Help Put This Puzzle Together - Electrician Talk - Professional Electrical Contractors Forum
Like Tree48Likes
Old 03-17-2019, 06:02 PM   #1
A Little Short's Avatar
Rewards Points: 716
Default Help Put This Puzzle Together
I need to install a service on a house. The meter will mount to a poured concrete basement wall. I need to run a 2" PVC conduit into a 2" LB, then through the wall. Here's the problem. They put a 2" piece of PVC in the form when they poured the wall. So now that the forms are off, the PVC is flush with the wall on both sides.
How can I connect my 2" to the existing 2" that is flush with the wall? I thought about some kind of reducer just for entrance/exit of the wall but can't come up with anything. I would need to go back to the 2" after it is reduced to get through the wall.
Any ideas?
Old 03-17-2019, 06:07 PM   #2
Rewards Points: 7,520
Chip around it on both sides just enough so you can glue on an LB is all you can do.
micromind and MikeFL like this.
Old 03-17-2019, 06:20 PM   #3
Rewards Points: 6,405
Sawzall the existing PVC, slitting it lengthways with a long blade, and pry it out with a beater screwdriver, then beat a new, longer 2" into the hole.
Old 03-17-2019, 07:03 PM   #4
cog
stuiec's Avatar
Rewards Points: 956
just for kicks, I'd roll up my heater blanket and jam it in there....let it get nice n toasty, then see what happens with a beater or some such. Probably make a giant wobbly mess......but I'd still try it.....on your job
Old 03-17-2019, 07:04 PM   #5
Rewards Points: 14,819
Drive up to Canada and get you some of that Tek-90 stuff big enough for your feeder. Apparently from what I read here , they let you just stuff that Chit just about anyplace.
99cents, glen1971 and daveEM like this.
Old 03-17-2019, 07:26 PM   #6
Rewards Points: 2,246
I'm really tired right now so I could be way off but do the conduit fill rules apply to short nipples?
If not, then use 1 - 1/2" to go through the wall and 2" outside.
Old 03-17-2019, 07:48 PM   #7
Rewards Points: 25,344
Joe is on the right track:
Further, BEVEL the edge of the newly inserted PVC. Later cut it square and true. You want excess PVC to mess with.
Use Pulling Lube to grease the operation.
Use a hefty block of 2x6 or some such as your point of pounding.
If you're lucky enough to have an automotive puller ( Snap-on, type ) you could rig a squeeze push by punching a hole into your 2x6 pushing plate.
Or, you could set wedge anchors to the left and right and then pull against them while pushing in the new PVC.
You can insert/ pound from either direction, of course.
If the fit looks too tight, consider buffing down the new PVC -- just a tad.
1/32" could make a big difference.
Old 03-17-2019, 07:54 PM   #8
Rewards Points: 1,749
Use it as a sleeve for SE cable.
On the outside cut the hub off of an LB. Attach the belly of the LB to the wall so itís hovering over the existing 2 inch pipe going through the wall.
Then just run the SE cable down the pipe, through the LB, through the pipe and into the panel. That is how I do all of my services now a days. Only without the pipe in the wall.
brian john and readydave8 like this.
There are 2 types of electrician... Those who knowingly break code, and those who lie about it.
Old 03-17-2019, 08:26 PM   #9
Rewards Points: 716
Thanks guys!
I like the "slitting" the conduit idea but the walls are 12" thick and I probably would have to cut from both inside and out.
I'll "mull" these over and come up with something.
@HackWork are you using copper or Al SE cable?
Old 03-17-2019, 08:37 PM   #10
wcord's Avatar
Rewards Points: 1,400
Use the existing sleeve for cable/data and just drill a new hole.
12" of concrete with a decent hammer drill would be completed faster than farting around trying to use/adapt the pipe
readydave8 likes this.
Social media has made too many of you comfortable with disrespecting people and not getting punched in the mouth for it.
Old 03-17-2019, 08:37 PM   #11
460 Delta's Avatar
Rewards Points: 414
The sleeve should drive out without too much drama, a little chipping around the ends may be necessary if the pipe was shorter than the forms inside width. Use a scrap of steel 2" pipe as a drift.
Florida likes this.
Old 03-17-2019, 08:39 PM   #12
4/0-4/0-2/0 aluminum SEU cable.
I run a piece of 2 inch PVC down to an LB, then just drill a hole through the house and run a piece of SE cable through the pipe in LB and into the house. Itís just a sleeve for protection.
brian john likes this.
A Little Short (03-17-2019)
Old 03-17-2019, 08:41 PM   #13
wcord's Avatar
Come on up and we'll show you where we can stuff it
macmikeman and eddy current like this.
Old 03-17-2019, 08:49 PM   #14
Watch it buster, I have cousins in high places..
Old 03-17-2019, 08:49 PM   #15
Rewards Points: 4,002
I run a piece of 2 inch PVC down to an LB, then just drill a hole through the house and run a piece of SE cable through the pipe in LB and into the house. It’s just a sleeve for protection.
Why bother with the LB? Just mount the meter pan directly over the 2" hole, SE cable through the back. Can leave the existing sleeve as-is.
Old 03-17-2019, 08:53 PM   #16
Iím assuming the hole is down low, too low to mount the meter.
Old 03-17-2019, 08:55 PM   #17
wcord's Avatar
okay
eddy current likes this.
Old 03-17-2019, 08:58 PM   #18
Rewards Points: 716
I didn't mention it but I'm using a meter/main. So I would have to use 4/0, 4-wire SER. Won't make much difference as far as the fit in the conduit though.
Old 03-17-2019, 09:05 PM   #19
Yeah, but Iím not sure if that would make the bend in the 2 inch LB.
Old 03-17-2019, 09:12 PM   #20
Modťrateur
Rewards Points: 16,466
for that 4 conductor SER ya can fit but the risk of damage is very high and most LB is not deep enough to make a good bend on SER.
ya have to end up use mougal 2 inch LB or oversized the LB like go get a 2.5 or 3 inch LB verison then it can able fit in.
Joke of the Day brian john Off Topic (Non Trade) 747 05-19-2019 12:10 PM
Solve This Puzzle - Mystery power outage zaps... MikeFL General Electrical Discussion 38 02-02-2019 08:45 PM
Resistor Puzzle power Off Topic (Non Trade) 24 09-01-2016 07:35 PM
240 volt gfci breader puzzle Anathera General Electrical Discussion 3 07-11-2016 04:24 PM
