Grounding switches - Electrician Talk - Professional Electrical Contractors Forum
Old 01-23-2015, 09:52 PM   #1
eds
Rewards Points: 234
Default Grounding switches
In a non metallic box why do I have to take equipment grounding conductor to each switch in the box. Why not just hit one switch with a conductor based on the largest wire in the box
eds is offline   Reply With Quote
Old 01-23-2015, 09:55 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
How would the other switches be grounded then?
guest (01-23-2015), sparky970 (01-27-2015)
Old 01-23-2015, 09:59 PM   #3
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
Do you have a supply of Romex with no ground wire?
Old 01-23-2015, 10:01 PM   #4
Don't laugh. It IS made.
Old 01-23-2015, 10:10 PM   #5
corn-fused
papaotis's Avatar
Rewards Points: 620
Old 01-23-2015, 10:11 PM   #6
The_kid's Avatar
Rewards Points: 12
I understand what he's saying.
The question is,
Do you have difficulty understanding what a non metallic box is?
The_kid is offline   Reply With Quote
Old 01-23-2015, 10:20 PM   #7
eds
Rewards Points: 234
I get why the switch needs to have a grounding conductor attached to it, but if I have a 4 gang box am I making it that much safer by grounding all 4 switches.
Old 01-23-2015, 10:22 PM   #8
corn-fused
papaotis's Avatar
Rewards Points: 620
only if there is a ground fault at the switch?
Old 01-23-2015, 10:23 PM   #9
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
Not in my opinion, however the code requires us to ground switches.
Old 01-23-2015, 10:28 PM   #10
Southeast Power's Avatar
Rewards Points: 144
Something about a bare ground in a box makes me wonder how much money is actually saved by not insulating it.
amigi968 (01-24-2015)
Old 01-23-2015, 10:28 PM   #11
ET rocks
3xdad's Avatar
Rewards Points: 2,174
Let's put it this way. The day you decide not to land on that green screw is the day some HO will shock the **** outta themselves.
3xdad is offline   Reply With Quote
Old 01-23-2015, 10:31 PM   #12
RIP 1959-2015
Black Dog's Avatar
Rewards Points: 180
The conductor is bare to prevent it from being used as an ungrounded conductor....
Old 01-23-2015, 11:08 PM   #13
If only one switch is grounded, is it safer than the other 3 that aren't?
Old 01-23-2015, 11:26 PM   #14
Rewards Points: 5,198
Having not read any further posts I will say that the egc is not determined by the largest conductor in the box...to start with.
Old 01-23-2015, 11:37 PM   #15
erics37's Avatar
Rewards Points: 642
Go ahead and leave them ungrounded. It's all exposed plastic, right?
Until someone decides to put a stainless plate on there, that is.
I had a service call a few years ago where a guy had a 3-way switch go bad and tried to replace it with a single-pole switch. Well the S.P. switch has three screws, right?? (Hot, switch leg, and ground)
So he had stuck the switch leg on the common screw and a traveler on the other screw and the other traveler on the ground screw. So of course the light didn't switch on and off properly (hence the service call) but unbeknownst to him, half the time his stainless switch plate (bonded to the switch yoke) was energized as well. Fortunately it was by his bed so the only time he ever touched it was when he was isolated from any grounded objects.
The Following User Says Thank You to erics37 For This Useful Post:
The_Modifier (01-23-2015)
Old 01-23-2015, 11:50 PM   #16
You should rethink your advice and I am not trying to be "stinky".
Old 01-24-2015, 12:34 AM   #17
A Little Short's Avatar
You did a good job not to be trying!
Old 01-24-2015, 12:47 AM   #18
Are we on the same page? He new that "all metallic components of an electrical system" must be bonded at ground potential but in the first sentence of the post...pissed it off.
Old 01-24-2015, 01:52 AM   #19
Rewards Points: 1,464
Life is gettting full of "What If ".
Old 01-24-2015, 06:57 AM   #20
Dash Dingo's Avatar
Rewards Points: 318
I think what the op is trying to say that if he grounds only one switch out of four and if someone puts a metal plate on, then the plate and all the switches will be grounded then.
I see his point.
Dash Dingo is offline   Reply With Quote
The Following 2 Users Say Thank You to Dash Dingo For This Useful Post:
MTW (01-24-2015), readydave8 (01-24-2015)
Client called a Handyman just to change old 3way switches to Decora Type switches HARRY304E Code Violation Discussion 30 01-27-2014 12:20 AM
Grounding Snap Switches/404.9(B) uconduit General Electrical Discussion 35 12-15-2013 06:47 PM
Replacing non-grounding receptacles with grounding Gamit General Electrical Discussion 31 01-10-2011 10:34 PM
Grounding of toggle switches walkerj General Electrical Discussion 26 05-17-2007 07:24 PM
