Hack? Maybe Not - Page 3 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree44Likes
Old 08-08-2016, 07:52 PM   #41
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,880
Originally Posted by just the cowboy View Post
It is now the feed for a receptical in the cabinet for a razor. Does it need to be GFI if it is in the cabinet?????
Not that it matters, but this would not be allowed in Canada.
26-710(h) disallows receptacles in cupboards and cabinets. There
are, of course, exceptions, but this isn't one of them.
P&L
Old 08-08-2016, 11:58 PM   #42
Conservitum Americum
LARMGUY's Avatar
Rewards Points: 216
Not trying to be funny but look at your smokies. You might want to upgrade to combos if you don't already have them. If they don't talk to each other, I have installed Nests.
By combos I'm assuming you mean CO detectors?
FYI - CO's have a shelf life depending upon manufacturer of 5 to 7 years.
http://www.fayengineering.com/articl...-alarm-expired
http://www.mouseprint.org/2012/10/29...il-in-7-years/
Cowboy words of wisdom.
Old 08-09-2016, 09:01 AM   #43
Rewards Points: 14,075
Yes, I meant smoke/CO. I didn't know about the end-of-life. That's good information.
On reno jobs, I often put a combo unit in the furnace room even though it's not a code requirement. I had a guy from the City tell me it's not a good idea because a gas furnace can emit small amounts of CO that aren't dangerous but could set off the alarm. I have never had a call back. What do you think?
Old 08-09-2016, 09:36 AM   #44
Rewards Points: 1,235
FWIW, Kidde makes a sealed battery unit rated for 10 years (both battery and function wise). Lithium battery so you never have to change it, it's a great idea and a good upsell for the customer. I just stocked a few of each on my truck.
Old 08-09-2016, 10:41 AM   #45
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 1,038
while I like the idea of being able to monitor the home, I have always opted to let someone else monitor it (burglar/fire). that way the fire/police are called whether I am checking on it or not. I like that. especially for the smoke/fire. 24/7. home, fishing, sleeping, whatever. that 600 bucks a year for monitoring is peace of mind.
LARMGUY likes this.
Old 08-09-2016, 12:07 PM   #46
Spaghetti Cleaner
Rewards Points: 540
$600? Try NextAlarm, have them at a couple sites, think under $200 a year
Thread shorter.
sarness is offline   Reply With Quote
Old 08-09-2016, 01:52 PM   #47
Rewards Points: 3,006
Wasn't aware of this choice. Thanks!
https://info.nextalarm.com/
Old 08-09-2016, 02:56 PM   #48
Rewards Points: 34
Originally Posted by Brain John View Post
I specialize in testing and maintenance, I can test everything but hack wiring like this while it may pass every test for 600 VAC cable is still hack
I advice work while standing on a wooden stool. So you you don't get earthed. Happy Testing
johntempleman is offline   Reply With Quote
Old 08-09-2016, 08:50 PM   #49
Wood has successfully been replaced by fiberglass. It's much more sturdy over time as well.
Old 08-09-2016, 11:01 PM   #50
LARMGUY's Avatar
Rewards Points: 216
I would hope future technologies would overcome the shelflife problems however every CO detector or combo I have used, the CO has either falsed incessantly or failed completely after a few years.
Old 08-09-2016, 11:10 PM   #51
I used to use a lot of Kidde but they had a bad run or something and had a bunch of bad ones. Failed right away.
Old 08-10-2016, 09:48 AM   #52
wildleg's Avatar
well, let's face it, the detectors have to breathe, but they have no way to clean their lungs, so besides the shelflife problem, the in-use problem is that someone either has to build one that cleans its own sensors or they will continue to be a throw away or maintenance item. (at least they fail in the on position ). Lastly, IMO they are worth the cost.
Old 08-10-2016, 02:42 PM   #53
Rewards Points: 34
Looks like someone is getting things done real quick and yeah Sturdy is good.
Gems of the Trade MechanicalDVR General Electrical Discussion 11801 02-14-2020 11:32 PM
How badly did I hack it Anathera General Electrical Discussion 26 05-14-2016 06:49 AM
EC fined $537,500.00 for hack work jza General Electrical Discussion 44 04-24-2016 05:48 PM
Hack? AllWIRES General Electrical Discussion 20 04-15-2016 10:55 AM
