Help with voltage loss - Electrician Talk - Professional Electrical Contractors Forum
Old 06-11-2012, 08:26 PM   #1
Rewards Points: 250
Default Help with voltage loss
Can't figure this out, I have a customer that on one circuit has 3 kitchen recessed cans, that then feeds a study light, that then feeds a bedroom light that then feeds 1 receptacle, and two receptacles.
The issue is when ever the iron is plugged into either receptacle, the study and bed lights dim by 4.8V.
I checked every connection for a loose neutral or loose connection but that wasn't it.
I then noticed that the kitchen lights only dip 1.1V, so I thought there must be either a nail or screw in the wire from the kitchen switch to the study switch, where I am stuck; is the 1.1V dip on a load normal?
I don't want to run a new wire and then find that the lights still dim due to the 1.1V dip
I know this maybe obvious or basic to you guys but I just cant get my head around it.
Auselect is offline   Reply With Quote
Old 06-11-2012, 08:37 PM   #2
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
I think you're seeing perfectly normal voltage drop. For an iron drawing 12A, I get a voltage drop of about 5V for a 75 foot circuit.
-John
Old 06-11-2012, 08:37 PM   #3
Rewards Points: 1,464
Sounds like old wiring.
Old 06-11-2012, 08:42 PM   #4
Rewards Points: 250
The home is only 3 years old
Old 06-11-2012, 08:43 PM   #5
Rewards Points: 250
-John
Then why do I get 5V at the study - which is upstairs, and 1.1V in the kitchen - which is on the first floor???
Old 06-11-2012, 08:51 PM   #6
Dash Dingo's Avatar
Rewards Points: 318
Is there backstabbing along the circuit?
Dash Dingo is offline   Reply With Quote
Old 06-11-2012, 08:54 PM   #7
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 300
Could be a number of things: Are these two circuits of different lengths? Are they different gauge wiring? Or is this the same circuit being measured at two different points?
Voltage drop changes with circuit length and conductor size. The drop at the middle of a circuit will be less than the drop at the end of that same circuit.
-John
Old 06-11-2012, 09:03 PM   #8
-John
Basically this. Also amount of load on the circuit as mentioned above.
Cujo is offline   Reply With Quote
Neutral Loss MEISENBURG General Electrical Discussion 2 04-12-2012 06:36 PM
Phase loss monitors Chris1971 Commercial Electrical Forum 3 04-10-2012 11:55 PM
One Electrician's Loss... Jupe Blue General Electrical Discussion 25 06-04-2011 10:16 AM
Voltage loss problem. winright007 Services and Service Equipment 12 09-12-2009 11:37 PM
need help calculating power loss john salyards General Electrical Discussion 16 03-12-2008 09:30 PM
