-2013, 12:26 AM   #3
Cletis's Avatar
Originally Posted by forgotflying View Post
neither
Are you saying they are both exactly the same resistance? What theory are you using?
Cletis is offline
Old 05-08-2013, 12:27 AM   #4
Data Tech/Apprentice.
Rewards Points: 22
What the phuck theory are you using?
chewy is offline
Old 05-08-2013, 12:29 AM   #5
Cletis's Avatar
It's Cletis theory. So, if the house took a direct hit which would dissipate lightning better ??
Cletis is offline
Old 05-08-2013, 12:34 AM   #6
220/221's Avatar
Rewards Points: 4,328
Resistance is futile.
220/221 is offline
The Following 3 Users Say Thank You to 220/221 For This Useful Post:
8V71 (05-08-2013), BBQ (05-08-2013), Theriot (05-08-2013)
Old 05-08-2013, 12:37 AM   #7
Chief Hack
Rewards Points: 258
I am saying that drugs are bad
Old 05-08-2013, 12:39 AM   #8
Rewards Points: 22
Obviously the car body up on cinder blocks with grass growing up through it that your cousin sleeps in.
chewy is offline
Old 05-08-2013, 12:39 AM   #9
Cletis's Avatar
To me or to lightening ?
I had a local inspector that always wanted 2 ground rods, so I ran 2 and just ran a continuous #6 from one to another. For fun one day I decided to set two rods and run 2 totally seperate #6's to each rod. He said what the hell did you just do? I said I ran two ground rods like you said to do. He said you can't do that. I said I just did that. He shook his head and walked off...TS
Cletis is offline
Old 05-08-2013, 12:41 AM   #10
Rewards Points: 21,898
For the Cletis's world., if your house did get a direct hit with lightning the lightning will find the least amout restance to the earth so basically my answer is., it don't matter which way you do with the ground rods as you posted. ( don't be suprised it may find other way as well. )
Merci,
Marc
frenchelectrican is offline
Old 05-08-2013, 12:42 AM   #11
Chief Hack
Rewards Points: 258
An inspector that's more foolish than Cletis, I never thought it was possible.
Old 05-08-2013, 12:48 AM   #12
Cletis's Avatar
http://www.allaboutcircuits.com/videos/17.html
http://www.allaboutcircuits.com/videos/20.html
Cletis is offline
Old 05-08-2013, 02:44 AM   #13
Rewards Points: 1,464
Post # 9... Having fun with ground rods.
bobelectric is offline
The Following User Says Thank You to bobelectric For This Useful Post:
CraigV (05-08-2013)
Old 05-08-2013, 03:47 AM   #14
Rewards Points: 21,615
I wish somebody could one day explain to me why inspectors get so all hell bent on the grounding system for anyway...
Most of it is unproven nonsense. Please don't start directing me to go read Soars. Ive done that probably 50 times. Let me say it again- unproven nonsense.
I stand with Tucker Carlson
macmikeman is offline
The Following 3 Users Say Thank You to macmikeman For This Useful Post:
BBQ (05-08-2013), flyboy (05-08-2013), forgotflying (05-08-2013)
Old 05-08-2013, 06:39 AM   #15
Senior Moment
drsparky's Avatar
Rewards Points: 334
drsparky is offline
Closed Thread
GE Ground Break - Ground Fault system acro Services and Service Equipment 2 10-09-2012 06:21 PM
System Ground / Earth Ground Bonded Cletis General Electrical Discussion 15 10-02-2012 02:38 PM
Ground rod to ground Qwest and Comcast service? dave.ruybal Residential Electrical Forum 8 05-31-2012 09:15 PM
Confused about Lightning Ground and Building Ground ponders NEC Code Forum 18 08-29-2011 11:11 PM
50 Volts Neutral to Ground and 50 Volt Hot to Ground... DarkDune Residential Electrical Forum 6 06-25-2009 09:56 PM
