Help with frozen pipes - Electrician Talk - Professional Electrical Contractors Forum
Old 01-16-2015, 06:26 PM   #1
Dash Dingo's Avatar
Rewards Points: 318
Default Help with frozen pipes
Ran some underground 3/4" PVC for pole lights back in September. Did not pull in wire because I was worried about theft, did not have the time, and the pole lights were not on sight at the time. The shipment of the pole lights got delayed until late December and I just received them last week. We went to push a fish tape through some conduits and they are froze up, feels like at the 90's. We tried a heat gun but that dint seem to get down far enough.
We had an unusual thaw in December and I think some water seeped in the pipes and now froze.
Any suggestions? Can you pour some type of chemical in there without damaging the conduits?
I don't want to wait til spring!?
Dash Dingo is offline   Reply With Quote
Old 01-16-2015, 06:37 PM   #2
RHWilks's Avatar
Rewards Points: 276
In Oklahoma I had the same problem last week..Polar Vortex...I put rubbing alchol<sp> the next one was white vinegar. Those are pretty non toxic and shouldn't hurt the conductors or the conduit.
Me " I ran out of parts.." Boss " if you would have worked faster...you would have finished before you ran out of parts."
RHWilks is offline   Reply With Quote
Old 01-16-2015, 06:38 PM   #3
Tsmil's Avatar
Rewards Points: 508
Originally Posted by Dash Dingo
Ran some underground 3/4" PVC for pole lights back in September. Did not pull in wire because I was worried about theft, did not have the time, and the pole lights were not on sight at the time. The shipment of the pole lights got delayed until late December and I just received them last week. We went to push a fish tape through some conduits and they are froze up, feels like at the 90's. We tried a heat gun but that dint seem to get down far enough. We had an unusual thaw in December and I think some water seeped in the pipes and now froze. Any suggestions? Can you pour some type of chemical in there without damaging the conduits? I don't want to wait til spring!? Sent from my iPhone using Tapatalk
Spring is coming.
Tsmil is offline   Reply With Quote
Old 01-16-2015, 07:12 PM   #4
Rewards Points: 1,004
Gas-line antifreeze is 90% alcohol (HEET), rubbing alcohol is only 70%. but once frozen solid its gonna take some time or heat, hopefully the plug is near the ends.
xpertpc is offline   Reply With Quote
Old 01-16-2015, 07:54 PM   #5
Rewards Points: 1,464
RV anti-freeze?
The Following User Says Thank You to bobelectric For This Useful Post:
The_Modifier (01-17-2015)
Old 01-16-2015, 07:55 PM   #6
IBEW L.U. 1852
Rollie73's Avatar
Rewards Points: 286
I've been there. I used a bottle of methyl hydrate mixed with a HUGE amount of salt.....poured it down the pipe and let it sit over night. The salt melted the ice enough for the methyl to get down in there and start evaporating the water. Set up with compressed air at the other end (thankfully it was inside the building) and blasted the rest of the crap out the outside end. After that we swabbed the pipe by dragging rags through there a few times....lubed it up good and pulled the wires in before it froze again.
The Following 2 Users Say Thank You to Rollie73 For This Useful Post:
Dash Dingo (01-16-2015), The_Modifier (01-17-2015)
Old 01-16-2015, 08:05 PM   #7
Rewards Points: 10,226
I love california, never had that problem.
Old 01-16-2015, 08:48 PM   #8
More than lead and elbows
JW Splicer's Avatar
Rewards Points: 1,130
Hopefully it didn't break the conduit. I had a 1 inch rigid 90 swell up like a bomb went off inside it once. Luckily it was out in the open.
JW Splicer is offline   Reply With Quote
Old 01-16-2015, 08:50 PM   #9
Senior Moment
drsparky's Avatar
Rewards Points: 42
Depending on your latitude you may be waiting until May.
Old 01-17-2015, 09:57 AM   #10
Rewards Points: 33
My old boss where I took my apprenticeship at once duck taped a heat gun to a 2" pvc run that was for the building feeders. He left it on overnight, and all was good in the morning. Best part was that he returned it to princess auto the next morning! We laughed and he said "well we've put more wear on this thing in one night then it'll ever see in a lifetime"
jablonski is offline   Reply With Quote
Old 01-17-2015, 11:13 AM   #11
I dislike people that cheat the world...
