HELP! - What wafers lights do you use? - Electrician Talk - Professional Electrical Contractors Forum
Like Tree11Likes
  • 1 Post By 99cents
  • 1 Post By HackWork
  • 1 Post By John M.
  • 3 Post By Switched
  • 2 Post By Switched
  • 2 Post By CoolWill
  • 1 Post By GroundFighter 78
Old 01-12-2019, 06:07 PM   #1
Rewards Points: 524
Default HELP! - What wafers lights do you use?
I have a customer I will be installing 47 wafer lights. I got a quote on the lithonia wafer led lights. My supplier told me they are in stock. i went to order them and Lithonia says they are discontinued. What other brands are out there? What do you use and like?
John M. is online now   Reply With Quote
Old 01-12-2019, 06:11 PM   #2
CoolWill's Avatar
Rewards Points: 1,694
What was discontinued? One product line? I have heard nothing of the whole Lithonia wafer line being axed. Lotus is the other major brand of wafer LEDs.
Old 01-12-2019, 06:15 PM   #3
Rewards Points: 11,027
Lithonia told you that or some dumbass supplier?
CoolWill likes this.
Old 01-12-2019, 06:21 PM   #4
Rewards Points: 1,567
Yes, Please clarify this.
I don't know if the Lithonias are that great or not. But I do know that I can always get them in 2 days for $25-30 from Amazon and I have had none fail on me.
If they are getting discontinued, I will be sad
Old 01-12-2019, 06:49 PM   #5
Rewards Points: 2,910
I would check into the lithonias switching CRI ones maybe that is what they mean the new go to are the cri adjustable ones
Old 01-12-2019, 07:04 PM   #6
Switched's Avatar
Rewards Points: 8,810
Halo
https://www.homedepot.com/p/Halo-HLB...EMWR/306051064
Old 01-12-2019, 07:05 PM   #7
Rewards Points: 18,720
Just ordered a couple packs Lithonia WF6 with no issues.
Old 01-12-2019, 07:08 PM   #8
Rewards Points: 524
Sorry, I wasnt clear on that. The WF6 line is still good. I needed a 4000K in black trim, not real common.
Old 01-12-2019, 07:12 PM   #9
Originally Posted by Switched View Post
Over 100 in stock at my local HD, selectable color temp, and they look good. Looks like a winner to me.
Have you installed many? Any issues? Does it fit in half inch drywall under a joist? A friend told me that he bought a knock off brand that said it fit in half inch drywall but in actuality itís stuck down a little bit.
Old 01-12-2019, 07:28 PM   #10
Switched's Avatar
I have installed about 50 of them so far. I noticed that HD had the Lithonia on clearance and the writing was on the wall. So I was looking for a replacement, and they had these on the shelf.
I prefer these hands down over the Lithonia.
They install the same as Lithonia, being a 1/2" and fitting under a joist. They have a higher lumen rating and a higher CRI, that with the selectable color is a winner in my book. No need to worry about color, if they don't like it just show them how to flip the switch.
HackWork, MTW and GroundFighter 78 like this.
Old 01-12-2019, 07:48 PM   #11
Rewards Points: 524
They look great, bit I'm skunked again. This customer wants the black trim. I did check Lotus, they may be an option,
Old 01-12-2019, 08:13 PM   #12
Switched's Avatar
Send them this link, they can have any color they want.
B-Nabs and GroundFighter 78 like this.
Old 01-12-2019, 08:57 PM   #13
Rewards Points: 524
What is your phone number? They may be calling you.
Old 01-12-2019, 09:53 PM   #14
Switched's Avatar
You can give them this number
1-800-898-2428
Old 01-14-2019, 10:10 PM   #15
I like the Halos at Home Depot best. They will fit under a joist in 1/2 inch drywall. Also the spring clips will work on a greater range of ceiling thickness. I have used them on 3/8 over top plaster and lathe with no problem. Four and an eighth holesaw on the four inchers is perfect.
Sent from my SM-S327VL using Tapatalk
wmbettsjr is offline   Reply With Quote
Old 01-14-2019, 10:34 PM   #16
CoolWill's Avatar
Some masking tape and a can of spray paint can go a long way toward meeting color requirements.
tmessner and GroundFighter 78 like this.
Old 01-15-2019, 12:12 AM   #17
Rewards Points: 15,409
f a color requirement. They come in white. You want another color , get a painter to handle that.
Old 01-15-2019, 04:43 AM   #18
Galt's Avatar
Rewards Points: 963
No box is required? I use the GM lighting ones but you need a box.
Galt is offline   Reply With Quote
Old 01-15-2019, 10:21 AM   #19
Rewards Points: 348
I've done this a bunch of times for customers, and in my own house. It was, of course, a nice upsell to both the customers and the wife.
GroundFighter 78 is offline   Reply With Quote
Old 01-18-2019, 07:32 AM   #20
Rewards Points: 141
I use Topaz 4 " and 6". They come in 3k 4k and 5k and run about $12. I use them directly beneath floor joists in 5/8 rock with no problems. Way easier then the cans used to be.
greenlee is offline   Reply With Quote
Clark Griswolds Xmas Lights WronGun General Electrical Discussion 21 12-25-2017 06:45 PM
Lights flashing gil48311 General Electrical Discussion 14 10-30-2017 08:36 PM
Front Porch-PVC conduit work for lights AFJES2017 Residential Electrical Forum 29 10-20-2017 01:41 AM
Removing unwanted recessed lights. Woodman General Electrical Discussion 4 05-03-2016 03:56 PM
