Grounding - Electrician Talk - Professional Electrical Contractors Forum
Old 07-26-2013, 04:37 PM   #1
Mikeelec's Avatar
Default Grounding
I placed my clamp meter on the main ground of a service going to main water pipe and picked up 2.6 amps. Is this a problem ?
Mikeelec is offline   Reply With Quote
The Following User Says Thank You to Mikeelec For This Useful Post:
Fibes (07-26-2013)
Old 07-26-2013, 04:44 PM   #2
Rewards Points: 310
Not if you want your tap water to be an energy drink
bkmichael65 is offline   Reply With Quote
The Following User Says Thank You to bkmichael65 For This Useful Post:
Shockdoc (07-27-2013)
Old 07-26-2013, 11:01 PM   #3
Rewards Points: 5,198
All energy...voltage etc, is destined to get back to it's personal energy source. In theory, the load current should be going back to the source transformer through either the neutral or one of the hot wires. If you have a loose neutral then possibly that is your problem.
Old 07-27-2013, 12:23 AM   #4
Vintage Sounds's Avatar
Rewards Points: 4,004
Or if your neighbour does.
Old 07-27-2013, 01:19 AM   #5
Rewards Points: 333
Check the neutrals in the panel. The service neutral especially. Also check the grounds and bonds. I have never put a clamp meter (amp) on a ground but I have found weak voltage readings from hot to ground. (i.e. 12 to 60 V, something like that). I have also found weak voltage readings between ground and neutral. (i.e 12 to 60 V, something like that.) This usually indicates a weak or improper ground somewhere in the circuit. (If the ground is connected solidly to the neutral bus you should get 120 V, or full voltage, depending on what type of service you're working on, and 0 voltage from neutral to ground). When the grounds are connected solidly again small amounts of induced voltage "bleeds off" and I then get a zero potential like it's supposed to be. (i.e. 120 V from hot to ground and 0 voltage from neutral to ground.)
Paul S. is offline   Reply With Quote
Old 07-27-2013, 01:32 AM   #6
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
Yes it is , Don't do it again..
Old 07-27-2013, 02:04 AM   #7
wendon's Avatar
Rewards Points: 54
You're in trouble. Put those amps back where you found them ASAP!
Old 07-27-2013, 12:52 PM   #8
Rewards Points: 1,224
The grounded conductor current flows back to the transformer on all of the available parallel paths. In areas with a common metal underground water piping system it is not unusual to find 20% or more of the total grounded conductor current flowing on the water pipe.
Old 07-27-2013, 02:10 PM   #9
Dash Dingo's Avatar
Rewards Points: 318
No, that's not that much.
Dash Dingo is offline   Reply With Quote
Grounding RIVETER General Electrical Discussion 54 11-28-2011 08:47 AM
Grounding Apprentice_617 General Electrical Discussion 4 01-19-2011 05:39 PM
Replacing non-grounding receptacles with grounding Gamit General Electrical Discussion 31 01-10-2011 11:34 PM
Grounding 250.24 uber stein NEC Code Forum 17 09-17-2010 05:02 PM
Grounding? calimurray NEC Code Forum 13 04-29-2008 03:56 AM
