Ground Wire!!! - Electrician Talk - Professional Electrical Contractors Forum
Like Tree4Likes
  • 2 Post By HackWork
  • 2 Post By Roger
Closed Thread
Old 11-24-2017, 05:17 PM   #1
Default Ground Wire!!!
Hiya, I need help... Currently I am fixing an outlet and my granny's but it does not have a ground screw on the switch... But on the old switch it does. Where shall I put the ground wire that was in the switch before?
I was thinking in the switch box/junction bo
Sent from my MIX using Tapatalk
Faiz1234 is offline
Old 11-24-2017, 05:38 PM   #2
Are you wiring an outlet or a switch?
DelGuy is offline
Old 11-24-2017, 05:42 PM   #3
Rewards Points: 1,359
You should call an electrician before you kill your granny.
The_Modifier and Jamato like this.
HackWork is online now
Old 11-24-2017, 05:45 PM   #4
Chief Flunky
Rewards Points: 338
A SWITCH does not need a ground wire. Receptacles do. Boxes have to be bonded if they are metal. Otherwise you just need to secure it so it won’t hit the hot or neutral, and connect to any other grounds such as one connected to the fixture.
paulengr is offline
Old 11-24-2017, 05:51 PM   #5
Rewards Points: 976
You might want to read 404.9(B)
Roger
electricguy and samgregger like this.
Roger is offline
Old 11-24-2017, 05:53 PM   #6
I've sorted it out.. I just need to fit the ground wire to the box instead of the switch.. it's got a ground screw
Faiz1234 is offline
Old 11-24-2017, 06:02 PM   #7
Peter Goldwing's Avatar
Rewards Points: 274
Trying to help a bit, I hope i understand you situation. The old switch had a grounding screw and the new one does not, as I understand. Go to your ACE store or HD and buy a switch with grounding screw. The grounding wire serves as shock protection. If the cover plate is made of plastic not much to worry about the ground ( i didn't say this)
Peter Goldwing is offline
Old 11-24-2017, 07:13 PM   #8
Rewards Points: 21,896
Please go to our sister site for this situation.,,
frenchelectrican is offline
Closed Thread
Underground fault locator recommendation garfield General Electrical Discussion 10 02-16-2020 05:31 PM
how a GFCI receptacle works if there is no ground wire connect to it? mike883 General Electrical Discussion 29 04-18-2017 10:09 AM
for pad mounted transformer secondary side, pulling wire no ground wire required? mike883 General Electrical Discussion 9 04-09-2017 02:22 PM
Ground wire "dish" underneath ground screw? BrianJayT Residential Electrical Forum 26 12-19-2016 03:51 PM
is it OK to use the wire connector to connect the ground wire inside the drop ceiling mike883 General Electrical Discussion 29 07-20-2016 01:37 PM
