Help with frozen pipes - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Old 01-17-2015, 08:19 PM   #21
Rewards Points: 1,298
Hire selected individuals from this site to blow in the conduit, theirs is plenty of hot air to do the job.
Mich drew is offline   Reply With Quote
The Following 5 Users Say Thank You to Mich drew For This Useful Post:
Dan the electricman (01-18-2015), eric7379 (01-18-2015), MTW (01-17-2015), Rollie73 (01-17-2015), Ty Wrapp (01-18-2015)
Old 01-17-2015, 08:26 PM   #22
ponyboy's Avatar
Rewards Points: 709
How has no one suggested pissing down the pipe
The Following User Says Thank You to ponyboy For This Useful Post:
amigi968 (01-18-2015)
Old 01-17-2015, 09:14 PM   #23
Rewards Points: 160
Chemicals.... waiting..... try a plumber's powered drain snake with the cutting head. Heat the head with a torch first. That works great for small areas, less than 10 feet frozen. Then just hook up a good vacuum and either suck or blow, whichever is the shortest route.
If the whole pipe is frozen, 1 gal of vinegar and a typical tub of salt mixed thoroughly. If you can boil the mix for a few minutes, even better. That concentrates the acetic acid in the vinegar. That formula also will eat concrete out of pipes ( and floors ) so be careful.
Edit, I havent always lived or worked in Fl.
amigi968 is offline   Reply With Quote
Old 01-17-2015, 09:20 PM   #24
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
All that would do is drill straight through the pvc. Especially in a90.
metalpats (01-18-2015)
Old 01-18-2015, 12:20 AM   #25
Rewards Points: 160
Uh, plumbers do it all the time.... as do we when old conduit gets filled with roots. The teeth are curved in at a 45 degree angle to go around corners....
See this one.
http://www.rjmcompany.com/plumbers-snakes/K%2014A.jpg
Old 01-18-2015, 08:31 AM   #26
professional redneck
Rewards Points: 187
the plumber drain cleaner is a bad idea for the same reason mcclary's mntionned, your best bt is to rent one of those http://www.northerntool.com/shop/too...7863_200377863 and use a pipe cleaning snake that go on it , and a vacuum at the other end. be careful, boiling hot water will be getting back on you, plus if the air is under -25celsius (?F) and the air really dry it wont work, your just gonna will the pipe from ice under those conditions.
i use this trick on anything from my house water suply to culvert and it really work
metalpats is offline   Reply With Quote
Old 01-18-2015, 05:58 PM   #27
220/221's Avatar
Rewards Points: 4,352
See this one.
Drain pipes are bigger than 3/4"
Hell has frozen over Phatstax Tools, Equipment and New Products 24 12-05-2014 12:48 PM
So why does a thread on frozen pipes get closed? 99cents Site Help and Suggestions 25 01-08-2014 01:49 PM
frozen pipes s.kelly General Electrical Discussion 24 01-23-2013 07:09 PM
Locks frozen ohiosparky99 General Electrical Discussion 44 12-17-2011 03:28 PM
Frozen pipes / Electric Heat - help mothgraphics General Electrical Discussion 29 12-19-2009 12:33 PM