The Following 5 Users Say Thank You to bobelectric For This Useful Post:
amigi968 (01-17-2015), Chris1971 (01-18-2015), eric7379 (01-18-2015), John Valdes (01-18-2015), Magnettica (01-18-2015)
Old 01-17-2015, 11:20 AM   #12
Rewards Points: 33
Yes, but the story was just too good. He runs a company of anywhere between 40-55 guys, and he actually took the time of day to return a 20$ heat gun!
Old 01-17-2015, 01:02 PM   #13
Senior Moment
danhasenauer's Avatar
Rewards Points: 725
I have poured Prestone Antifreeze (undiluted) down frozen pipes with great success. Works slow but works every time. Ethylene glycol is also a component of PVC pipe as well as wire insulation, so it's pretty harmless to your work and it's residual in the pipe acts like pulling lube.
danhasenauer is offline   Reply With Quote
Old 01-17-2015, 01:06 PM   #14
220/221's Avatar
Rewards Points: 4,352
If it is at the first 90, I'd pour in some boiling water, let it sit for a few minutes then vacuum it out and repeat. If you see some progress (like the water starting to drain slowly), put the vacuum on the other end and try to suck the hot water through (or use air to push it out).
But, I live in the desert so WTH do I know about ice? Give me a question about cacti and I will hook you up.
Old 01-17-2015, 01:24 PM   #15
Senior Moment
Rewards Points: 725
Ever see the YouTube videos of how fast boiling water freezes at a -30 windchill index? And you're spilling it while pouring it in the pipe, creating a nice skating rink where you're trying to work clearing a frozen conduit. Pour in your antifreeze and come back tomorrow.
Can I use a cactus as a clean-out mandrel?
Old 01-17-2015, 03:08 PM   #16
220/221's Avatar
I have seen the boiling water thrown into the air in extreme cold. Craziness.
I was thinking less extreme conditions and small amounts of water. If there was a small ice plug (a few inches of ice) 24" down in the first 90, a couple cups of boiling water would probably do some thawing.
And, yes, a cactus will work nicely for your mandrel. The Cholla is very user friendly
Old 01-17-2015, 03:11 PM   #17
I still think your boss using a heat gun on someones electric and taking it back for a refund is sad. It'll catch up to him.
The Following 2 Users Say Thank You to bobelectric For This Useful Post:
eric7379 (01-18-2015), jablonski (01-17-2015)
Old 01-17-2015, 03:40 PM   #18
Rewards Points: 14,714
Couldn't you just drop a small air hose down to the ice level and blow compressed air (and a low pressure) down on the ice? I bet it would melt it enough where you could either blow it (ice) out or suck it up.
It might take a while.
Old 01-17-2015, 06:48 PM   #19
Rewards Points: 761
Could I use the exhaust from the van idling forced via a tube into the conduit end to melt it? I have this same problem right now in Philly.
electricbysullivan is offline   Reply With Quote
Old 01-17-2015, 08:03 PM   #20
Senior Moment
drsparky's Avatar
Rewards Points: 42
If you realy need to thaw it this method is messy but will work. Feed a 3/8 flexible hose into the conduit while pumping hot water at low volume through the 3/8 hose and advancing it as the ice melts you will clear it. Puting hot water or chemicals at the end doesn't do much. You need to transfer the heat to the ice and remove the cold water as the ice melts. Have a shop vac to clean up the waste water that will be forced out of the conduit as you add hot water. Good luck and post your success.
The Following 2 Users Say Thank You to drsparky For This Useful Post:
hardworkingstiff (01-18-2015), metalpats (01-18-2015)
Hell has frozen over Phatstax Tools, Equipment and New Products 24 12-05-2014 12:48 PM
So why does a thread on frozen pipes get closed? 99cents Site Help and Suggestions 25 01-08-2014 01:49 PM
frozen pipes s.kelly General Electrical Discussion 24 01-23-2013 07:09 PM
Locks frozen ohiosparky99 General Electrical Discussion 44 12-17-2011 03:28 PM
Frozen pipes / Electric Heat - help mothgraphics General Electrical Discussion 29 12-19-2009 12:33 PM
