help with which wiring to use for project. - Electrician Talk - Professional Electrical Contractors Forum
Closed Thread
Old 05-22-2014, 07:07 AM   #1
Default help with which wiring to use for project.
Greeting from Australia the land of 240V power.
I need help with a project. We have a bunch of 12V 10W LED outdoor floodlights for small signage applications.
The problem is we need a 20 meter 12V cable from the light to the driver that converts the 240V power to 12V.
The problem: The cable will drop in voltage by the time it gets to the 10W 12V LED floodlight, and then it wont work.
What wire can we use to make sure there is no voltage drop? Is there a way to calculate this.
Please note the wire needs to be 12V because 240V is just not an option due to safety regs on the 20 meters of cable.
your help would be great
Simo is offline
Old 05-22-2014, 07:25 AM   #2
Rewards Points: 88
Specifically what Aussie safety regs prevent you from running your 240v out closer to the sign? What size/type of cable?
Quick voltage drop online calculator: http://www.southwire.com/support/vol...calculator.htm
Jarp Habib is offline
Old 05-22-2014, 08:07 AM   #3
Rewards Points: 1,363
Use a higher voltage DC power supply to get 12v on the distant end
samgregger is offline
Old 05-22-2014, 08:12 AM   #4
Speedy Petey's Avatar
Rewards Points: 604
Thanks for posting on ElectricianTalk.com. However, working with electricity and electrical systems can be unsafe if not done by a professional licensed electrician. The moderators of this site would like to advise you to contact a professional electrician in your area.
Speedy Petey is offline
Closed Thread
Another new project....... RobRoy General Electrical Discussion 68 06-20-2012 08:07 PM
4H project wiring problem Jessica NEC Code Forum 1 07-22-2011 05:32 PM
Project dantheman Lighting Design 5 02-04-2011 06:21 PM
Our next project Magnettica Residential Electrical Forum 164 09-19-2010 11:12 AM
Ac vs. Dc project Skim302 General Electrical Discussion 14 01-21-2008 01:28 PM
